Old 01-13-2012, 01:57 AM   #1
FourScene
Member#: 304366
2010 WRX Limited
Spark Silver Metallic
Default OTS Stage 2 + CBE only
Just installed my AP and I'm running Stage 1 93oct map right now.. About to order my catted Invidia down pipe online. I have the Invidia N1 street cat back right now, no other mods.
Is it harmful to run the Stage 2 93oct map if I don't have the downpipe just yet?
I know Cobb suggests TBE and no other mods for this map.. I was wondering if anyone has run it with the OEM down pipe.
Car will be tuned once I order my EBCS and EWG up pipe.. But until then, I'm curious.
FourScene is offline   Reply With Quote
Old 01-13-2012, 02:11 AM   #2
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
Personally I would stick with the STG 1 map until you get a downpipe. The DP is really the most restrictive section of the exhaust so it's the most important piece when stepping up to STG 2, cat backs are mostly just for sound.
Just my opinion
danny_d19 is offline   Reply With Quote
Old 01-13-2012, 10:50 AM   #3
Cobb Tuning
Member#: 4803
Do not run the stage 2 map until you have the downpipe installed. There's no reason to run it now anyway, since reflashing the map when you do finally have it installed is only going to take a matter of minutes.
Bill
Cobb Tuning is online now   Reply With Quote
Old 01-13-2012, 04:57 PM   #4
FourScene
Member#: 304366
2010 WRX Limited
That's what I figured but I wanted to clear it up.. I'll be skipping the OTS maps all together once I get everything installed.
Thanks!
Old 01-14-2012, 11:23 AM   #5
Cobb Tuning
Member#: 4803
Thanks!
Well, you just want the correct map on the car for the mods that are installed. If you are getting a custom tune and the parts you are installing are not supported by the stage 2 map (the EBCS and EWG in your case), then you'll want them to send you a limp map to install just to get you to the tuner.
Bill
Old 01-17-2012, 10:54 PM   #6
Screwbal
Member#: 196946
2007 Wrx limited WRB
07 FXT WRB,'15 model S
I don't want to try it just to see what happens... If someone flashed the stg 2 map with just the cbe would the result be heavy over boosting? Just curious
Screwbal is offline   Reply With Quote
Old 01-18-2012, 11:50 AM   #7
speedbagger
Member#: 289736
2016 WRX Base
bill--is there any plan to add additional features to your stage2 tunes (ie. ebcs or ewg)?
thanks for your support.
speedbagger is offline   Reply With Quote
Old 01-18-2012, 02:34 PM   #8
Cobb Tuning
Member#: 4803
Not currently - that stuff is best left to be custom calibrated for the car in question.
Bill
free OTS stage 2 map? tydawg2 Open Source Reflashes 6 07-17-2008 08:14 PM
Cobb OTS Stage 2 map with an APS 65mm CAI? GuammyBear AccessPort 0 05-02-2008 06:56 PM
Will OTS Stage 2 support this? 05_WRX AccessPort 11 08-02-2007 04:31 PM
Can a SPT intake cause issues with an OTS stage 2 map? "B" Engine Management & Tuning 1 05-03-2007 12:43 AM
datalog 06 WRX Cobb OTS Stage 2 EnterTheDragon AccessPort 8 10-08-2006 08:50 PM
