#1126 |
Member#: 317014
Vehicle:2012 Impreza Sp Ltd. Dark Grey Metallic |
Hell, I'm tempted to do a turn down also but not at the expense of hearing the drone. Maybe a Magnaflow would give it a little rumble and I really don't care about a nice exhaust tip since I have the 5-door.
#1127 | |
Member#: 257754
NWIC
Vehicle:2012 Impreza Sport P Camilla Red Pearl |
#1128 | |
Member#: 257754
NWIC
#1129 |
Member#: 317022
Vehicle:2013 Impreza Sp. Lim Dark Grey Metallic |
Hi all, i bought a front strut bar for my 2013 Impreza Sport Limited, but the item was from ebay and listed fit the 2012 WRX, i assume it fits in the impreza, but it didnt fit? Does anyone if they are the same strut for both model? Also i have a question regarding the rear strut, does that do much to the car compare to the front strut?
#1130 |
Member#: 317014
No, it will not fit. You have to get the one specific to the 12/13 Impreza/Crosstrek. I have the Cusco one right here after a 7 week wait....
![]() Should take all but 10 minutes to install. FTW! ![]() Last edited by uspopo; 10-01-2012 at 06:29 PM. |
#1131 | |
Member#: 330797
Vehicle:2012 Impreza 5dr Prm Satin White Pearl |
not sure if answered yet, but you are suppose to, from the right side of the housing, push to the left then lift and it should come out. also in the manual on how to change the light bulb for the plates. |
#1132 |
Member#: 317014
I actually removed the panel from the inside to access the both assemblies because I didn't want to ruin the single-sided foam insulation tape with a pry tool from the outside. I would have been pissed if water had gotten into the bulbs thru a ruined seal. Took an extra 5 minutes to remove the panel but I know I didn't compromise the seal in anyway.
#1133 |
Member#: 326540
BAIC
Vehicle:2012 Impreza MT SP DGM |
Posted in the classifieds, but just to put it out there, I'll be letting these go so PM me if you're interested.
http://forums.nasioc.com/forums/show....php?t=2414898 |
#1134 |
Member#: 317014
Good luck with the sale James..those should go fast!
#1135 |
Member#: 326540
BAIC
#1136 | ||
Member#: 313093
VIC
Vehicle:2012 Impreza 2.0i 5-door Sport. Dark Grey |
#1137 |
Member#: 323103
Vehicle:2012 Limited 2.0i Dreamy Gray Mistress |
#1138 |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
His are 17" rims too. Standard rim for the Sport Premium (and maybe Sport Limited too).
#1139 |
Member#: 323103
#1140 |
Member#: 322264
#1141 |
Member#: 73068
Vehicle:2008 STI Boost Wagon 2012 Impreza Limited ISM |
Easier to clean also!
#1142 |
Member#: 323103
Tell me about it. The 15 spoke gets dirty within a week, and takes forever to clean them. I plastidipped them so i wouldnt see it anymore.
#1143 |
Member#: 313093
VIC
I really like the look of the gunmetal rims, I wish they would offer them here in Canada. It sucks how you're all the way in California otherwise I would drive down and get those rims from you.
#1144 |
Member#: 334032
Vehicle:2012 Impreza 5 door Black |
Just a quick note.
On my '12 Impreza Hatch I currently have a SPT Front Strut Brace for a '12 WRX installed. It fits perfectly although it is barley touching the back of the engine bay. Second I have been building custom intake for my car using an '99 intake, '04 WRX MAF housing *"Had to fabricate a different hole out of plexiglas for the sensor because the hole on the original housing is 1.4" and our MAF sensors need a 1" hole", and some various silicone tubing/bends. So far on my intake I have been getting a check engine light that causes my cruise control and traction control to flash. I'm thinking I may have to go into the dealership and get my ECU re-flashed. |
#1145 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
#1146 |
Member#: 334032
The sound the intake gives is just a personal preference for me. Also, as soon as I start boring out my cylinders and building up the N/A engine, I'm going to need that increased air flow right? From what I have read/heard it's possible to get more power out of an N/A engine than a Factory Turbo it's just fairly costly
#1147 |
Member#: 314216
why would the dealership reflash your ECU for a modification you made that is now making it CEL?
#1148 |
Member#: 334032
Because their nice people.
I have heard that getting a CEL with a new intake is quite common and all it needs is a reflash to work properly. I'm going to the dealership to ask them to do it before I do it myself and defiantly void my warranty. |
#1149 | |
Member#: 308742
Vehicle:2012 Impreza Sport Marine Blue Pearl |
#1150 |
Member#: 317014
hhhhmmmm
| Thread Tools | |
| Display Modes | |
| factory SS or aftermarket for 2012??? | Myth21 | Transmission (AT/MT) & Driveline | 8 | 01-07-2012 11:18 AM |
| Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? | somebody else | Southern California Impreza Club Forum -- SCIC | 1 | 12-29-2011 11:31 PM |
| Has anyone test drive a 2012 Impreza yet? | pRiMe DiReCtIvE | General Community | 25 | 11-28-2011 10:03 PM |
| Hybrid Impreza in the works for 2012? | rsholland | News & Rumors | 43 | 03-12-2010 10:58 PM |
