Welcome to the North American Subaru Impreza Owners Club Wednesday August 27, 2014
Old 03-08-2012, 07:52 PM   #26
CobbsSTI
Member#: 245242
2006 STI
E85 Power
Originally Posted by HSBabyFace
I'm getting the Dom 1.5xtr put on my wrx as we speak. I was hoping to see people hit higher numbers after seeing TopSpeeds results.
My tune is fairly mild considering I'm on stock internals and injector size while running E85, you should expect to see around 350 give or take on a setup like mine on pump gas, if your running E85 on a built motor with bigger injectors you'll be well into the 400hp+ range easy with the Dom 1.5xtr.
CobbsSTI is online now   Reply With Quote
Old 03-08-2012, 09:07 PM   #27
Ragnarok_WRX
Member#: 257093
That sounds about right, I'd be happy with a dd tune making 350-370whp and a nice powerband. Any more and it wouldn't be practical for where I live
Ragnarok_WRX is offline   Reply With Quote
Old 03-08-2012, 10:50 PM   #28
HSBabyFace
Member#: 130204
06 WRX IAG Built
FOR SALE!!!
What kind of boost are you running?
I'm getting a built short block with ID1000s and will be tuned on pump 93.
HSBabyFace is offline   Reply With Quote
Old 03-08-2012, 11:51 PM   #29
CobbsSTI
Member#: 245242
2006 STI
E85 Power
22.5psi on 93 and 23.5 on E85
Old 03-09-2012, 12:44 AM   #30
neorex
Member#: 106478
STi 1.5 xt-r
TS #'s are due in large part to the invidia race header they employed...
neorex is offline   Reply With Quote
Old 03-09-2012, 10:05 AM   #31
B.R.E.D
Member#: 289606
06 WRX
white
I've got a customer thats using a DOM 1.5 (10cm) with one of our Track 1 short blocks and our stage 1 head package. On his break in tune on TopSpeeds dyno he made 350whp 350wtq at 16lbs and a 5500rpm rev limit.
I suspect he will be over 400whp on pump gas.
Matt
Ball Racing
Edit, That wasn't a slam on the OP, just a statement really about what an awesome turbo this is. I'm looking forward to my customer getting a final tune so we can see what it will really do.
B.R.E.D is offline   Reply With Quote
Old 03-09-2012, 12:01 PM   #32
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I run this turbo on E. Ended up running out of injector at 27 psi. Turned it down to ~24 to get my IDC under 98%. I am going to move up to 2000cc and try again and see where the walbro runs out next I suspect.
what are your IDC on pump and on E?
Looks like it's pretty safe and fun tune.
medamullet is offline   Reply With Quote
Old 03-09-2012, 12:54 PM   #33
mpristave
Member#: 284761
2012 WRX
Originally Posted by Ragnarok_WRX View Post
My bad, I should have told you, I'm in Alaska.
Anchorage isn't that bad compared to most parts.
mpristave is offline   Reply With Quote
Old 03-09-2012, 05:09 PM   #34
Ragnarok_WRX
Member#: 257093
Most parts of where? The rest of Alaska? Then yes, but the rest of the country...noooot so much.
Old 03-22-2012, 02:11 PM   #35
CobbsSTI
Member#: 245242
2006 STI
E85 Power
I'll have check my IDC again and get back to you on that I forget the %
Old 03-22-2012, 02:41 PM   #36
LBell05STI
Member#: 305890
2005 STI
What garret core is the 1.5 compared too?
LBell05STI is offline   Reply With Quote
Old 03-22-2012, 04:16 PM   #37
neorex
Member#: 106478
STi 1.5 xt-r
The Dom 1.5xtr essentially has a GT3071 chra with the optional 56.5mm (not 60mm) turbine..tacked on the other end is their 71mm billet comp wheel...
Old 03-22-2012, 06:57 PM   #38
B.R.E.D
Member#: 289606
06 WRX
white
Matt
Ball Racing
Customer cracked 400hp today on TopSpeeds dyno. It made 407whp at 21lbs. Its an amazing car to drive one of the few stock location turbos I really like.
Edit 93 Octane.
Old 03-22-2012, 07:02 PM   #39
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
On E??
07wrx84 is offline   Reply With Quote
Old 03-22-2012, 07:14 PM   #40
B.R.E.D
Member#: 289606
06 WRX
white
Originally Posted by 07wrx84 View Post
On E??
93 Octane Pump Gas.
Our Track1 Short Block and Heads (1mm oversize Slight porting) GSC S1 Cams, AMR Top Mount, 10cm Dom 1.5.
We built the engine, customer installed it and Doug tuned it.
Its a very nice car.
Ill see if I can get him to do a PP thread about it tomorrow.
Old 03-22-2012, 07:37 PM   #41
neorex
Member#: 106478
STi 1.5 xt-r
Someone needs to start "The Dom 1.5XT-R Thread..." *hint-hint*
Old 03-22-2012, 07:59 PM   #42
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
93 Octane Pump Gas.
So sweet! I have maxed out my 20gxt. How aggressive is the timing?
Old 03-22-2012, 08:05 PM   #43
Zaider
Member#: 154281
2002 V7 EJ207 Dom1.5
MBP
Looks nice. According to Blouch, this turbo was originally designed for the UK Ej207.
Im probably going with it for my JDM Ej207...
Hoping for 350ish with water-meth and alright spool (4k-ish).
Zaider is offline   Reply With Quote
Old 04-22-2012, 02:04 PM   #44
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
348hp/353tq on 93 and 398hp/393tq on E85
Originally Posted by juanmedina
agreed it should spool sooner, although the power band is still good . My 68lb/min turbo makes more torque than this one at 4k rpm .
Enjoy OP, look for leaks
OP correct me if I'm wrong but this appears to be 3rd gear pull.
I just installed Dom 1.5 and this looks alot like mine as I have been logging in 3rd gear. Not laggy at all, I'm still tuning mine but it responds really quick and spools very close to vf39.
bswilmington is offline   Reply With Quote
Old 07-04-2013, 02:16 AM   #45
markesc
Member#: 164875
2007 WRXTR blouch20G
Mine is waiting on Lumpkins @ Cobb Surgeline! 1.5 xtr / 8cm hotside
I'll post results!!
For now I'm stuck with pics
[IMG][/IMG]
markesc is offline   Reply With Quote
Old 07-04-2013, 08:00 AM   #46
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
At iag I made 367/363 @21psi on 93oct. My mods are hybrid setup with completely stock 2.0 heads, headers, tbe, ID1000's, the deletes, Txs fmic and lil other stuff hear and there. Oh and a 6spd lol but I really like this turbo (1.5xtr 10cm) spools nice and pulls hard enough to make my cd's under my head unir come flying me if I punch it lol
shadowmd is offline   Reply With Quote
Old 07-04-2013, 01:38 PM   #47
RobSTI89
Member#: 225268
2005 STI
So with this turbo and e85 1100cc injectors feed the 1.5xtr at 400+whp on a mustang dyno? Or would I need bigger injectors ?
RobSTI89 is offline   Reply With Quote
Old 07-04-2013, 06:31 PM   #48
bilt2run
Member#: 134211
^^^ I make 450whp on a mustang dyno with this turbo with fic 1100 and a 55psi base pressure intank bosch 044 and a boost a pump. 90% duty cycle
bilt2run is offline   Reply With Quote
Old 11-13-2013, 07:25 AM   #49
sweeeeper
Member#: 186894
2005 sti
blue
Anybody installed this turbo by yourself?
sweeeeper is offline   Reply With Quote
Old 11-13-2013, 09:01 AM   #50
bswilmington
Member#: 217563
Yeah I have.
Dyno Tune: 2.5L Blouch Dom 2.5XTR, 372whp, EPIC Tuned englishguy3012 Proven Power Bragging 9 06-11-2014 08:31 PM
Dom 1.5xtr fitment issue, 11' STi tazswing Factory 2.5L Turbo Powertrain 21 01-07-2012 07:05 PM
05 STi with Blouch 1.5XTR on E85 1slow05WRXSTi Proven Power Bragging 33 10-14-2011 10:50 AM
2006 sti 2.5L Dom 1.5xtr 400+WHP E85 medamullet Proven Power Bragging 31 05-26-2011 04:32 PM
06 STI with super suck 1/8 times... need some help. messenger Proven Power Bragging 10 04-04-2007 11:06 PM
