Old 05-17-2013, 02:34 PM   #2376
fistv
Member#: 350063
2013 Impreza sport
Looks nice, scored one from Macanudo here at work, sadly it's too short for the imp so it's now in my Cherokee.
fistv is offline   Reply With Quote
Old 05-19-2013, 08:46 PM   #2377
Angelus911
Member#: 89967
2012 Impreza Sport
Quick question to those who have installed Hella Supertones and used the Subimods wiring harness: how did you get it to plug into the factory harness?
It seems like our year has a different connector, as it won't fit the connection on the Subimods harness (factory connector below):
It also seems that the Subimods harness isn't the best wire length for our cars either, as the good mounting point for the relay by the washer fluid resevoir ends up being too far away for the wires to be able to hook up to the horns themselves. Before I start ripping apart the harness, has anybody made the Subimods harness work?
Angelus911 is offline   Reply With Quote
Old 05-20-2013, 06:55 AM   #2378
ronjr8102
Member#: 216040
2013 Impreza 2.0i5dr
dark metallic grey
I used the Subimods harness on my car. Yes the plug was bigger than the factory plug but I just trimmed it to fit and it worked fine. Then I wrapped it in electrical tape but I went to rewrap it and pulled the connector off so I just spliced it in before the factory connector and still works the same.
For the relay I zip tied it to a hole on the driver's side top part where there was a open hole and didn't seem to have any issues with length.
ronjr8102 is offline   Reply With Quote
Old 05-20-2013, 08:03 AM   #2379
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I don't have the subimods harness, but I made my own. I cut the connector off one of the factory horns and soldered that on my harness so it will plug into the other factory connector.
There is a thread "2012 2.0I supertones install" or something like that, I posted my pictures there
Old 05-20-2013, 03:37 PM   #2380
Angelus911
Member#: 89967
2012 Impreza Sport
Thanks for the feedback, I'll probably look at it again this weekend see how to make it work the best. I have to figure out where to mount the relay - the harness is only long enough to mount it behind the bumper beam. I'd have to modify it to put it in either of your locations
Old 05-20-2013, 04:00 PM   #2381
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
MjSub2.0 is offline   Reply With Quote
Old 05-21-2013, 08:24 PM   #2382
solistik
Member#: 345948
Cross-post from the 2012 Impreza Pictures thread:
Originally Posted by solistik View Post
Freshly lowered on BC Racing BR Series Coilover Kit:
solistik is offline   Reply With Quote
Old 05-21-2013, 09:56 PM   #2383
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
^^ Nice wheels.
sgoldste01 is offline   Reply With Quote
Old 05-22-2013, 09:13 AM   #2384
tenaciousZ
Member#: 342279
2012 Impreza Sport
Hey MjSub2.0, horns look awesome!! I actually like the extra spread.. Looking forward to seeing it with the grill on.
Btw, what did u use to plug ur old license plate holes??
tenaciousZ is offline   Reply With Quote
Old 05-22-2013, 11:17 AM   #2385
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
Thanks buddy. I'm still using the factory grille and you can't see the horn much unless you switch to a sport grille. The tabs for the license plate holes, I got that at Lowe's hardware store. Pretty cheap . http://forums.nasioc.com/forums/show....php?t=2306527
Old 05-22-2013, 02:02 PM   #2386
AJB001
Member#: 338330
Congrats on the sucessful lowering, It looks only a little lower than the RSR springs. Hope you slam it someday
AJB001 is offline   Reply With Quote
Old 05-24-2013, 07:13 AM   #2387
ronjr8102
Member#: 216040
dark metallic grey
MjSub2.0- Nice. Did u get a new grilletoo. I got the same ones but mounted them ib the middle with the Subimods bracket. I have a mesh grille and people are always looking at my car as the horns stick out and are very noticeable. I had someone ask if they were speakers.
Old 05-24-2013, 08:35 AM   #2388
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
^Thats when you say "yea listen close" and blow the horn. lol
Old 05-24-2013, 09:07 AM   #2389
ponchsox
Member#: 353045
Which wheels are those?
ponchsox is offline   Reply With Quote
Old 05-24-2013, 11:33 AM   #2390
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
LOL! Tell them it plays whatever favorite song they want... Honk!!!
Old 05-24-2013, 12:26 PM   #2391
AngryPanda
Member#: 253849
Did you guys see that Tanabe is looking for an Impreza for R&D?
http://www.tanabe-usa.com/rnd/post/T...plicants!.aspx
AngryPanda is offline   Reply With Quote
Old 05-24-2013, 01:03 PM   #2392
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
I got a call from tein but they need the car for two weeks
subaru222 is offline   Reply With Quote
Old 05-24-2013, 01:05 PM   #2393
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
I also got contacted by magnaflow
For a axle back
And stromung
Old 05-24-2013, 01:12 PM   #2394
myrt1987
Member#: 323103
2012 Limited 2.0i
All these shops are in CA boooo
Old 05-24-2013, 03:30 PM   #2395
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
Yeeeeah baby!!
Old 06-03-2013, 01:40 PM   #2396
garamas
Member#: 169194
04 STI
Car is at tanabe for springs and "chasis parts"
It was supposed to get an exhaust as well but when I showed him the rear bumper he said the R&D guys would have to see if they would even want to develop an exhaust that would need modification to the rear bumper
garamas is offline   Reply With Quote
Old 06-03-2013, 07:02 PM   #2397
solistik
Member#: 345948
Thanks man, I appreciate it.
Originally Posted by sgoldste01 View Post
^^ Nice wheels.
Yeah, I didn't really want to slam it nor do I plan on doing so. But since I just got some 245's this weekend, I'll probably roll my fenders because I'm not sure if the fronts will clear. If I do roll the fenders, I might lower it a bit more to eliminate the wheel gap completely but we'll see. The current ride height is pretty functional.
They are the 2011+ WRX wheels.
Old 06-03-2013, 09:37 PM   #2398
Dijm8
Member#: 337144
2012 Impreza Hatch
Ice Silver
finally have bought a set of coilovers for my hatch, from Cusco should have them in a couple weeks time, then i can finally put my wheels on
Dijm8 is offline   Reply With Quote
Old 06-04-2013, 07:01 PM   #2399
ronjr8102
Member#: 216040
dark metallic grey
Lucky u. Good luck and keep us updated.
Old 06-06-2013, 04:15 PM   #2400
Kyle Paton
Member#: 1184
2012 Impreza
Dark Grey Metallic
The Subimods harness plugs into the horn on the passenger side, not the one in the front of the car with the ambient temp probe attached to it.
Kyle Paton is offline   Reply With Quote
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
