Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 04-04-2012, 12:07 AM   #126
li312
Member#: 310084
2012 Imp 2.0i Sp Lim
Dark Gray Metallic
Question
Originally Posted by italia490 View Post
I have a complete LED swap on my car except for the DRL's. It looks nice and is not hard to do.
One more question...
When you did the LED swap for the turn signals and brake lights, you know how sometimes the LED's don't reflect properly off the mirror and it changes the appearance of the reflector housing or decreases the brightness or reduces the amount of mirror that is lit up. Did you experience any of this?
li312 is offline   Reply With Quote
Old 04-04-2012, 12:27 AM   #127
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I did experience that with the turn signals actually. The first 4 that I bought were not bright enough...well actually they probably were but because the bulb sits in the housing at an angle the brightness appeared diminished. I ended up getting an led bulb with more led's. I am satisfied for now however I'm sure I will end up swapping them out for something else or taking the lights apart and building boards with SMD leds instead so I don't have to worry about the light reflecting off the inner mirror housing.
italia490 is offline   Reply With Quote
Old 04-04-2012, 08:37 AM   #128
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
Thanks for the link
Here are the pictures...
http://s1161.photobucket.com/albums/q507/strunz490/
I definitely want to do the plasti dip on my grill like that, looks good! Did you do anything to prep the grill before spraying it?
imprzya is offline   Reply With Quote
Old 04-04-2012, 10:12 AM   #129
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
There isn't anything special that needs to be done to prep the grill. Plastidip goes on very easily. I used a citrus base degreaser to clean it up. You'll want to make sure it is completely dry. Mask off any areas that you don't want covered and then start spraying. You'll want to do 4-5 thin coats. If you spray to closely or apply too heavy of a coat, you'll get drips.
Old 04-04-2012, 11:30 AM   #130
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Would you recommend the spray or the bucket? It would seem easier to just dip it (no need to mask) but I guess it depends on the application though.
http://www.car-lab.com/2007-2011-sub...rs-light-lamp/
Why is this one so much cheaper? Is it even the same thing and will it even fit?
I was content with the price for them on this site:
http://www.customledservice.com/subaru_prod.html
Actually its like a $8 difference, I will definitely buy it from the 2nd site.
pkL is online now   Reply With Quote
Old 04-04-2012, 11:35 AM   #131
BryanP5555
Member#: 314731
2014 WRX
Spray for sure. bucket will come out messy and uneven.
BryanP5555 is online now   Reply With Quote
Old 04-04-2012, 11:48 AM   #132
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Spray for sure. I have dipped a few tools and really don't like the way it comes out. As BryanP said, it's messy and comes out uneven. Like I said, the spray is easy and very forgiving unlike rattle can spray paint. When I did mine, I removed the grill from the bumper, which required removal of the bumper. I planned it this way because I installed the Hella Supertones at the same time. Just make sure you take your time.
It's hard to say especially without being able to see the back of the housing.
Old 04-04-2012, 12:37 PM   #133
pkL
Member#: 313093
2012 Impreza 2.0i
Yeah I will go with the 2nd site, the total is only $8 more and its exactly the same as the one you had ordered, not really worth the risk and wasted time otherwise.
Old 04-04-2012, 05:13 PM   #134
li312
Member#: 310084
Dark Gray Metallic
ooooo. Interesting. Glad I asked! I wish I had the skills to build LED's into the housing, that would be sweet.
But the brake lights worked out well? And you said you used the 7443 with the re-wiring cause you couldn't find the 7443-CK??
Old 04-04-2012, 05:22 PM   #135
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
We'll see. I would need to get an additional set of tail light housings to do a mod like that. Tail lights can't be baked like head lights and pulled apart. They have to be cut open. The idea would be to build a board that has the leds mounted on it and uses the standard bulb base so they are just plug and play essentially.
Brake lights worked out fine. In fact I want to say that they are as bright as the stock filament bulbs. For the 7443 bulbs, the first pair I bought kept burning fuses because they were not the -CK type. Unfortunately, the base was glued to the housing so I tried the different wire configuration with little success. I ended up buying a second set which worked out even better. The base wasn't glued to the housing so what I ended up doing was straightening out the leads, pulling the base off and then re-position the leads to the proper location. This worked great and I think it's a better idea then the re-wire option.
Old 04-04-2012, 11:01 PM   #136
sparky62
Member#: 315653
2012 Impreza
Originally Posted by brockd View Post
Ya I'd love some fogs. Are the stock ones bad? I was contemplating installing them myself if I did them for the right price.
I just finished installing the fog lights, they look good and are very easy to install. Took me about 45 min.
sparky62 is offline   Reply With Quote
Old 04-04-2012, 11:04 PM   #137
PAO56
Member#: 304676
2012 Impreza Ltd 5DR
Deep Cherry Pearl
car-lab is shipped from Taiwan.....and the other one is local......I will go with the local one......he had great customer service......I didnt post his link orginally as someone asked.....didnt know if the site allowed the links to non-supporting vendors or not.....thus I didnt post it personally....but is is customledservice.......
PAO56 is offline   Reply With Quote
Old 04-05-2012, 12:29 AM   #138
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
What fogs did you use. The OEM ones intended for the Impreza or something else? Can you post pics?
Old 04-06-2012, 12:55 AM   #139
li312
Member#: 310084
Dark Gray Metallic
Sweet deal! Thanks for taking a minute to spell out the details. Super helpful!
Care to share where you bought the second set from??
Old 04-06-2012, 12:58 AM   #140
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I haven't purchased the second set. If I were to do such a modification, I would need to get a second set.
Old 04-08-2012, 01:05 AM   #141
dreezy
Member#: 312678
2012 Impreza
Perrin short shifter for the '11 impreza works on the '12. I have the brushing too I just haven't gotten under the car yet.
dreezy is offline   Reply With Quote
Old 04-08-2012, 01:34 PM   #142
pkL
Member#: 313093
2012 Impreza 2.0i
Hey I placed an order for rear bumper LEDs, I'm about to checkout in Paypal, it shows shipping and handling is $7. I'm assuming they will ship to Canada and for that price as well? The contact us link on the site does nothing.
Anyone have any experience or thoughts on the rear hatch area LEDs, they do seem cool but I don't see why you would want that kind of lighting in the hatch though.
Old 04-09-2012, 10:23 AM   #143
PAO56
Member#: 304676
Deep Cherry Pearl
if you ordered from the local vendor...I can send you his email address....he will respond within 24 hours.....let me know
Old 04-09-2012, 07:28 PM   #144
BryanP5555
Member#: 314731
2014 WRX
Here are the net prices for everyone. I got these parts today for what the dealer paid for them. i had the dealer order these parts for me. last week they quoted me Front spoiler installed $325.45, Rear Aero splash guard $225.68 and front mesh grille $292.72 which totaled out to $843.85. for everything. He also had told me they were giving me 15% off the list price and the number i just listed reflect 15% off plus install prices.i was going to see if i could talk them down a bit but thats before i caught a glimpse of the order sheet they handed me by mistake with all the net prices for the parts on it. here is my bill after i said i wanted them all for net price and said ill do the install myself
I hope this saves you all some money
Old 04-09-2012, 07:58 PM   #145
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
Did the plastidip on my grill last night. You don't need to take off the bumper to get the grill off, just need a stubbie little screw driver
Old 04-09-2012, 11:59 PM   #146
79letour
Member#: 302570
2013 XV
DGM!
Nice looking^^
I'm gonna copy yall and do the same on my grille.
On another note- I love the ride of my car but I think at 50-60k I'm going to see about upgrading the suspension. I just want it a tad bit firmer and less body roll. I'm definitely going to look into aftermarket sway bars.
79letour is offline   Reply With Quote
Old 04-10-2012, 06:49 AM   #147
pkL
Member#: 313093
2012 Impreza 2.0i
Well I will order from him, haven't placed the order yet, in case shipping is a lot.
Old 04-10-2012, 12:28 PM   #148
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Looks good! I'm thinking of doing this too, but just painting the "wings" black and the outer edge of the grille body color. Nice to know that removal of the bumper isn't necessary to take off the grille!
jr0bb5 is offline   Reply With Quote
Old 04-10-2012, 02:28 PM   #149
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
There is a pic of someone who just painted the wings on the 2012 impreza picture thread in the Members Car gallery. His car is white so the silver trim doesn't stand out as much.
Old 04-10-2012, 04:06 PM   #150
pkL
Member#: 313093
2012 Impreza 2.0i
That looks so nice, definitely on my to do list.
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 1 12-29-2011 11:31 PM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
