Old 01-13-2012, 04:40 PM   #1
jollyblue84
Member#: 292300
01 GC8
blue
Ok so first what i have.2001 RS 2.5 body that is powered by a jdm 1995 sti motor with a 5spd tranny. I will start with 1 ? Then follow with more later. Main ? Parts. Were can I find parts for the motor?
jollyblue84 is offline   Reply With Quote
Old 01-13-2012, 04:55 PM   #2
kyleyap
Member#: 214088
1995 WRX Type RA
JDM YO!!
I believe you use an 02/03 wrx for parts
kyleyap is offline   Reply With Quote
Old 01-13-2012, 05:07 PM   #3
eg33GC
Member#: 206851
56 Belair
Pro Street
No.
Parts used are 1992-1996 WRX
eg33GC is offline   Reply With Quote
Old 01-13-2012, 08:37 PM   #4
RallyColtTurbo
Member#: 16819
What parts?
Some are available here in the states, some are OEM on USDM models, some are JDM/Euro only.
RallyColtTurbo is offline   Reply With Quote
Old 01-14-2012, 01:35 AM   #5
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
All parts around the engine (valve covers, timing belt etc) are identical to 1996 USDM EJ25D (not 1997-1998, just 1996), except for the water pump which is identical to USDM WRX/STI.
Marnix is offline   Reply With Quote
Old 01-15-2012, 11:34 AM   #6
jollyblue84
Member#: 292300
01 GC8
blue
Ok thanks fellas. What about the turbo? I that it should be a 16g. Correct or not? Also need an actuater for the turbo. Were can I get one?
Old 01-15-2012, 09:31 PM   #7
blessthekellen
Member#: 273859
MY98
WRX
Td05.
blessthekellen is offline   Reply With Quote
Old 01-16-2012, 12:07 PM   #8
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
The 95 sti I think is an EJ20K. Regarding what source parts from there is a parts thread stickied at the top.
TommyAtomic is offline   Reply With Quote
Old 01-16-2012, 02:23 PM   #9
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
JDM '95 is EJ20G...
You're confusing USDM Model Years w/ Japan. We always sell cars here as a year newer than they actually are.
omahasubaru is offline   Reply With Quote
Old 01-17-2012, 12:46 PM   #10
jollyblue84
Member#: 292300
01 GC8
blue
The engine stamp is EJ20 nothing more. Please don't burn me but what is a sticky exactly? All I see is an advertising bar.
Old 01-17-2012, 01:50 PM   #11
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Originally Posted by omahasubaru View Post
JDM '95 is EJ20G...
Crap thats right. My bad.
Old 01-17-2012, 03:21 PM   #12
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
Originally Posted by blessthekellen View Post
Td05.
I could have sworn the 95 was a TD04 16g. I could be wrong though, haven't pulled my turbo cooler off to look at mine yet.
Millhouse_5 is offline   Reply With Quote
Old 01-17-2012, 03:44 PM   #13
Aphex28
Member#: 11506
2015 WRX
td05 16g.
USDM 02-07 wrx has a td04 13t.
EJ20g wagon motors have td04.
Aphex28 is offline   Reply With Quote
Old 01-17-2012, 03:52 PM   #14
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
95 sedan or wagon? The sedan should be a TD05-16G the wagon is a TD04
Old 01-21-2012, 11:06 AM   #15
jollyblue84
Member#: 292300
01 GC8
blue
Can anyone tell me if 18psi in this motor is safe? It only has 45,000 miles. Looking to change the actuator and I have one set for 18psi. I'M ruining 15psi now. Thanks
Old 01-21-2012, 06:46 PM   #16
vic-gc8
Member#: 298909
1995 STi VII type-RA
White, on white wheels
jolly, if you want to run 18psi you need to be running robs 550 tune or something similar.
vic-gc8 is offline   Reply With Quote
Old 01-24-2012, 01:03 AM   #17
jollyblue84
Member#: 292300
01 GC8
blue
Tuning my car is a big issue. Being it's a jdm motor nobody can tune it. Will it not run proper?
Old 01-24-2012, 12:56 PM   #18
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Tuning is a big issue period. The JDM ecu's are fairly aggressive tunes to begin with. Turning up the boost will increase the likelihood of knock which will increase the likelihood of FAIL. Other then increasing boost are you doing any other supporting modifications to back that up?
Most of the usdm tuners will suggest going with a FMIC or a bigger tmic and an AOS if you want to go aggressive at higher boost. I have an AOS and feel in some cases I think the AOS is a good idea; in other cases I think it is not required and a lame excuse to buy shiny crap for your engine bay.
In any event an aggressive JDM ecu + more boost with no supporting mods doesnt seem like a well thought out plan. Just because you can crank up the boost doesnt mean its a good idea.
Old 01-24-2012, 03:00 PM   #19
jollyblue84
Member#: 292300
01 GC8
blue
Well I have an after market down pipe full exhaust k&n air filter (will be making my own cold air intake). So not much but a little to support. As of the intercooler. I will converting to a front mount. But I will need to look at one that has this already.
Although I am new to the forum and subarus. does not mean Im new to motors. I understand that in order to get more power I must do more than gain boost. But I believe my question was if it would be safe to run 18psi in this motor. I dont believe I asked anything about how much power i would gain.
Old 01-25-2012, 03:06 PM   #20
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Your specific question as to - if it is safe to run more boost with your engine is a loaded question without a simple yes or no. Safe means no knock.
Assuming that at 18psi of boost you have ZERO knock then sure you can absolutely run 18psi.
The amount of boost is not material. Safe is merely a matter of if at that level of boost there is or isnt knock which is why I asked what supporting modifications you have done to facilitate running 18psi.
The reason people run AOS, FMIC or bigger TMIC as supporting modifications for running more boost is to decrease air temperature in order to reduce the likelyhood of knock. Also the fuel you are running could be considered a supporting mod. 94 octane is probably a good idea.
A wideband sensor to tell you if your running lean at higher boost is probably a good idea as well.
Old 01-25-2012, 04:02 PM   #21
jollyblue84
Member#: 292300
01 GC8
blue
Ok. Well im still on the stock tmic. Always run 94 octane fuel.
thanks for the info. I really appreciate it.
Old 01-25-2012, 07:00 PM   #22
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
The answer is no. for more than 16 psi you will need bigger injectors and the ecu tune to match.
rob is offline   Reply With Quote
Old 01-25-2012, 07:37 PM   #23
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
This thread is a cluster**** of ****.
i_c_the_light is offline   Reply With Quote
Old 01-26-2012, 03:29 AM   #24
jollyblue84
Member#: 292300
01 GC8
blue
Originally Posted by rob
The answer is no. for more than 16 psi you will need bigger injectors and the ecu time to match.
Thank you very much.
Old 02-11-2012, 11:26 AM   #25
steveomiami
Member#: 309883
What boost is this car supposed to run stock? I'm trying to figure out what Im dealing with in this 1992 jdm wry i just bought
steveomiami is offline   Reply With Quote
New member with a decent amount of mods _Naomi Newbies & FAQs 14 01-10-2011 02:31 PM
New member with a couple of questions.. WickedXj Vancouver Impreza Club Forum -- VIC 16 10-01-2008 06:03 PM
New guy with lots of noobish upgrade questions tickthrow Newbies & FAQs 9 03-26-2008 06:40 PM
New Member with just out of warranty wrx 2.0 Rattus58 Newbies & FAQs 6 06-09-2007 12:52 PM
