Notices
Old 11-14-2012, 02:08 PM   #51
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
I prefer to avoid using the "stage" phrasing. Not many people know what stage 3 is or beyond for that matter. The main purpose of this thread isn't to eliminate boost creep, however I did spend quite a bit of time on that subject. The majority of my experience and research has been on 08/09+WRX's. They suffer heavily from boost creep, so it was only logical for me to spend time explaining it.
I will continue to update the OP with other mods. I'll do my best to explain the purpose as well as what mods should be done in conjunction with others.
Edit: Added more info...
drewvdw is offline   Reply With Quote
Old 11-14-2012, 03:23 PM   #52
zUnRealistiCz
Member#: 337517
2010 WRX Limited
Dark Grey
so being new to the forums and the subi world.. after reading the part about intakes and then the feedback from whoever responded i'm still torn on weather or not a cold air intake or even a shirt ram is a better way to go than getting a drop in for my 2010 WRX Hatch. I ordered a drop in from Perrin and figured i'd try out the cheaper way first. I'm sure i wont be feeling a difference or anything but i'm still curious to know which is a better route
zUnRealistiCz is offline   Reply With Quote
Old 11-14-2012, 03:27 PM   #53
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Well, you won't feel a difference. Some have said that even a drop in filter must be tuned for in the newer cars. Personally, I have a hard time believing it, but I suppose it is possible. Either way, a CAI requires a tune. You will feel a difference from being tuned with or without an intake. I'd start by getting a tune, then go for a downpipe.
Old 11-14-2012, 03:56 PM   #54
Freep
Member#: 238640
2007 WRX STi
Built wrb (Sold)
^ALL of This
You will mostly just HEAR a difference with nothing else done.
Freep is offline   Reply With Quote
Old 11-18-2012, 02:38 PM   #55
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Bump for updated info on 08+ 5mt.
Edit: Also added 3 port vs 4 port EBCS.
Old 11-27-2012, 06:13 PM   #56
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Update: Added suspension and bushing sections
Old 11-27-2012, 10:16 PM   #57
DoogieSTi
Member#: 247023
2007 STi
WHAAAA?!?
DoogieSTi is offline   Reply With Quote
Old 11-27-2012, 10:17 PM   #58
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Well, what little knowledge I have about them
Old 11-27-2012, 10:21 PM   #59
DoogieSTi
Member#: 247023
2007 STi
I've done plenty of bushing upgrades and they make a huge difference for the money.
BTW, this is a great thread with good basic info. I smell a STICKY!!
Old 11-27-2012, 10:27 PM   #60
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Haha, thanks, I appreciate it, there's a lot of hours into just writing this, let alone all the research behind all of it.
You don't happen to have a good list of bushings and what they do/their effect on handling, do you?
Old 11-27-2012, 10:56 PM   #61
DoogieSTi
Member#: 247023
2007 STi
For bushings and what they do I would consult TiCs website. That's where i get most of my bushings. The Old Bush New Bush replaces almost all of the suspension bushings and they describe where they go and what they do. I can look around for some more/better info too.
Old 11-27-2012, 11:33 PM   #62
DoogieSTi
Member#: 247023
2007 STi
Drew, you have a PM.
Old 11-27-2012, 11:52 PM   #63
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Haha, I was reading up and adding to this while I ignored your PM, I didn't think about it.
Old 11-27-2012, 11:57 PM   #64
DoogieSTi
Member#: 247023
2007 STi
Oh well. Haha. I think I added some things in there that you might not have. But then again maybe not. Good work regardless.
Old 11-27-2012, 11:58 PM   #65
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Yeah, there's a few more things I'll be adding tonight or tomorrow. You really don't understand how much work one of these is until you do it
Old 11-28-2012, 12:01 AM   #66
DoogieSTi
Member#: 247023
2007 STi
I hear you man. That little bit I sent you felt like researching a thesis paper or something. Keep the good stuff comin man!!
Old 11-28-2012, 10:05 AM   #67
jpatt006
Member#: 289470
2010 Forester XT
First off, great info. With that being said, I have a question regarding TGV deletes. My car has most of the things you mention in the first post. The TGVs are not next on my list, but they are on my list. So here is my question:
The two main benefits of composite TGV deletes are less restrictive air flow at initial start-up and cooler intake temps, correct? Since our 08+ cars already have composite intake manifolds, will we see any cooling benefit from composite TGVs? If not, is the less restrictive airflow alone enough of a benefit to make them worthy of upgrading? I guess what I'm wondering is, does the benefit come more from cooler temps or from improved airflow?
Thanks.
jpatt006 is offline   Reply With Quote
Old 11-28-2012, 10:10 AM   #68
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
The composite TGV deletes are an option, you can also have your stockers ported and polished. I wouldn't think that the gains from going to composite would be very measurable, but I could be wrong. Composite TGV's are just coming onto the scene.
They both should have roughly the same airflow once done, the composite just adds the insulating factor. Personally I run regular TGV deletes with a phenolic spacer. I did this well before composite TGV's came out, but my point stands that you can still achieve the insulating effect to some degree without composite.
Old 11-28-2012, 11:44 AM   #69
DoogieSTi
Member#: 247023
2007 STi
I just picked up my GB set of composite TGVs and I think the inner diameter is same as a PnPed stock TGV. For guys with metal intake manifolds the benefits will definitely be better/greater than the new composite intake guys. I think it comes down to how much time and money are you willing to put in for so-so gains? Probably a better bang for you buck mod out there, depending on what you already have.
Old 11-28-2012, 01:09 PM   #70
Teehsee
Member#: 229300
2011 obp wrx hatch
08 dgm fxt
I know this is a "post" stage 2 modification thread. However, in speaking with my local tuner it was recommended that I get a EBCS and some fuel modifications. They recommended the DW65c fuel pump and upgraded 850cc injectors. I know it's not necessarily necessary, but it seems recommended. I guess my question is, what are the purpose of the bigger injectors at stage 2 levels? Just a failsafe because they seem to run at near capacity at stage 2?
Also, I plan to eventually modify beyond this, just planning to do the remainder and get a retune in the summer. I do plan on going E85, do you feel the recommended 850cc injectors will need to be upgraded once again, should I go bigger?
Also, if there are issues of boost creep/spikes, especially with a catless setup which I'll have, does the EWG/EBCS actually fix this?
Teehsee is offline   Reply With Quote
Old 11-28-2012, 01:24 PM   #71
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
It depends on the tuner and what they recommend. For 08+ WRX's and STI's, the fuel system is more tasked and closer to 100% Injector Duty at Stage 2. For 02-07's this is not true.
EBCS would be souly based on the tuner. It's not at all needed, but could help out anyone for a bit of peace of mind.
Old 11-28-2012, 01:28 PM   #72
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Both of those are great ideas at stage 2 power levels, especially on newer WRX's. Your car will be at the limit of the injectors and fuel pump, so yes, they could be viewed as a failsafe right now. You want to go bigger in the future, so you may as well go with bigger injectors and fuel pump. An EBCS won't solve any boost creep issues, but it may slightly help. I wouldn't rely on it and would get an external wastegate.
850cc to 1000cc injectors seem to be about perfect for most people running E-85. That's something you have to talk to your tuner about as some won't deal with certain brand injectors.
An EWG and EBCS setup will solve your boost creep issues, go with the largest you can afford. I have a 38mm EWG and it works great. There's no benefit to a smaller wastegate.
Old 11-28-2012, 10:26 PM   #73
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Bump for updated info.
Old 08-06-2013, 03:12 AM   #74
NJ_wrx
Member#: 268855
2009 WRX
red
Bumping for a good read. Thanks OP!
NJ_wrx is offline   Reply With Quote
'07 STi "stage 2" at the track rxer311 Proven Power Bragging 14 04-27-2008 04:51 PM
Looking to go to "stage 2" 07SWPSTi Newbies & FAQs 31 10-18-2007 08:13 PM
Our take on a "stage 2" P&L Motorsports Inc. Proven Power Bragging 30 04-12-2007 12:29 PM
"stage 2" 2.5L WRX at 3500' and sea level Airboy Engine Management & Tuning 1 01-09-2007 01:27 PM
FS: 04 Ecutek ecu - "stage 2" Panic Engine/Power/Exhaust 5 10-03-2006 04:16 PM
