Closed Thread
Old 01-12-2012, 09:44 AM   #101
Thunderburn
Member#: 287149
2008 Wrx Sti
Originally Posted by HoboBob View Post
Hella-Flush that **** down the toilet
Thunderburn is offline
Old 01-12-2012, 10:03 AM   #102
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
In for more horrible photoshops errrrrrr ms paints!
iconone is offline
Old 01-12-2012, 10:04 AM   #103
LEGITWRX
Member#: 255816
2006 Subaru WRX WRB
omgwtfbbq
OP since you are planning on rallying it you should do an F150 front end and do a prerunner!!!! It would be sooooo easy 4 welds and 3 bolts max, I'm sure it fits in your $10k budget with enough money left over for mad decals!!!!! Could you photoshop that for me please!!!! kthx
LEGITWRX is offline
Old 01-12-2012, 10:12 AM   #104
mejifair
Member#: 11356
2012 WRX STi Hatch
Actually - the OP has a pretty good idea. Take the rear wheel drive train of a Toyota and marry it with the Boxer engine of a Subaru.
Wait a minute!!!!!
mejifair is offline
Old 01-12-2012, 10:52 AM   #105
Decipher
Member#: 262760
2011 WRX Hatch Limtd
Satin White Pearl
What the hell do you mean, BRoZeph?
Decipher is offline
Old 01-12-2012, 11:04 AM   #106
manticus
Member#: 162857
I have to say, I haven't laughed this hard in a long time. Everything about this thread is win.
Only thing missing is a ute back end on an STI front. That will be key to sell in the Aussie market. Background should show this beast on top of Ayers Rock
manticus is offline
Old 01-12-2012, 11:04 AM   #107
James2.5i
Member#: 305063
2016 VDUBBB
Thank you. This made the internet fun again.
James2.5i is offline
Old 01-12-2012, 11:21 AM   #108
NcKidd
Member#: 133267
2004 psm WRX
Originally Posted by samb View Post
i could probly make that work but i dont know about putting a rotary engine in a subaru i think they were meant for a boxter or at least something with more than 2 liters.
That ugly car shouldnt be parked on the track like that, everyone knows thats dangerous for ugly cars
NcKidd is offline
Old 01-12-2012, 11:24 AM   #109
liv4psi
Member#: 206505
'04 STI
JBP, 360whp 355tq @18psi
Originally Posted by markman
hey liv4psi clear your PMs
EDIT: nevermind I'll post it here. liv4psi attempted to school me on rotaries via PM:
I tried to reply by PM but his box is full so I guess he can read this here, I don't really care...
_______________________
I used to drive an FC. Do you really want to go there? Fine. Here we go:
Wrong. Rotary engines are 4-stroke engines. And not all piston engines are four stroke.
The link you sent me proves you wrong. You are partially correct in that similar to many 2-stroke engines (ironically, ones that don't need premixing), rotaries utilize oil injection as part of their lubrication system. The statement "You have to premix oil with the gas" is WRONG.
Pre-mix means that you have to manually mix the oil in with the gas before you put it in the tank, or keep track of how much gas you put in and manually add oil accordingly. Rotary engines use oil injection so YOU DO NOT HAVE TO PREMIX. It post-mixes it through injection.
Some people don't trust the built in lubrication system and choose to pre-mix it instead, but this is not required (as you implied by your statement) and is therefore besides the point.
But thanks for fixing my ignorance
____________
end transmission
My PM box isn't full? I had to empty some out to PM you, and I did. I was patiently waiting your response. We can talk here though
Edit: it as full, I had a late night PM asking me what QFT stood for and I responded. I tried to make room for your response.
I'm only remotely wrong because you are splitting hairs. Rotaries are not four stroke engines, they aren't two stroke engines either, those refer to piston engines. I said rotaries are analogous to a 2 stroke piston engine, which they are. Pistons go up and down twice to achieve the intake, compression, combustion and exhaust, so 4 strokes. Rotors only spin around once per cycle, making them LIKE a 2 stroke. Obviously I know some piston engines are 2 stroke, I mentioned dirtbikes. No regular CAR has a 2 stroke piston engine, all are 4 stoke. That is what I meant. Seemed obvious to me.
The oiling system (oil metering pump) accomplishes the same thing as premixing. I understand that if you keep the OMP, there isn't a need for premix. If you delete it, there is. I mentioned it since there is no such system or prodecure similar on 4 stroke piston engines.
Its a Subaru forum, there was no need to get any more technical than I did. I was just intentionally feeding the trolls.
Don't come in here all mad because I knew about your thread in OT making fun of us, and played along. I even posted a reply to you there about the oil metering pump, last night.
liv4psi is offline
Old 01-12-2012, 11:27 AM   #110
mejifair
Member#: 11356
2012 WRX STi Hatch
I'm only remotely wrong because you are splitting hairs. Rotaries are not four stroke engines, they aren't two stroke engines either, those refer to piston engines. I said rotaries are analogous to a 2 stroke piston engine. Obviously I know some piston engines are 2 stroke, I mentioned dirtbikes. No regular CAR has a 2 stroke piston engine, all are 4 stoke. That is what I meant.
Its a Subaru forum, there was no need to get any more techical than I did. I was just intentionally feeding the trolls.
Don't come in here all mad because I knew about your thread making fun of us, and played along.
Win X1000
mejifair is offline
Old 01-12-2012, 11:29 AM   #111
akatypes
Member#: 293267
2012 WRX
akatypes is offline
Old 01-12-2012, 11:33 AM   #112
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
Ya that car looks pretty bad.
DSRX2005 is offline
Old 01-12-2012, 11:36 AM   #113
jiGGypiGGy
Member#: 271097
2014 Evo Gsr
wicked white
jiGGypiGGy is offline
Old 01-12-2012, 11:37 AM   #114
liv4psi
Member#: 206505
'04 STI
Originally Posted by akatypes View Post
Check out their OT thread that went hand in hand with this one. The fun starts are few pages back. They weren't impressed I knew I about it.
http://forums.nasioc.com/forums/show....php?t=2295107
liv4psi is offline
Old 01-12-2012, 12:17 PM   #115
jessetm
Member#: 228956
'15 ISM STi
07 WRX on e85-sold
ICWUTUDIDTHERE
jessetm is offline
Old 01-12-2012, 12:27 PM   #116
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
I was impressed.. you tracked us down through accounts on the same website.. didn't know you had it in you.
Calamity Jesus is offline
Old 01-12-2012, 12:31 PM   #117
liv4psi
Member#: 206505
'04 STI
My apologies, impressed was a poor choice of words. I should have said "They were surprised I was intelligent enough to find it"
You guys gave way too many clues for my detective work to be impressive. Especially, as you mentioned, since I didn't have to leave Nasioc.
liv4psi is offline
Old 01-12-2012, 01:32 PM   #118
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
boxer? oh ok but i thought it was the same engine from the boxter i guess you learn something new every day dont you.
i really hope you do, man, i really hope you do
Nimbus09 is offline
Old 01-12-2012, 01:32 PM   #119
Nismonic
Member#: 162500
2011 LR WRX
What about the Saab 92, 93, and early 93's and Sonetts? They had 2-stroke motors... are those not regular cars? There's also a few eastern european cars like the Trablant that had 2-strokes too...
2nd gen RX7 (FC) was a 13b engine. It was a 1.3l that came turbo and NA. There are 4 port and 6 port intake designs. Turbo makes approx 230hp stock.
FCs never had 230hp stock. 6 port NA motors were 145-160hp depending on the series and the 4 port turbo motors came in at 180-202hp depending on the series. There was a limited edition called the Infini for the Japanese market that made a little more power... but you couldn't get that one here.
Nismonic is offline
Old 01-12-2012, 01:41 PM   #120
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
man, y'all straight trippin boo
Nimbus09 is offline
Old 01-12-2012, 02:15 PM   #121
army medic
Member#: 200236
05 STi
Aspen
Quoted for straight awesome-ness.
It's been a while since a thread made me tear up in laughter. Bravo sir, Bravo.
army medic is offline
Old 01-12-2012, 02:29 PM   #122
samb
Member#: 177235
2012 Mustang
for you rx-7 lovers
im sorry about the low quality on this one guys i did it from my work computer so a little bit was lost in translation in case you cant tell thats a 04 sti front and and wing on an rx-7 at a super car track meet.
samb is offline
Old 01-12-2012, 02:32 PM   #123
markman
Member#: 93623
blahblah
http://auto.howstuffworks.com/rotary-engine4.htm
markman is offline
Old 01-12-2012, 02:52 PM   #124
liv4psi
Member#: 206505
'04 STI
Okay, so there are a few random exceptions that are 2 strokes. They are RANDOM exceptions.
I said approx. on the FC hp, I definately gave it too much credit. Thanks for the correction. I have only owned FDs
liv4psi is offline
Old 01-12-2012, 02:53 PM   #125
liv4psi
Member#: 206505
'04 STI
Thank you for the link. This should clear everything up for me.
Nothing in that link will disprove anything I've posted. That's why you just quoted me saying "blahblah" as opposed to making actual corrections to my "facts".
I actually enjoy learning and like to be shown when I'm wrong. Then I'm not wrong the next time. You should give this philosophy a try
liv4psi is offline
Closed Thread
FS : Il. Toyota Supra 1993.5 Automatic Targa "TT" (single conversion) DoctorNick Private Vehicle 'For Sale' Classifieds 19 07-06-2012 11:41 PM
FS : OH: '88 Supra 2JZ-GTE, single turbo - PRICE DROP $7k, BEST Supra deal online!! WrxRonald Private Vehicle 'For Sale' Classifieds 71 01-22-2011 07:16 PM
WRX+STI+STi+supra+abandoned camp=pic thread chu my pu Member's Car Gallery 92 07-03-2008 05:52 PM
New Toyota SUPRA SUPRA SUPRA! Dan_E Off-Topic 29 11-18-2002 08:49 PM
PE1820, sti injectors, supra fuel pump and turboxs unichip install nmyeti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 43 10-31-2001 11:10 AM
