Old 01-13-2012, 03:24 PM   #1
MDRSK
Member#: 226510
2001 Legacy GT
Default Differential Thud?
Trouble with trying to use the search function for something is you have to know how to describe it in a way that others would have described it...
Here is something close to what I am experiencing: http://forums.nasioc.com/forums/showthread.php?t=116310
Only difference is that it is not when I remove foot from the clutch (although that does happen sometimes), but it happens simply from taking the foot of the gas pedal quickly, i.e. deceleration. These thuds which seem to be coming from the differential do not happen all the time but happen fairly regularly. Any ideas?
I will be taking the car to the dealer on Monday for an oil change. I am the original owner of a 2001 Legacy and it is just at 198K miles. So I do not think it is my driving style as I have been driving manual transmission cars for the past 30 years and this car exclusively for the past 10+.
Just started happening since summer... Coinicidentally around the same time I started teaching my son how to drive a manual. I do not think he did anything too terribly wrong other than reving too high on inclines to avoid stalling.
Any assistance is greatly appreciated.
MDRSK is offline   Reply With Quote
Old 01-13-2012, 11:46 PM   #2
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
This one
ANNDDDDD
This one here
Read both of those. See if any of that helps a little.
Frogsthatmoo is offline   Reply With Quote
Old 01-14-2012, 06:35 AM   #3
MDRSK
Member#: 226510
2001 Legacy GT
Thanks, Frogs. Most of the scenarios are not exactly the same, although JLaw3000's description is pretty close. But I get the connection you picked up on. I actually was thinking motor mounts initially, but when my son indicated that he felt the thud in the rear and suggested the rear differential I started directing my attention in that area.
I did not realize that there were rubber mounts for the rear diff and will check them out (or more likely as the dealer to check them out). I am happy that my Legacy GT has the rear diff LSD, but wonder if the thump may be more pronounced than if I had a regular open diff?
Anyway, your analysis makes the most sense to me and with almost 200K miles that seems like a likely reason. Any idea how much dealer will charge to swap out the mounts? Thanks again.
Old 01-14-2012, 11:43 AM   #4
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
You're welcome. I figured it was worth looking at the mounts before breaking open a diff. Also, I doubt the LSD has any part in the noise.
A dealer would probably be in the range of a couple hundred bucks. The mounts themselves are really cheap, but labor may be like 2 hours. If you have a local indie mechanic that you know of, I'm sure they'd be more than willing to put the car in the air and check out some of the mounts. Or you could even try having the dealer do it for free.
Old 01-14-2012, 07:35 PM   #5
Cervantes
Member#: 219252
2000 STi w/S203 swap
I'm about to replace a rear diff mount and my motor mounts. The issue I'm having is a thud in the rear when I get off the gas pedal. I had it looked at and the mechanic said it was the right rear diff mount. I'm thinking we have a similar issue.
Cervantes is offline   Reply With Quote
Old 01-15-2012, 05:54 AM   #6
MDRSK
Member#: 226510
2001 Legacy GT
Yes, that is exactly the issue. Maybe it is because I have the JDM tail lights and my car thinks it is a Blitzen too
Old 01-16-2012, 04:54 PM   #7
MDRSK
Member#: 226510
2001 Legacy GT
OK. Dropped off the car at the dealer today. Confirmed the differential mounts needed to be replaced. Trouble is they are quoting me 5.0 hours of labor. I said no way so I just ordered the parts (both sides + bolts for $60). Now I have to find a place that can install them once the parts come in. Anyone have an idea if this is possible DIY?
Old 01-16-2012, 05:16 PM   #8
GTP231
Member#: 144366
2010 Impreza Prem DG
16 Imp Sport Prem CW
If you're eastern shore I can give you a hand.
Something tells me this is my thud I've never really tried to hard to diag
GTP231 is offline   Reply With Quote
Old 01-16-2012, 08:55 PM   #9
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
It seems to be a very common problem among our cars. There are a lot of threads for our generation over on Outback.org. There's a couple how to's that I've seen floating around. It's mostly a DIY but maybe with a helping hand, some jack stands, and a big big wrench.
Do you a little searching around for replacing diff mounts on Subarus so you can get a feel for the work involved and then decide whether or not you want to tackle it.
Old 01-16-2012, 10:15 PM   #10
MDRSK
Member#: 226510
2001 Legacy GT
Thanks, GTP and again to Frogs. I will do some researching and will ask a local shop how much they would charge. BTW, I will also try to cancel my order from the dealer as subaruparts.com has those parts for sale for about $31 vice $60.
I am not on Eastern shore, btw. I am way down south in St. Mary's county.
Old 01-16-2012, 10:32 PM   #11
MDRSK
Member#: 226510
2001 Legacy GT
Looks like a pretty involved job requiring dropping the rear.
http://www.subaruoutback.org/forums/...acement-2.html
http://www.rs25.com/forums/f8/t98598...hing-help.html
Seems like a hooptie method would be to inject some window weld into the bushings as a temporary fix.
Rear differential ratios jkershaw Subaru Conversions 20 01-17-2012 06:11 AM
Installed Ver. 5 struts with 5Zigens springs, now have a weird thud? garface Brakes, Steering & Suspension 19 10-11-2001 09:16 PM
Loud thud when shifting under hard acceleration PhilG Normally Aspirated Powertrain 7 03-11-2001 04:26 PM
I changed my clutch and tranny and motor mounts now i have a drivetrain thud bill harvey Normally Aspirated Powertrain 5 03-03-2001 01:57 PM
Thud! meebs General Forum Archive 1 12-16-2000 09:16 AM
