Old 03-27-2013, 09:04 PM   #1301
Ryan91
Member#: 311300
2011 WRX Sedan
Spark Silver
How big are the spacers? Sorry if you posted that already.
Ryan91 is offline   Reply With Quote
Old 03-27-2013, 09:08 PM   #1302
ixwrxxi
Member#: 334215
2015 Forester
[quote=Overland04;39456005]Awesome, when are you planning to get them?
I already placed my order yesterday.
ixwrxxi is offline   Reply With Quote
Old 03-27-2013, 09:16 PM   #1303
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
The spaces are 25mm
I needed about 15mm to clear the Brembos but I would have to change to bigger wheel studs. The 25mm spacers use the stock studs so I went with them. They ended up being the perfect fit for my fenders so I'm happy.
Just crazy thick!
Overland04 is offline   Reply With Quote
Old 03-27-2013, 09:17 PM   #1304
Overland04
Member#: 293311
2013 FXT 6-Speed
What are you riding on now?
Old 03-27-2013, 09:31 PM   #1305
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Did you cut off one lobe from the bump stops? I've been waiting to do this install myself, a few weeks and all should be together! Looking good!
jester8798 is offline   Reply With Quote
Old 03-27-2013, 09:35 PM   #1306
ixwrxxi
Member#: 334215
2015 Forester
My car is pretty much stock, got the whiteline swaybars to go alone with the bilsteins.
Old 03-27-2013, 09:38 PM   #1307
Overland04
Member#: 293311
2013 FXT 6-Speed
Hmmmm, I know the front's didn't have them and for some reason I can't remember seeing ones on the rear. Is there supposed to be?
Old 03-27-2013, 09:41 PM   #1308
Overland04
Member#: 293311
2013 FXT 6-Speed
It's going to be such a change for the better. I went back to stock for a couple weeks before I changed everything to RCE. It was so amazing!
Good luck with the install!
Old 03-27-2013, 09:53 PM   #1309
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
I thought you were supposed to reuse the fronts and I swear my rears came with new ones. Ben or Rob may be able to chime in. I'll look through my stuff.
Old 03-27-2013, 10:01 PM   #1310
rsutton1223
Member#: 280744
2009 CTSV 1,216whp
Black Raven
I reused all of mine when I installed that setup.
rsutton1223 is offline   Reply With Quote
Old 03-27-2013, 10:05 PM   #1311
underskore
Member#: 223303
2015 WRB WRX LIMITED
Package 22 6-Speed
Great job with the WRX.
I have one question, do you regret not getting an STi, in the first place?
underskore is offline   Reply With Quote
Old 03-27-2013, 10:20 PM   #1312
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
COBB Stg3 336whp/370wtq
I wish there was a wheel that I could run that looks the same without having to run the spacers. I love the way they look but hate that I have to use these HUGE spacers to get it that way.
Idk what your offset is with those spacers, but I run XXR 527 17x8.25 +25 (no spacers required) as my winters. Tires are Bridgestone Blizzak WS60 215/50/17.
I wanted the same thing, a wheel that would sit flush with my fenders just like how I have my summer setup, but be narrow enough for winter.
For reference, my summer setup is Sumitomo HTR ZIII 245/40/18 x 9 +35 Drag DR-31.
QwaktastiK is offline   Reply With Quote
Old 03-27-2013, 10:44 PM   #1313
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Rears too? I just checked and mine came with new rears but no fronts. Did you trim your fronts or was it not needed with the yellows?
Old 03-27-2013, 10:48 PM   #1314
Overland04
Member#: 293311
2013 FXT 6-Speed
The fronts definitely don't get reused. The shafts on the Bilstein's are 1-5/16" and the stock is 3/4". No way it would fit.
Still got to check the rears to be sure.
Old 03-27-2013, 10:58 PM   #1315
Overland04
Member#: 293311
2013 FXT 6-Speed
It looks like the offset for the Sparco wheels are +48 which would make it similar to your +25's without spacers.
You're running a 215 on an 8.25 rim?
The winter setup on there now is a 235 on a 7.5"
Old 03-27-2013, 11:01 PM   #1316
Overland04
Member#: 293311
2013 FXT 6-Speed
That topic comes up often but the quick answer for me is yes, I should have and still wish I did. I'll make excuses of why the WRX was a better choice but deep down I wish I did the STi.
Old 03-28-2013, 12:00 AM   #1317
underskore
Member#: 223303
Package 22 6-Speed
That is how I felt when I got my 06 WRX... so I got a 07 STi... lol
Here's to hoping you one day get an STi, and do this good again!
Old 03-28-2013, 07:57 AM   #1318
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
Yes'r. Since its such a tall tire, you can't see the stretch. If I had the room I would run 225's instead. But the additional 5mm might rub.
Keep in mind mine's a narrow body.
Old 03-28-2013, 08:34 AM   #1319
Overland04
Member#: 293311
2013 FXT 6-Speed
I wonder how the XXR's would do around the Brembo's, At +25 I would think they would be fine. They look great on your car, thanks for the info!
Old 03-28-2013, 08:46 AM   #1320
Overland04
Member#: 293311
2013 FXT 6-Speed
This picture is the only one I have of the Bilstein's compared to the stock shaft. The stock bump stop is almost the same diameter as the shaft of the Bilstein's. I was able to use the stock dust cover though, that still fits!
Old 03-28-2013, 09:58 AM   #1321
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Wow, I can't believe I missed that part! I haven't had my stock ones off so I wasn't sure the shaft size. I'm guess I'm confusing things Ben's Koni swap with RCE blacks. Sorry for the confusion, carry on
Looking forward to more pictures!
Old 03-28-2013, 09:41 PM   #1322
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
So the GTWorx don't use any bump stops at all? If you do happen to bottom out does it break the shock/strut? The giant shaft is probably a lot stronger, but that still would concern me a bit.
Overall they do look great. Sometimes I wish they were in stock when I got mine. I think I would have gotten them over the Koni's. I'm pretty happy with the Koni's though. Just a lot more work to put in, and a bit more low.
xluben is offline   Reply With Quote
Old 03-28-2013, 09:54 PM   #1323
arf80
Member#: 125580
2011 WRX 5dr
Is that a different or new version of the Bilsteins? Mine don't sit anywhere near that low, and I've never seen anyone else's that low either.
arf80 is offline   Reply With Quote
Old 03-28-2013, 10:49 PM   #1324
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
I'm wondering the same thing. Anybody know....Rob or Myles?
Old 03-29-2013, 01:04 AM   #1325
Overland04
Member#: 293311
2013 FXT 6-Speed
I got the word on the bump stop situation...
The fronts are internal, so they're bump stops but you just can't see them.
The rears come with bump stops which don't have to be cut at all if your using their black or yellow springs. If you use anything lower than 25mm, then you'll have to cut a section down on the rear.
I feel better knowing that about the fronts too
First Subaru ordered, '12 WRX hatch to be my daily driver MacNugget Newbies & FAQs 54 02-17-2012 03:07 PM
Is it wise/practical to shoot for 300whp in a daily driver 04 WRX? JonM in MN Newbies & FAQs 76 12-17-2006 12:50 PM
looking to upgrade my daily driver drifterx Outback Forum 1 09-30-2005 05:30 AM
looking to upgrade my daily driver. drifterx North West Impreza Club Forum -- NWIC 15 07-27-2005 10:32 AM
I want to get a daily driver Kuonji Off-Topic 9 05-11-2004 11:11 PM
