Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 01-24-2012, 02:12 AM   #76
Subaru_Freak
Member#: 25667
2011 STI 5-Dr.
PBP
Move me to tentative, got something that came up and I might have to miss it or leave early.
If we can push the cruise start time up to 9:00 AM I'd be able to do it, but I'd understand if you can't.
Subaru_Freak is offline   Reply With Quote
Old 01-24-2012, 09:28 PM   #77
04Rsx
Member#: 307688
I'm down if i can get out of work early! I don't have a subie though :/
04Rsx is offline   Reply With Quote
Old 01-24-2012, 11:34 PM   #78
crollins
Member#: 202202
2011 Clubman S
green
Originally Posted by rexassian View Post
Driving the mini?
I have a friend that just bought an AWD MazdaSpeed6 that probably would like to join
I'll re-do the map with the staging area built in later tonight. It would be the Tetco @ 71 & 620.
Of course, it should be fun trying to keep up.
crollins is offline   Reply With Quote
Old 01-26-2012, 04:44 PM   #79
garrett144
Member#: 260305
2008 STi
DGM - Stealth Mode
I might have a buddy come drive with us in his Mini. You two can keep each other company.
garrett144 is offline   Reply With Quote
Old 01-26-2012, 05:18 PM   #80
RckyMtnLegacy
Member#: 287058
93 Turbo Legacy
White on Black
I am 80% sure I will be there
RckyMtnLegacy is offline   Reply With Quote
Old 01-27-2012, 02:17 AM   #81
4-n-zics
Member#: 228961
2016 4Runner TRDP
Put me down at tentative. If I do make it I will be coming from the DFW area.
4-n-zics is online now   Reply With Quote
Old 01-27-2012, 03:11 AM   #82
bpayne84
Member#: 265242
1995 Impreza L wagon
mostly white
I can't wait for this drive, a little R&R for my subie to strech the old legs...247,XXX and still kickin
bpayne84 is offline   Reply With Quote
Old 01-27-2012, 12:25 PM   #83
garrett144
Member#: 260305
2008 STi
DGM - Stealth Mode
Updated driver list.
One of my group leaders may or may not make it so - if anyone has experience with this route/area and wouldn't mind leading a group - PM me with your name and number.
Old 01-27-2012, 10:02 PM   #84
02bugeyedimp
Member#: 299328
2002 outback sport
R&R is never what ur subie needs, needs to be put through the paces to make sure it's still running up to par. maybe we'll pick up sumthing thursday for it.
02bugeyedimp is offline   Reply With Quote
Old 01-28-2012, 12:12 AM   #85
Alex05sti
Member#: 145428
2005 STi
heres Brianne's 250,000+ mile subie rocking the rallycross last week.
Alex05sti is offline   Reply With Quote
Old 01-29-2012, 12:25 PM   #86
02bugeyedimp
Member#: 299328
2002 outback sport
Originally Posted by DEVO330 View Post
i think i paid $40??? i'd prefer a plug in earphone to set the thing down and hear better in these loud cars
does it have to be the same brand? I'm new to using radios, but if I have a midland radio i'll be able to find the channel yes?
Old 01-29-2012, 12:53 PM   #87
DEVO330
Member#: 159291
03 EVO,TurboMiata
Good question, some guys showed up on the SouthNTEC BRAZOS RIVER Cruise with VHF. . Not compatible. I don't know the correct BAND names, you'll have to do some research
Wikopedia:
A Motorola FRS radio with labeled parts Most personal walkie-talkies sold are designed to operate in UHF allocations, and are designed to be very compact, with buttons for changing channels and other settings on the face of the radio and a short, fixed antenna. Most such units are made of heavy, often brightly colored plastic, though some more expensive units have ruggedized metal or plastic cases. Commercial-grade radios are often designed to be used on allocations such as GMRS or MURS (the latter of which has had very little readily available purpose-built equipment). In addition, CB walkie-talkies are available, but less popular due to the propagation characteristics of the 27 MHz band and the general bulkiness of the gear involved.
Personal walkie-talkies are generally designed to give easy access to all available channels (and, if supplied, squelch codes) within the device's specified allocation.
Personal two-way radios are also sometimes combined with other electronic devices; Garmin's Rino series combine a GPS receiver in the same package as an FRS/GMRS walkie-talkie (allowing Rino users to transmit digital location data to each other) Some personal radios also include receivers for AM and FM broadcast radio and, where applicable, NOAA Weather Radio and similar systems broadcasting on the same frequencies. Some designs also allow the sending of text messages and pictures between similarly equipped units.
While jobsite and government radios are often rated in power output, consumer radios are frequently and controversially rated in mile or kilometer ratings. Because of the line of sight propagation of UHF signals, experienced users consider such ratings to be wildly exaggerated, and some manufacturers have begun printing range ratings on the package based on terrain as opposed to simple power output.
While the bulk of personal walkie-talkie traffic is in the 27 MHz area and in the 400-500 MHz area of the UHF spectrum, there are some units that use the 49 MHz band (shared with cordless phones, baby monitors, and similar devices) as well as the 900 MHz band; in the US at least, units in these bands do not require licenses as long as they adhere to FCC power output rules. A company called TriSquare is, as of July 2007, marketing a series of walkie-talkies in the United States based on frequency-hopping spread spectrum technology operating in this frequency range under the name eXRS (eXtreme Radio Service—despite the name, a proprietary design, not an official allocation of the US FCC). The spread-spectrum scheme used in eXRS radios allows up to 10 billion virtual "channels" and ensures private communications between two or more units.
DEVO330 is offline   Reply With Quote
Old 01-29-2012, 01:27 PM   #88
oakcliff
Member#: 273767
2011 WRX
Red
I'm curious as well...I have a set of four I'm bringing
oakcliff is offline   Reply With Quote
Old 01-29-2012, 05:15 PM   #89
bpayne84
Member#: 265242
mostly white
I'm pretty sure I met Brianne while working at a junkyard in Austin, she came by looking for parts and we had a long conversation about Subaru rally sports!
Old 01-29-2012, 05:17 PM   #90
bpayne84
Member#: 265242
mostly white
Maybe new tires for me?? that would rock!! And BTW R&R stands for Rally & Racing LOL
Old 01-30-2012, 10:08 AM   #91
02bugeyedimp
Member#: 299328
2002 outback sport
hahahaha, aiight! I thot you were getting soft in your old age, cuz I KNOW it's not ur car that's getting old.
Old 01-30-2012, 10:11 AM   #92
02bugeyedimp
Member#: 299328
2002 outback sport
Wikopedia:
...........communications between two or more units.[/color]
That's a lot of information. Guess I'll just bring what I got and hope it works. Anyone going for a test run on a Sunday LMK I'll be there!
Old 01-30-2012, 10:17 AM   #93
garrett144
Member#: 260305
2008 STi
DGM - Stealth Mode
If its a two way radio made in the last 5 years, chances are what you have will work. If not - I have a spare you can borrow.
Old 01-30-2012, 11:01 AM   #94
02bugeyedimp
Member#: 299328
2002 outback sport
Appreciate that. I have three so I'm hoping they work so I can have extra for sumone else.
Old 01-30-2012, 01:08 PM   #95
dromango
Member#: 94531
99' RS
Rally Purple Pearl?
count me in on the action.
dromango is offline   Reply With Quote
Old 01-30-2012, 01:13 PM   #96
oakcliff
Member#: 273767
2011 WRX
Red
Pic made my day
Old 02-01-2012, 12:33 PM   #97
bpayne84
Member#: 265242
mostly white
Hoping to see some of you Subaru guys and gals out at First Thursday in Austin, check out the thread in TXIC forums!! ;-))
Old 02-02-2012, 09:17 AM   #98
garrett144
Member#: 260305
2008 STi
DGM - Stealth Mode
I'll be there as well and encourage anyone who has never been to a Cobb event to attend. Great cars, great shop, great staff, etc.
EDIT: look for the pedobear sticker on the back of my Sti and come say hi
Old 02-02-2012, 10:27 PM   #99
DEVO330
Member#: 159291
03 EVO,TurboMiata
Close call! i've been look'n fwd to this so much I started packing tonight and happened to check post #1 noticing the March3rd date. . . This Saturday is the 4th. . Oh shi_! another month?? maybe i can coerce more NTEC EVOs to make the farm road commute w/me. . .
Old 02-04-2012, 10:40 AM   #100
garrett144
Member#: 260305
2008 STi
DGM - Stealth Mode
Hah! I still would've cruised around with you today, there just wouldn't have been 20 other cars with us.
Austin Hill Country Cruise - November 14th BoostedMKIV Texas Impreza Club Forum -- TXIC 37 11-17-2009 10:11 AM
Sunday, March 16, 2008 FOCSA.ORG Hill Country Cruise Dentless Dave Texas Impreza Club Forum -- TXIC 0 02-16-2008 11:04 PM
EVO/STi/SRT4 Hill Country Cruise aznburn210 Texas Impreza Club Forum -- TXIC 23 03-14-2007 10:24 PM
Sept 7th Hill Country Cruise in Austin GoodFinder Texas Impreza Club Forum -- TXIC 115 09-07-2002 11:36 AM
Saturday AM Hill Country Cruise...review Whit Texas Impreza Club Forum -- TXIC 1 12-23-2001 06:37 PM
