Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC > MWSOC Vendor Classifieds
Old 01-11-2012, 04:54 PM   #1
JBAutosports
Vendor Sales Rating: (6)
Member#: 304709
Default JB Autosports - KW / COBB / Perrin / AMR / Cosworth / Invidia / Grimmspeed and more.
JB Autosports is located here in the heart of the midwest, Des Moines, IA. We are an authorized dealer for over 300 product lines and are herr to provide you with the best customer service around. Be sure to check out our feedback thread and give us a shot. We will not disappoint!
Looking to get faster on track? How about that extra low ride and stance that can only be attained with coilovers? JB Autosports carries over 300 lines of products for which we are an authorized dealer and has you covered on the coilover front! We also carry the entire line of famous Whiteline products!PM us for the special NASIOC Forums price and visit our website to see everything we have to offer.
AUTHORIZED DEALER FOR OVER 300 PRODUCT LINES
Like us on Facebook for Facebook only specials!
Our NASIOC Feedback Thread
KW Variant 3 Coilovers - We have the best Price around!
KW Variant 3 Coilover System is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers
Fortune Auto
These are a great option for the budget minded racer. They are rebuild-able right here in the USA and all options offer custom spring rates and valving. Track Tested!
Click the images to learn more:
500 Series
510 Series
DREADNOUGHT© Inverted Coilovers
Eibach Coilovers
These state-of-the-art, race-ready, damping-adjustable coil-overs use a monotube damper design for maximum track performance. Ride height is infinitely adjustable between 0.80” – 2.5” lower than stock, and the dual-spring setup is dialed for maximum cornering performance. Rebound and compression damping are both adjusted-ensuring proper damping balance at any setting.
Multi Pro R2 or R1
KSport Coilovers
Ksport Version RR Damper System is built specifically for road racing only. Aggressive rates and valving are chosen for maximum handling and performance with acute reaction and responsiveness. Integrated with 36 levels of dampening adjustment, simultaneous compression and rebound adjustment, lightweight aluminum mounts, and pillow ball upper mounts on some applications.
Kontrol Pro Kit
Key Features
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
One Year Limited Warranty
Click the image to learn more:
Kontrol Pro
Stance Coilovers
The GR+ is the Stance flagship line. It features 15-way damping adjustable monotube shocks, which allows the driver to fine-tune the handling and ride. A separate lower bracket allows the ride height to be adjusted without sacrificing stroke. Spherical bearings are used to give the driver greater feedback. Inverted monotube shocks are utilized on strut types for greater rigidity and heat dissipation. Camber adjustable upper mounts are used on strut types.
Stance GR+
Don't see something listed? PM us!!
__________________
[B]E-Mail:[/B]
(best way to contact) [B]
Phone:[/B] 515-984-0068
[B]SPECIAL PRICING VIA PM[/B] (This is your best bet for killer deals!)
[B][SIZE="3"]AUTHORIZED DEALER FOR OVER 300 PRODUCT LINES[/SIZE][/B]
JBAutosports is offline   Reply With Quote
Old 01-11-2012, 04:54 PM   #2
JBAutosports
Member#: 304709
This is old news for most, but for those who have not heard of Whiteline, the brand graces a number performance suspension components that work hard to deliver real results and performance outcomes for vehicles and motorists the world over.
Whiteline’s primary focus was initially delivering ‘bang for your buck’ handling gains from the simplicity of an anti sway bar. But over the years, the expertise, the knowledge, the reputation and the products have grown since progressed to include additional offerings such as the range of infamous anti lift/caster kits, roll centre adjuster kits, adjustable control arms, camber kits, strut and chassis bracing.
Adjustable Front or Rear Sway Bars
The Whiteline Flat Out ADJUSTABLE solid steel Sway Bars are a great addition to any Subaru to help conquer mid-corner understeer. The kits include high performance polyurethane sway bar bushings.
End Links Front or Rear Heavy Duty
Bump Steer Kit
Anti Lift Kit
Rear Camber/Toe Correction Arms
Lateral Lock Kits
Chassis Braces
With regards to undercar chassis bracing, Whiteline engineers have tested and identified up to 15mm body flex on late model vehicles under moderate acceleration, braking and cornering loads. Chassis bracing maintains alignment angles and spring rates by greatly reducing body or chassis flex.
PM us for the special NASIOC Forums price or check out through our website.
__________________
[B]E-Mail:[/B]
Old 01-11-2012, 04:55 PM   #3
JBAutosports
Member#: 304709
Tons of great options available to get some extra grunt out of your Subaru. JB Autosports carries over 300 lines of products for which we are an authorized dealer.PM us for the special NASIOC Forums price and visit our website to see everything we have to offer.
Cosworth
Cosworth leverages its successful motor sport pedigree, performance technology expertise and globally recognised brand to provide high quality engineered solutions for a growing customer base across diverse industries.
Cosworth - Rods - Pistons - Oil Pans - Pistons and more.
Cobb
COBB Tuning is an automotive engineering company dedicated to providing professionally engineered, thoroughly tested solutions and components that improve your vehicle’s performance, and your driving experience..
Cobb - AccessPORTS - Downpipes - Up Pipes - Exhausts - Intakes and more.
Invidia
Invidia - Manifolds - Downpipes - Up Pipes - Exhausts and more.
Perrin
From exhaust systems, to full turbo upgrades to even something simple like an antenna mast, PERRIN has you’re needs met.PERRIN has been a pioneer and market leader in the performance aftermarket since ots inception more than 10 years ago. Using the finest materials and labor, found here in the United States, you are assured that PERRIN stands for quality and value.
Perrin - Control Arms - Downpipes - Up Pipes - Exhausts - Intakes - End Links - Intercoolers - Sway Bars - Heat Sheilds and more.
GrimmSpeed
GrimmSpeed’s objective is to provide you and your car a high quality product that is at a competitive price while delivering it to you in an ethical and honest way..
GrimmSpeed - EWG Kits - Crank Pullys - EBC's - Air/Oil Seperator - HiFlow Crosspipe - Internal Wastegate Bracket - Paint - Heat Sheilds and more.
Brian Crower
Brian Crower, Inc. was created to fill the need for high quality, high performance, late model internal engine components, in stock, at very affordable prices. Stroker kits for all popular Sport Compact applications and camshafts and valve train to match. Complete packages designed to work together to deliver more horsepower and torque as well as greater reliability.
Brain Crower- Cams - Bearings - Cranks - Rods - Valves - Springs and more
AMR
Dont like stock? Who does! Wanting more is what sends your car from a stock level daily driver to a 10 sec power pushing beast!!!! Take a look at what we got in store for you!
AMR- Manifolds/Header - Intercoolers - Inlets - Up Pipes - Intakes and more
Wiseco
Wiseco sport compact pistons are forged and machined in-house and receive a full compliment of power enhancing features. Light weight forgings, millimeter ring packs, extra-strength forgings, gas ports, skirt coatings, offset pins, and a variety of other features are available to insure each engine exceeds our customer’s expectations. Optimized skirt profiles minimize rock and provide long skirt life in stroker applications.
Wiseco - Pistons - Mahle, ACL, and other bearing MFG's available also for builds.
Cusco
The CUSCO brand offers parts thoroughly researched and developed for those who prefer the authentic items.
Cusco - Motor Mounts - Clutch , LSD , and more.
PM us for anything you may need and check our feedback. We are here to serve you! Thank you.
__________________
[B]E-Mail:[/B]
Old 01-11-2012, 04:55 PM   #4
JBAutosports
Member#: 304709
The CobbAccess Port for the WRX/STI is a very affordable way to unlock some extra horsepower from your Subi even in stock form. These units are in stock ready to ship free of charge overnight or UPS ground.PM us for the special NASIOC Forums price.
The AccessPORT by COBB Tuning, Inc. is a handheld programmer that allows you to unlock your vehicle's hidden potential by reprogramming the stock Engine Control Unit (ECU).
With a short and guided installation process you can upgrade the ECU in your car from stock to one of our performance oriented tuning maps. The unit uses the OBD-2 diagnostic port, and requires no cutting, wiring, or other such modifications, simply plug-and-play.
The crowning function of the AccessPORT is COBB's unique 'Real-Time' mapping, which allows you to change the tuning data within seconds, as opposed to minutes. Simply park, switch realtime, and resume driving, it's literally that easy.
Using our off-the-shelf staged maps, the AccessPORT can unlock the potential of your vehicle by as much as 50hp, and more based on further modifications. The possibilities are endless since the AccessPORT is a short ProTUNE away from giving your car even more potential from the staged maps.
The AccessPORT's features include:
» On-the-fly map switching
» Monitor vehicle sensor data and display in analog or digital format
» Vibrant color graphic display with First-Ever full 260,000 color OLED, high-resolution screen
» Read/Clear engine trouble codes
» Preloaded with performance, economy and convenience maps
» Update via the Internet
» Measure 0-60 and ¼ mile times
» Adjustable on-screen Shift Light functionality
» Estimates horsepower and torque
» Displays current and averaged fuel economy
» Drag race simulation with reaction time and “time slip” data
» Built in on-screen help mode function
» Multi-Language support
» RoHS compliant (Lead Free design)
» Custom performance tuning for your specific vehicle and modifications as provided by an
authorized AccessTUNER Pro™ center, or upgrade to the AccessTUNER Race™
software package for do-it-yourself tuning
AP-SUB-002 Subaru Forester XT 2004-06 2.5
AP-SUB-001 Subaru WRX 2002-05 2.0
AP-SUB-002 Subaru WRX 2006-07 2.5
AP-SUB-003 Subaru WRX 2008 ; **MT Only**
AP-SUB-002 Subaru WRX STi 2004-07 2.5
Free Overnight Shipping! PM for SALE PRICE
__________________
[B]E-Mail:[/B]
Old 01-11-2012, 07:48 PM   #5
JBAutosports
Member#: 304709
DeatschWerks is proud to announce their drop in fuel pump for the 08+ STI and 05-09 Legacy. This pump is a direct fit and drop in for your factory pump assemblies. No cutting required.
PM us for the special price. Stock is very limited!
DW65C
__________________
[B]E-Mail:[/B]
Old 01-13-2012, 10:51 PM   #6
JBAutosports
Member#: 304709
Have a great weekend guys! We'll be available like always via e-mail or PM.
__________________
[B]E-Mail:[/B]
Old 01-18-2012, 06:03 PM   #7
JBAutosports
Member#: 304709
Shoot us a PM on anything you may need. Over 300 product lines available and some of the best pricing around!
__________________
[B]E-Mail:[/B]
Old 01-20-2012, 12:59 PM   #8
JBAutosports
Member#: 304709
Happy Friday!
__________________
[B]E-Mail:[/B]
Old 01-24-2012, 10:00 PM   #9
JBAutosports
Member#: 304709
To the top for tonight.
__________________
[B]E-Mail:[/B]
Old 01-28-2012, 10:17 AM   #10
JBAutosports
Member#: 304709
__________________
[B]E-Mail:[/B]
Old 01-31-2012, 02:25 AM   #11
doubleUareX2011
Member Sales Rating: (8)
Member#: 292096
2011 WRX Sedan
Dark Grey Sexiness!
I pmd...
doubleUareX2011 is offline   Reply With Quote
Old 02-02-2012, 07:02 AM   #12
JBAutosports
Member#: 304709
Replied.
__________________
[B]E-Mail:[/B]
Old 02-03-2012, 08:42 PM   #13
JBAutosports
Member#: 304709
Have a great weekend guys. As usual we are available via PM or e-mail.
__________________
[B]E-Mail:[/B]
Old 02-07-2012, 09:03 PM   #14
JBAutosports
Member#: 304709
Wicked Deals on Comp Clutch, Fortune Auto, Ksport and more!
__________________
[B]E-Mail:[/B]
Old 02-11-2012, 11:53 PM   #15
JBAutosports
Member#: 304709
Valentines Day is around the corner. No shame in asking for some car parts from us as a gift...
__________________
[B]E-Mail:[/B]
Old 02-13-2012, 09:38 PM   #16
JBAutosports
Member#: 304709
Order on Valentines day and We'll send you some chocolates! lol
__________________
[B]E-Mail:[/B]
Old 02-15-2012, 07:01 AM   #17
JBAutosports
Member#: 304709
Fortune Auto, Ksport, ACT, Comp Clutch and more available!
__________________
[B]E-Mail:[/B]
Old 02-19-2012, 10:49 AM   #18
JBAutosports
Member#: 304709
Lots of great Subi parts in stock!
__________________
[B]E-Mail:[/B]
Old 02-23-2012, 12:04 PM   #19
JBAutosports
Member#: 304709
Deatschwerks Injectors and Fuel Pumps in stock!
__________________
[B]E-Mail:[/B]
Old 02-25-2012, 05:41 PM   #20
JBAutosports
Member#: 304709
Have a great weekend guys. Feel free to PM or e-mail us.
__________________
[B]E-Mail:[/B]
Old 02-28-2012, 10:20 PM   #21
JBAutosports
Member#: 304709
Lots of PM's and good questions. We are here to help answer questions and fit you with the best parts for your application.
__________________
[B]E-Mail:[/B]
Old 03-02-2012, 12:04 PM   #22
JBAutosports
Member#: 304709
Friday bump!! Thanks guys.
__________________
[B]E-Mail:[/B]
Old 03-05-2012, 08:09 PM   #23
JBAutosports
Member#: 304709
Back at it on Monday. PM US for anything you need.
__________________
[B]E-Mail:[/B]
Old 03-07-2012, 09:53 AM   #24
JBAutosports
Member#: 304709
Don't forget about all the other great items we have!
__________________
[B]E-Mail:[/B]
Old 03-10-2012, 08:45 AM   #25
JBAutosports
Member#: 304709
__________________
[B]E-Mail:[/B]
JB Autosports - Cosworth / COBB / Invidia / Perrin / GrimmSpeed / BC / AMR / Wiseco JBAutosports Engine/Power/Exhaust 84 05-12-2012 11:09 PM
TurboXS Huge Clearance**Cobb**DW Injectors**Perrin**Invidia**Walbro**And More!! Spun Autosports Engine/Power/Exhaust 111 11-23-2011 08:22 AM
