Welcome to the North American Subaru Impreza Owners Club Saturday September 20, 2014
Old 01-12-2012, 04:53 PM   #1
mdelg035
Member#: 290433
2011 WRX
Default 2011 WRX coolant question
Hey guys what's up. I've had my subie for almost 10k miles and last week I had to put coolant fluid because it was under low. Then when I went and checked today I had it almost at low and the engine was cold. I have Cobb stage 2 + sf, dp, cat back and sf intake. Has this happened to anyone. My car is running perfect but idk why the coolant is goin down so quick. Maybe it's normal?
Sorry if I posted this thread in the wrong place
mdelg035 is offline   Reply With Quote
Old 01-12-2012, 04:57 PM   #2
04caliwrx
Member#: 157842
2004 wrx
I know on my Honda when I had to replace my head gasket I had coolant getting used like crazy
04caliwrx is offline   Reply With Quote
Old 01-12-2012, 05:09 PM   #3
mdelg035
Member#: 290433
2011 WRX
oh crap .. I hope that's not the case man
Old 01-12-2012, 06:28 PM   #4
donkey_cart
Member#: 151448
2005 Forester XT 5MT
Tall wagon
My car was low too. The expansion tank on top of the motor was half-empty and the bottle was below the low mark. I filled both with distilled water and its been fine since. (do this while engine is cold)
Bubbles in the system from factory fill?
Also check that the little return hose in the bottle is not bottomed out - pull it up 1-2mm to make sure. This will allow the coolant to flow better during expansion and contraction.
donkey_cart is offline   Reply With Quote
Old 01-12-2012, 06:36 PM   #5
mdelg035
Member#: 290433
2011 WRX
Thanks for that dude ... but what I did was that I bought the subaru coolant for my car and I filled it to full while the engine was cold .. and I didnt find any bubbles in the system at all ... im gonna check the hose but I doubt its that
whats the difference of using water and the actual coolant? This might sound stupid but, does coolant evaporate for the engine being too hot? you think its not leaking to somewhere else in the engine?
Sorry for all the questions but I'm freaking out lol
thanks for the answers
Old 01-12-2012, 07:55 PM   #6
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Your cooling system is sealed, except for the opening in your expansion tank. Only 2 things can be happening. 1. You are leaking fluid somewhere. Check under your car after driving. 2. You are burning it. (so to speak). It can't/won't evaporate. RP
drivin blind is offline   Reply With Quote
Old 01-12-2012, 08:01 PM   #7
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Is your car overheating? No. Stop worrying and thinking. I haven't checked my coolant since 2003.
Old 01-12-2012, 08:20 PM   #8
mdelg035
Member#: 290433
2011 WRX
I've checked under my car and I am not leaking. Just normal A/C water and I might be burning it .. how would I get that fixed?
Lol, no but I don't want to destroy my engine with just 9k miles (not that I want to destroy it at any mile range). Hopefully it doesn't happen anymore but I want to learn about my car and what is happening with it.
Old 01-12-2012, 08:40 PM   #9
GotWRX?
Member#: 254167
2011 WRX Sedan
SSM
This was something I noticed too, but I didnt worry about it too much since its just a reservoir tank and it wasnt completly empty. Dealersip topped it off when I was in.
GotWRX? is offline   Reply With Quote
Old 01-12-2012, 08:45 PM   #10
STOBURU
Member#: 278504
Yes!! This happened to me too. I have a 2011 as well with 9,800 miles on it. At around 4,000 miles, I noticed that the coolant level was low. I was really confused by this but I simply filled it back up, and it hasn't required any more coolant since....
STOBURU is offline   Reply With Quote
Old 01-12-2012, 08:48 PM   #11
bfedorov14
Member#: 208058
2005 WRB STi
EWG
Hows your overflow tank looking?
bfedorov14 is offline   Reply With Quote
Old 01-12-2012, 08:51 PM   #12
mdelg035
Member#: 290433
2011 WRX
Where is the overflow tank located?
STOBURU, what mods do you have done to your subie .. maybe it has something to do with the mods .. lmk!
Thanks guys
Old 01-13-2012, 06:46 PM   #13
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
I would think (hope) that as new as your car is that you are not burning it. I think you may have had a bubble in the system from the factory that just made it's self through the system. I would'nt worry about it. Just keep an eye on it. Check it when you check your oil. (you do keep an eye on your oil level as new as your car is don't you?) RP
Old 01-14-2012, 12:31 AM   #14
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
This would be one post from the expert that I'm going to have to disagree on.
Don't run it until it overheats.
I HAD THE EXACT SAME ISSUE. I went to autozone and tested both my radiator cap and turbo reservoir cap. Both were under spec, venting about 2psi too soon (the rad cap being worse). Replaced them and haven't had issues since.
Also, check the level every oil change. The system isn't completely sealed. You'll lose some gradually if repeatedly driving in heavy traffic on 90+ degree days.
Nimbus09 is offline   Reply With Quote
Old 01-14-2012, 04:07 PM   #15
mdelg035
Member#: 290433
2011 WRX
Thank you! I will definitely do that next week if I notice that the coolant went down again. Hopefully it is just a bubble but if its not then I'm doing this for sure! Thank again!
Old 01-19-2012, 06:45 PM   #16
mdelg035
Member#: 290433
2011 WRX
Hey guys just wanted to update you on the problem I had. It seems like it was a bubble that I had because after I filled it up last time the coolant level has not changed. I drove normally and I even floored it a couple of times.
Thanks for all the help!
Old 01-20-2012, 09:47 PM   #17
wrxman02
Member#: 24162
2014 Legacy 2.5i
2012 Impreza 2.0i
a lot of times when the vehicle was built had air pocket and now its cold you had heat on full hot and it burped the air bubble and drank some coolant from resivoir. no issues. top it off and stop worrying. be safe. have fun. happy boosting.
wrxman02 is offline   Reply With Quote
Old 01-21-2012, 08:15 PM   #18
flash02
Member#: 78916
I can't believe someone who seems to have a lot of knowledge on these cars has not checked his coolant since 2003, preventive maintenance is checking your fluids, plus like oil coolant brakes down, can't hurt to refresh it every 3 years.
flash02 is offline   Reply With Quote
2011 WRX shifting question snookey318 Newbies & FAQs 15 02-15-2012 09:03 PM
2011 WRX Bluetooth questions cwapface Car Audio, Video & Security 5 12-09-2011 12:02 PM
2011 WRX Intake Question 2011_Black_WRX General Community 94 07-15-2011 10:05 PM
2011 WRX Sedan Question 2011_Black_WRX Interior & Exterior Modification 3 03-30-2011 11:34 PM
2011 WRX Stereo Questions TheRedWRX Car Audio, Video & Security 4 03-13-2011 05:22 PM
