#1 |
Member#: 294644
Vehicle:2011 WRX Agile Auto DGM 290.5whp 331wtq |
So Im really new to this and I tried out my tactrix cable today for the first time was only going to read from the ecu. Well after I read from the ecu it worked but ecuflash couldnt read it. So i said ill go inside and check it out after I restart the car and make sure it works. Well it took like 10 seconds for the car to turn over and finally start and then it ran different. I runs fine but its more torque is how ill describe it. So i drove it for like 3 miles to make sure it was good and it was ok but just seemed to be a little more jerky. After going inside i realized i was using the beta version of the ecuflash so i got that fixed. But i was just wondering do you think i did something to the car? Sorry for the long thread just kind worried.
#2 | |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
After a write, the ECU needs a few seconds to 'boot up' before the motor can start. It sounds like you ran into that, but it's no big deal. 9 out of 10 new tuners spend a few seconds thinking they've bricked their ECU after that first flash. Myself included. |
#3 |
Member#: 294644
no i read the stock image, then ecuflash couldnt read it. I tried reopening it after i read the stock image to make sure it worked. i think i just reset the ecu
#4 |
Member#: 267815
South East
Vehicle:EVO Woudve been Cheaper!!!!! |
The ecuflash Beta version is the shizzle!!! I can actually read the bottom of the MAF table now lol Its a little improved as far as displaying tables. I didnt notice a whole lot of difference overall.
#5 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
the difference you're feeling is because you reset all of the AF trims and the fine learning knock correction table and the IAM.
The only reason ecuflash wont open a file is if you dont have the proper definition for it.....since you have a 2011 WRX you have to go to romraider and download your definition separately and add it to the rommetadata/subaru/impreza wrx folder manually. http://www.romraider.com/forum/viewt...hp?f=34&t=6639 |
#6 |
Member#: 287161
SCIC
Vehicle:2011 WRX 5dr Black |
The last batch of 2011 WRXs apparently have a slightly different definition file, which is probably why ECUFlash can't read it. Unless you didn't add in the definitions to begin with. Did you get a window that gave three options (something like Cancel, Save anyway, or Create definition)? Same happened to me. I was instructed to just save the file, and there will be an updated definition for the new ECU version soon. All it means is I can't flash back to stock without it.
| Thread Tools | |
| Display Modes | |
| ecuflash - stuck at read from ecu | black thunder | Open Source Reflashes | 1 | 04-22-2010 04:16 PM |
| Cant Read from ECU | Jakkim | Engine Management & Tuning | 6 | 03-08-2010 03:42 PM |
| 2003 wrx cant read from ecu | matthewhiggins118 | Open Source Reflashes | 16 | 05-15-2009 10:08 PM |
| Voltage readings from ecu? | Onederer | Factory 2.0L Turbo Powertrain | 1 | 06-25-2002 06:12 PM |
