Old 02-27-2013, 08:52 PM   #51
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
Overland04 is offline   Reply With Quote
Old 03-10-2013, 07:10 PM   #52
icemanftr
Member#: 320444
2012 WRX
Mine didn't come with galley plug for my prosport oil pressure sender... Did you orser that separate? Sender won't fit in OEM one
icemanftr is offline   Reply With Quote
Old 03-11-2013, 02:35 PM   #53
TheRealGkz
Member#: 339946
2016 Limited BRZ
Hey Overland04, as always your write-ups are perfect and look amazing! I'm going to be getting a Gauge setup soon. How do you like your prosports, still working okay? Are they fairly accurate? Thanks in advanced
TheRealGkz is offline   Reply With Quote
Old 03-11-2013, 02:40 PM   #54
Overland04
Member#: 293311
2013 FXT 6-Speed
Hey All,
I have to say, I still love my Prosports. They are working 100% and still look great. They seem to be accurate, I'm just using them as a reference so I'm not the best judge to see how accurate they are.
Great value too!
Old 03-11-2013, 02:41 PM   #55
Overland04
Member#: 293311
2013 FXT 6-Speed
Hey,
I posted the link to the galley plug in the beginning of the thread. It doesn't come with the gauge.
Old 06-28-2013, 07:50 PM   #56
TheRealGkz
Member#: 339946
2016 Limited BRZ
Any reason for not going with Exhaust gas temperature? I'll be purchasing my gauges today and I was going to go with that one, boost and oil pressure.
Old 06-28-2013, 10:27 PM   #57
Overland04
Member#: 293311
2013 FXT 6-Speed
Nope, no reason not to. I didn't have the need to monitor the EGT so I went with the easier ones to install
Old 06-28-2013, 10:47 PM   #58
TheRealGkz
Member#: 339946
2016 Limited BRZ
Curious, what does EGT enforce? Like what's the purpose of monitoring it anyways?
Old 06-28-2013, 10:59 PM   #59
Overland04
Member#: 293311
2013 FXT 6-Speed
I used to monitor it on my first B16b turbo install back in the day. It was nice to use on long pulls for tuning. Before access ports and wide band afr monitoring, I was able to manually tune with how hot the gasses exiting the turbo were. Too lean, got hot. To rich, ran cold. Proper fuel mixture made everything happy.
The gauge required to tap your down pipe to install the temperature probe. Not the easiest install.
Old 06-28-2013, 11:18 PM   #60
TheRealGkz
Member#: 339946
2016 Limited BRZ
Hmm makes sense, okay. Definitely going with Oil temp/pressure/boost now.
Old 07-25-2013, 02:14 PM   #61
SubNub
Member#: 53603
2004 EJ207 WRX
Awesome writeups Overland04! When I ran my Prosport Halo Boost Gauge (these have dimming BTW), I wired the sender unit under the dash, with vaccum line tapped near the BPV running through the firewall back to the sender unit. I thought I read that the sender wasn't waterproof and wouldn't hold up well in an engine compartment (with heat and dirt etc). No concerns with running yours in the engine bay? I find my guage to be very accurate too, according to my tuner looking at the ECU readouts for boost.
Thanks for all the photos too. I was about the buy the remote sender kit for the oil pressure sender until I saw how small the unit was in your photos. I believe the Halo series come with the small sender too so now I just need the galley plug adapter! Yay!
SubNub is offline   Reply With Quote
Old 07-25-2013, 02:17 PM   #62
Overland04
Member#: 293311
2013 FXT 6-Speed
Sounds good man, nice job so far!
The sender has been doing well for the past 2 years without an issue. The gauge is relatively accurate. I feel it's a pound off but after having it for two years, you just know that it's always a pound off.
Cheers!
- Jason
Old 07-31-2013, 06:49 PM   #63
brandonk_5
Member#: 268700
Bump for a question
How much would would you ballpark the cost of having something like this done? I thought it would be relatively simple but it's not something I'd want to try doing myself.
With cost, I mean for all of the installation/customizing that needs to go on with the wires, and labor for removing/putting back together the dash.
Car looks amazing though man.
brandonk_5 is offline   Reply With Quote
Old 07-31-2013, 06:57 PM   #64
Overland04
Member#: 293311
2013 FXT 6-Speed
Originally Posted by brandonk_5 View Post
Bump for a question
Thanks Brandon,
I would think it would be somewhere around a few hundred. Do you have the gauges already? Are you looking at getting a pod too?
The install takes roughly 4-5 hrs depending on their speed and shops per/hr fee.
Take a 3 hr ride up here and lets do them together
Old 07-31-2013, 07:14 PM   #65
brandonk_5
Member#: 268700
Don't tempt me haha. I already drove 8 hour round trip to swap trunks .
I currently don't have any gauges. I was asking because in the near future, I would like to buy the ATI clock pod, but saw that the fitment was horrendous. I was calling around to see how much certain places would charge to wrap the top of the dash (after pod was installed) to give it that uniform look.
If my math is correct, for the pod + gauges, I should be paying in the ballpark of around 730 bucks (boost, oil temp or pressure, and probably egt).
I just don't have the technical know how to be installing gauges + re-wiring anything, yet
Where in Maine are you from?
Old 07-31-2013, 07:57 PM   #66
Overland04
Member#: 293311
2013 FXT 6-Speed
Do IT!!! I'm ready when you are
I'm located in the Rockport/Rockland area
Old 07-31-2013, 09:50 PM   #67
brandonk_5
Member#: 268700
Teasing.
Used to live in wayne, Skowhegan, and near old Orchard Beach when I was younger
Old 10-25-2013, 01:47 PM   #68
olenderc
Member#: 338384
2014 Impreza WRX STi
I would honestly take you up on this offer one day if it still exists. I have a friend who lives in Maine and I'm about 5-6 hours away and would come up for the day to do something like this if I'm ever visiting him up there. I'm so retarded when it comes to anything electrical, I probably couldn't even do the simplest wiring if I had to, just seems so complicated.
olenderc is offline   Reply With Quote
Old 10-25-2013, 05:31 PM   #69
Felon187
Member#: 371590
Nice...
Felon187 is offline   Reply With Quote
Old 11-14-2013, 01:11 PM   #70
takeadirtnap
Member#: 344507
2010 WRX
Just to bring this back. Overland what did you do with the OEM sender after it was unplugged? Just let it sit there free? ziptie it down somewhere? just curious
takeadirtnap is offline   Reply With Quote
Old 11-14-2013, 01:22 PM   #71
Overland04
Member#: 293311
2013 FXT 6-Speed
The sender you will unplug and remove. The wire can be zip-tied back as it is not used anymore. The light will remain off.
Cheers!
- Jason
Old 03-07-2014, 08:15 PM   #72
KIRKOY
Member#: 115756
2002 wrx impreza
ASPEN WHITE
did u delete the cig lighter outlet ?
KIRKOY is offline   Reply With Quote
Old 03-07-2014, 11:07 PM   #73
Overland04
Member#: 293311
2013 FXT 6-Speed
I did, nice catch.
Didn't really like the offset location of it. It messed with my ADD, lol
Old 03-08-2015, 04:58 PM   #74
M A T T
Member#: 319233
Im just about to install my boost and oil temp guages from prosport...but see it doesnt come with a sender. I am assuming i have to buy one after reading the comments. This sucks.
My wiring for my guages dont look long enough to even connect them to the fuse box under the pedals? I bought an SMY gauge cluster and cant figure out where you put your wires through the firewall?
Please help me :/
EDIT: Yes i bought this bad boy back from the grave..but dont see any other threads that can help mme with it.
M A T T is offline   Reply With Quote
Old 03-08-2015, 05:48 PM   #75
asangahtang
Member#: 381101
Nice setup man.
asangahtang is offline   Reply With Quote
Prosport Evo Boost Gauge Wiring Help 2011 Wrx scoobnoob1103 Newbies & FAQs 2 01-02-2012 10:13 AM
WTB : someone to install a 3 gauge dash pod elias0930 NESIC Private Classifieds 4 01-13-2011 10:36 PM
FS/FT: Aftermarket Subaru 3 gauge dash pod [ATI] with Greddy gauges Saabaru25 Interior/Dressup/Audio & Security 18 06-25-2008 10:33 PM
FS/FT: Aftermarket Subaru 3 gauge dash pod [ATI] with Greddy gauges Saabaru25 MWSOC Private Classifieds 13 05-21-2008 11:11 PM
wrx 3 gauge dash SNAFU...a little help please... db97 Service & Maintenance 2 11-19-2001 03:47 PM
