Old 09-12-2012, 07:51 PM   #976
kenny doggins
Member#: 326540
2012 Impreza MT SP
Originally Posted by mitchjjohnson View Post
Rear Sway, and some other small parts for the 2012/13 Impreza!
http://www.perrinperformance.com/subaru/impreza-na-2012
Hey I just had a chat regarding this sway bar. Seems like it's only for base model. If you already have an rsb under there (sport premium or limited) you don't need all the hardware this kit comes with.
better info here, and my lame attempt to find out direct form perrin what the deal is with that: http://forums.nasioc.com/forums/showthread.php?t=2298202&highlight=2012+sway+bar
hope it helps.
kenny doggins is offline   Reply With Quote
Old 09-12-2012, 07:58 PM   #977
imcausinmadrukis
Member#: 318978
This is for the none retro-fit fog lights.
Aside from adding yellow film to your fog light lens has anyone ventured out with replacing the bulbs and had any success?
What is the difference between H16 and psx24w?
I really want to upgrade my fog light bulbs from the OEM and give it more a yellow look but I read mixed reviews about the metal around some bulbs will melting. Also I don't want to lose the light output which is why I don't want to put in LED's.
imcausinmadrukis is offline   Reply With Quote
Old 09-13-2012, 01:50 AM   #978
12ImprezaSL
Member#: 322198
2012 Impreza SL
Originally Posted by 95carigreenwagon View Post
Notice any difference in fuel economy or power? Sounds great.
Thanks! MPG actually went up a little bit. Low end is a little weaker but has better high end.
12ImprezaSL is offline   Reply With Quote
Old 09-13-2012, 01:52 AM   #979
12ImprezaSL
Member#: 322198
2012 Impreza SL
The little nub in the socket of the bulb it the only difference. Just shave the nub off and it should fit.
Old 09-13-2012, 09:36 AM   #980
j0nm13n
Member#: 331977
Default SPT exhaust?
I'm ordering a new 2013 WRX within the next week and debating on the SPT exhaust. Would this CBE work with an aftermarket downpipe (i.e. perrin downpipe with cat)?
I can't seem to find anywhere if the SPT is a 3" CBE instead of the stock 2.5". I just want to be able to go to an aftermarket downpipe and a stage 2 tune at some point down the road. I like the sound of the SPT but will not get it if I can't go with an aftermarket downpipe at some point.
j0nm13n is offline   Reply With Quote
Old 09-13-2012, 12:57 PM   #981
kenny doggins
Member#: 326540
2012 Impreza MT SP
wrong thread, we're all about economy and suspension mods
Old 09-13-2012, 06:23 PM   #982
Hate
Member#: 304868
2015 WRX
I'm picking up my 2013 Premium 5 Speed next week... my first question is is there any short shifter kit out for the car yet? I would like to clean up the sloppy feeling of the slushbox 5 speed. Also, who's putting out coilovers. I want to have some parts waiting for this thing.
Hate is offline   Reply With Quote
Old 09-13-2012, 11:03 PM   #983
nels0300
Member#: 331332
2014 Camry SE V6
"slushbox" is a nickname for an automatic transmission.
nels0300 is offline   Reply With Quote
Old 09-14-2012, 08:24 PM   #984
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
Perrin's short shift adapter fits perfect as well as any short shift kit from previous years. I took mine off my 02 bug eye.
apexracer is offline   Reply With Quote
Old 09-15-2012, 03:04 PM   #985
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
Installed my Supertones today....no more cheesy Japanese beep...FTW!
uspopo is offline   Reply With Quote
Old 09-15-2012, 10:51 PM   #986
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Looks great! Did you get the mounting bracket?
italia490 is offline   Reply With Quote
Old 09-16-2012, 06:04 AM   #987
uspopo
Member#: 317014
ISM
Yes, I got the bracket and harness from Subimods but make sure you use the relay included with the Hellas and not the one supplied with the harness because it was buggy. The horn worked fine then after putting everything back together it didn't so we had to pull off the grill and check all the connections again. Everything looked fine so we decided to try switching the relay out and voila!
Old 09-16-2012, 08:10 PM   #988
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
The supertones was one of the first mods I did. I mounted mine towards the bottom of the radiator and made my own wiring harness.
Old 09-16-2012, 08:23 PM   #989
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Thought about doing it but not sure it's worth it..plus I just don't care for that sound anyways I'd rather have a regular sounding horn...ford trucks have great horns!!!
jsteg is offline   Reply With Quote
Old 09-16-2012, 08:37 PM   #990
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
You probably could wire them in...
Old 09-17-2012, 11:24 AM   #991
Matt4949
Member#: 313890
2012 Impreza Sport
Marine Blue Pearl
Default Supertone Problem
Matt4949 is offline   Reply With Quote
Old 09-17-2012, 11:36 AM   #992
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Originally Posted by Matt4949 View Post
There are two separate units if you will....one is for the horn and the other is for the alarm chirp. The one for the alarm chirp is located on the passenger side of the vehicle in front of the wheel well. The horn itself is located in front of the radiator towards the bottom just behind the front bumper. The supertones should be wired in with the included relay. This can be done by purchasing the wire harness or doing your own wiring. The horn itself has no bearing on the chirp when you lock/unlock your car. Subimods.com is a good place to start. They have the horns, wiring harness and mounting bracket.
Old 09-17-2012, 11:46 AM   #993
Matt4949
Member#: 313890
2012 Impreza Sport
Marine Blue Pearl
Italia,
Thanks for the insight. If I understand you correctly, the unit for the alarm chirp is the same as for the remote start chirp, which is a different unit from the primary horn? I.E. I should be able to just wire up the hellas according to their instructions, and not worry about them being activated with the remote start system? Is it possible to just remove this secondary unit?
Old 09-17-2012, 11:57 AM   #994
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Italia,
I can't comment on the remote start feature but the unit for the alarm chirp is completely separate from the horn. When the alarm has been tripped though, it's the horns that go off. I can't remember for certain but I think there is a way to disable the chirp when arming/disarming the alarm. If not, it can always be unplugged.
Old 09-17-2012, 12:03 PM   #995
Matt4949
Member#: 313890
2012 Impreza Sport
Marine Blue Pearl
I guess all that's left to do is order 'em up and see what happens! Thanks!
Old 09-17-2012, 01:14 PM   #996
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
For the remote start, the horn is honked when the car is started. Not the beep of the alarm chime.
ST Eye is offline   Reply With Quote
Old 09-18-2012, 09:40 PM   #997
ans2k
Member#: 315631
2012 Impreza Sport
hey, some of you may remember that i mentions about getting after market fog lights. they are advertised as 7 watt smd high power led. yea, not sure, but i wouldn't call them an "upgrade" but they are brighter than ordinary stock halogens and other LED bulbs. but there isn't much usable light. not like the oem had any better.
without fog light on:
with fog lights on.
comparison stock passenger, led driver side.
beam pattern-ish
brighter than oem, i took a pic of the oem on my phone but accidentally deleted it. also headlights were unplugged to the lights are just the fog lights!!!
but if i were to do it again, would i? no
ans2k is offline   Reply With Quote
Old 09-19-2012, 04:34 AM   #998
uspopo
Member#: 317014
ISM
Thanks for the pics. If they are just a tad brighter as you noted than the OEM H16 halogen bulbs then I would considerate a worthy upgrade.
Old 09-19-2012, 06:50 AM   #999
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Wrong color for fog lights though.
I find the vinyl overlays i put on mine combined with my h9 low beams create enough contrast that my fog lights actually help, in fact i used them 2 mornings ago in some misty conditions and was actually pleased with how well they worked.
Old 09-19-2012, 07:03 AM   #1000
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Did you use yellow vinyl overlays like I did?
http://www.lamin-x.com/One-Universal...ver-p/1-48.htm
sgoldste01 is offline   Reply With Quote
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
