Old 08-10-2012, 12:01 AM   #726
Wes_888
Member#: 320291
2012 Impreza 4DR 5MT
Originally Posted by FlyerHazen View Post
My apologies for the late response, I just got back to college. I know the inlet from the mid-pipe is 2", so some modding may be required depending on which axle back. These are the ones I found for HKS universal mufflers:
http://www.andysautosport.com/subaru...t/mufflers/hks
I don't know yet which one I'll buy. I may just wait for a axle back or cat back specifically designed for our Imprezas. Considering our car isn't really for "tuners", we may have to wait a bit.
My thoughts exactly. It may be a while till something comes out... if one even comes out :S
But I will wait nonetheless but man, that HKS muffler looks real good though. lol
Wes_888 is offline   Reply With Quote
Old 08-10-2012, 04:36 AM   #727
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
What about getting an exhaust shop to custom a fabricated mandrel bent exhaust system?
pkL is offline   Reply With Quote
Old 08-10-2012, 04:23 PM   #728
imcausinmadrukis
Member#: 318978
Default Fog lights
Originally Posted by sgoldste01 View Post
Send me a PM with your email address, and I'll send you the info you need.
Can you PM me the info as well?
imcausinmadrukis is offline   Reply With Quote
Old 08-10-2012, 09:53 PM   #729
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
These cars come with front and rear sb? i checked the front today and i dont see any fsb, havent checked rear. I have limited sedan so shouldnt it have these? Am i not seeing it? Could someone point out the stock one for me on a pic maybe?
thx
Old 08-11-2012, 12:13 AM   #730
ans2k
Member#: 315631
2012 Impreza Sport
fsb is the front SWAY bar, we do not have a front STRUT bar.
ans2k is offline   Reply With Quote
Old 08-11-2012, 12:27 AM   #731
pkL
Member#: 313093
2012 Impreza 2.0i
thx
You can buy a front strut bar for under $200. I have one installed.
Old 08-11-2012, 08:49 AM   #732
WLS
Member#: 316030
Originally Posted by uspopo View Post
Subaruonlineparts.com I think I paid just under 100.00 for the bar and a set of bushings not including NYS tax and shipping....
I don't see it listed there. Do you have to call and ask if they stock it? Is there a part number to look up?
Thanks
WLS is offline   Reply With Quote
Old 08-11-2012, 10:20 AM   #733
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Thanks
Look under wrx or sti 08+
Old 08-11-2012, 06:24 PM   #734
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
Ok, has anyone done an LED rear plate lamp bulb swap yet? I have already done the map/dome and cargo area but I can't figure out how to access the license plate lamp assembly..any help or pics would be appreciated...
Stan
uspopo is offline   Reply With Quote
Old 08-11-2012, 07:14 PM   #735
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Stan
What is the point of changing the dome/map lights?
Old 08-11-2012, 07:27 PM   #736
myrt1987
Member#: 323103
2012 Limited 2.0i
Oh gotcha. thanks guys. I want that!
Do they affect handling similarly? in that they improve it?
Old 08-11-2012, 07:39 PM   #737
WLS
Member#: 316030
The only one that shows up is a 17mm sway bar and I thought it was a 19mm one being discussed. There is a BRX swaybar listed but not picture or size listed.
Old 08-11-2012, 09:12 PM   #738
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I seem to remember seeing it, i will look
Didn't take me long to find it..
http://www.subarugenuineparts.com/pr...oducts_id=1690
Old 08-11-2012, 10:19 PM   #739
pRiMe DiReCtIvE
Member#: 301387
2012 Impreza HB
Black/Dark Grey
Look for 2011 STI.
pRiMe DiReCtIvE is offline   Reply With Quote
Old 08-12-2012, 12:07 AM   #740
eps105
Member#: 205153
2014 Forester 2.5i
Venetian Red
Thanks
Actually, even easier -- Look under 2010-13 Outback Performance Parts. They have a kit put together with everything you need, which was popularized back in 2010 when Outback owners learned the same thing -- that the 19mm WRX sway bar and bushings drop-in to the Outback. In the link below, you'll also see a hyperlink to Subaru Outback installs (myself included). This kit is now a drop-in fit for the Impreza also. When I get my Impreza, I'll be moving my 19mm RSB from my Outback.
https://www.subaruonlineparts.com/pr...oducts_id=1267
eps105 is offline   Reply With Quote
Old 08-12-2012, 06:56 AM   #741
uspopo
Member#: 317014
ISM
I like the softer white light that the LEDs give off and am used to it plus I have replaced all my personal incandescent flashlights with Cree LED units. Less heat and power drain (not that it matters too much in the cars).
Old 08-12-2012, 07:10 PM   #742
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Yes, but you will need to PM me your email address first.
sgoldste01 is offline   Reply With Quote
Old 08-13-2012, 12:34 PM   #743
FastJK
Member#: 317325
2012 Impreza Hatch
Stan
Yeah. They're your standard 168 bulbs. Just pull the edge of the plastic lens towards you its a pressure clip and wiggle it out.
FastJK is offline   Reply With Quote
Old 08-13-2012, 02:33 PM   #744
Cogito8888
Member#: 328981
2012 Impreza 2.0i
Hatch 5MT Camellia Red
thinking about going this route with a lightweight burns muffler
also for anyone who cares, I weighed the steel wheels on the 2.0i and the spare yesterday.
Steels were 15lbs minus the weight of the 19lb tire
Spare was about 25.5lbs
Cogito8888 is offline   Reply With Quote
Old 08-13-2012, 02:48 PM   #745
uspopo
Member#: 317014
ISM
Thanks, I was gently tugging on one and it looked like it was doublesided taped to the attachment plate so I thought you had to access it behind the hatch panel..
Old 08-13-2012, 04:08 PM   #746
FastJK
Member#: 317325
2012 Impreza Hatch
Its just a foam washer to insulate the plastic from the metal.
Old 08-13-2012, 11:37 PM   #747
Wes_888
Member#: 320291
Will these sparco pedals work with our impreza's?
http://www.sparcousa.com/product/reflex-shrtnrw
along with this dead pedal?
http://www.sparcousa.com/product/dead-pedal-grip
I really like that aluminum look with the pedals. The black rubbery stuff isnt doing it for me.
Just found a DIY for it. Looks like a lot of work :S
http://www.fordstownerssa.co.za/foru...p?f=57&t=43413
Old 08-14-2012, 12:45 AM   #748
pkL
Member#: 313093
2012 Impreza 2.0i
Those look awesome, but that's a lot of work, to the point where it would be worthwhile to buy the OEM metal ones.
I bought 10 of the standard 168 bulbs and I'm wondering what existing bulbs can be replaced with LEDs? Interior lighting (light in the hatch, 2 map lights, and door illumination light) and license plate lights, is there anything else I can swap out?
Old 08-14-2012, 12:57 AM   #749
pkL
Member#: 313093
2012 Impreza 2.0i
Keep me posted on how that goes, I'm especially interested in the price seeing that I can probably buy a branded exhaust system for the 2.5 RS and have a muffler shop modify and bolt it on for me.
The car corners a lot flatter now and I can take corners faster than before. The rear sway bar is possibly the best upgrade for your money.
Old 08-14-2012, 06:01 AM   #750
uspopo
Member#: 317014
ISM
The map and dome lights are the 31mm Festoon bulbs, the glove box already has a led light...Cargo and LP lights are 168 bulbs.
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
