Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 07-13-2013, 08:16 AM   #1726
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Originally Posted by TheRealGkz View Post
Dude how did you get that double sided tape off behind the emblems? Its so tough
Haha, heat gun, thumbs and blisters!
Overland04 is offline   Reply With Quote
Old 07-13-2013, 08:31 AM   #1727
TheRealGkz
Member#: 339946
2013 Impreza Wrx
Black (CBS) Hatch
Did you take it completely off? Or is a thin layer still okay? Sorry for so many questions!
TheRealGkz is offline   Reply With Quote
Old 07-13-2013, 09:53 PM   #1728
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
It all has to come off. It's basically the most painful job to do
Old 07-13-2013, 10:09 PM   #1729
TheRealGkz
Member#: 339946
2013 Impreza Wrx
Black (CBS) Hatch
Booooo!
Old 07-16-2013, 09:26 AM   #1730
NBRX
Member#: 356927
'15 WRX Limited
World Rally Blue
Did you use the 2 can shadow kit by dupli color to do the turn signal housing or did you just go with the dupli color smoke metal cast ? I know you mentioned using the shadow but the link from earlier post brings up a amazon page for metalcast smoke . just trying to clarify before I purchase.
NBRX is offline   Reply With Quote
Old 07-16-2013, 09:44 AM   #1731
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Sorry for the confusion. Ive done a few more headlights since mine and tried a couple different paints along the way.
My original headlights are done with Dupli-Color Smoke: MC206. The coating is a very light mist and close up, it looks textured. I liked it and it was easy to apply.
The other headlights I have done since mine are with Dupli-Color Shadow Kit: SHD1000. The base coat sprays out tinted and smoother but it's a lot harder to tell how much you are putting on, so you may go too far without realizing until it's too late. The finished look is nice if you nail it just right.
If your only doing one set, I would stick with the Smoke: MC206
Old 07-16-2013, 10:14 AM   #1732
NBRX
Member#: 356927
'15 WRX Limited
World Rally Blue
Awesome, thank you good sir.
Old 07-16-2013, 11:40 AM   #1733
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
I have received a couple PM's on what to do about the hyper flash situation when you change your lights over to LED. Since I have changed over my front turn signals to LED I was extremely frustrated with the hyper flash and was about to order the resistors to stop this from happening.
The reason for the hyper flash is that the stock bulbs pull a lot more resistance to flash then LED's. When you remove the OEM bulbs and replace them with LED's, the integrated circuit flash relay looks for this resistance to flash properly. Since the LED have a much lower resistance, you get hyper flash.
To resolve this you have two choices. You can add resistance to the circuit by adding 50w, 6-ohm resistors across each bulb circuit. This will add the proper amount of resistance to the circuit to make your blinkers flash normally again.
(HERE)(HERE)
are the resistors for this.
The second option is to change over the OEM flasher to one that is made for the lower LED resistance. I have found one being sold by FastWRX.com for $19 found (HERE) or if you are crafty like me you can use my part number below and link to purchase the flasher on Amazon for $10.
The installation takes about 2 minutes and it works great. It's designed for 4 LED's but you can use this with only 2 LEDs if that's all you have. The only difference is that when you turn on your signal, the bulb will illuminate for 1 second than start to flash like normal.
(HERE)(HERE)
is the link.
Here is the flasher I used.
<img src=" />
Old 07-16-2013, 12:32 PM   #1734
ScoobyFreak86
Member#: 338329
2013 WRX Hatch
Used the same module in mine. Works like a charm! Very easy to install and works just like OEM (minus the pause in the beginning).
ScoobyFreak86 is offline   Reply With Quote
Old 07-16-2013, 12:36 PM   #1735
NBRX
Member#: 356927
'15 WRX Limited
World Rally Blue
You mentioned you have been doing headlights for people. Have you done any that looks like yours but without the yellow high beam area? pic?...its what I wanna do but not sure how it will look...
Old 07-16-2013, 07:01 PM   #1736
Studmike02
Member#: 220095
'95 MX-5
Me and scoobyfreak.
http://forums.nasioc.com/forums/show...2476991&page=4
Studmike02 is offline   Reply With Quote
Old 07-22-2013, 09:42 PM   #1737
TurtleWRX
Member#: 259919
2011 WRX Hatchback
Default Thank you!
Originally Posted by RaceComp Engineering View Post
We designed the GTWORX/BILSTEIN valving profile to work with BOTH the YELLOWS and BLACKS.
YES at one point we offered a hand full of members who were self admittedly, very sensitive to the valving EVEN with BLACKS installed. Keep in mind of the initial batch of 100 sets we sold in mid 2010 only 6 members complained of it being too stiff. Literally the remaining majority checked in with us via PM,email, phone calls, at events etc with super positive feedback. The reality is MOST want this for improved performance and NOT having to get coilover
We have NOT done any revalves in over a year and it is NOT necessary as the existing valving is fine for BOTH blacks and yellows.
What one gets with the Black springs paired to BILSTEINS is a damper that offers a LOT of control AND more comfort than the Yellows which are on the aggressive side.
(disclaimer: all references to BLACKS and YELLOWS is directed to RCE BLACK springs and RCE YELLOW springs). Had a bro roll up on me once " say my man, you said on the internet that Yellows are better than blacks..". I had to explain the whole thing to him. When we were done he wanted a Subaru WRX.
Myles
Thank you for clearing this up Myles! I will be installing my RCE Black springs with the Bilsteins this week. Can't wait!
TurtleWRX is offline   Reply With Quote
Old 07-27-2013, 02:28 PM   #1738
takeadirtnap
Member#: 344507
2010 Rex
whats next for overland? been a hot minute since a new mod
takeadirtnap is offline   Reply With Quote
Old 07-27-2013, 02:36 PM   #1739
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Haha, it's been a while for sure. Still have the entire interior blackout to do. All the parts are in, just need to find time.
I've been doing a lot of side work lately for other members so its been taking up all my free time. Interior Alcantara work, headlights, coilover covers, traction control bypasses and now shift boots!
If anybody's interested I stuff, send me a PM
Cheers!
- Jason
Old 07-27-2013, 02:50 PM   #1740
NBRX
Member#: 356927
'15 WRX Limited
World Rally Blue
Post some pics
Old 07-27-2013, 02:57 PM   #1741
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Post some pics
Can't post things on here. I just started a FB page last week to post some images. I have a lot to post still, but it's a start.
Facebook.com/OverlandDesigns
Old 07-27-2013, 03:16 PM   #1742
NBRX
Member#: 356927
'15 WRX Limited
World Rally Blue
Gotcha, I'll def check it out.
Old 07-29-2013, 10:42 PM   #1743
zohh_amaze
Member#: 158592
2011 WRX 5-Door
Hey Jason, I sent you a PM and was wondering if you got it? Thanks!
zohh_amaze is offline   Reply With Quote
Old 07-29-2013, 10:47 PM   #1744
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Whoops, it's in there but man I need a secretary for that inbox, haha. I'm replying now.
Old 08-01-2013, 10:32 AM   #1745
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
So as I mentioned in some earlier posts, not too much going on with my own car lately. I did head out early this morning a make a couple photographs in the fog. I haven't taken a full car shot in a while so you may notice some changes. The side-skirts, rear aprons, and fender badges were added. I really like the way they complete the black/white contrast of the car.
Old 08-01-2013, 11:24 AM   #1746
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
I think it would look good with a second polarization on the windshield.
xluben is offline   Reply With Quote
Old 08-01-2013, 11:38 AM   #1747
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Haha, I've officially given up on the Polorizor. I've learned to live with the reflections since that is what I see when I looked through the lens. Too much work involved blending images together and breaking out a tripod in this location anyway. I'm basically standing in a foot of water, lol (it was an old boat launch)
Old 08-01-2013, 11:41 AM   #1748
GJL44
Member#: 248748
2011 STi SWP
04 WRB WRX wagon (RIP)
Did you get the real R205 skirts or the Bayson R ones?
GJL44 is offline   Reply With Quote
Old 08-01-2013, 11:45 AM   #1749
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
Haha. I agree that the reflections aren't really a big deal. But when I compare my before and after I always like the fully polarized ones more.
PS. I shoot mine hand held and have Photoshop do all the work. There is literally no manual aligning or blending done at all.
Old 08-01-2013, 11:48 AM   #1750
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
They are replicas in fiberglass. In theory, the real ones would be nice but not for the beating they will take during the winter. I'd rather run replicas and break them each year than purchasing the real skirts and have to take them off each winter. It's the nature of the north east
First Subaru ordered, '12 WRX hatch to be my daily driver MacNugget Newbies & FAQs 54 02-17-2012 03:07 PM
Is it wise/practical to shoot for 300whp in a daily driver 04 WRX? JonM in MN Newbies & FAQs 76 12-17-2006 12:50 PM
looking to upgrade my daily driver drifterx Outback Forum 1 09-30-2005 05:30 AM
looking to upgrade my daily driver. drifterx North West Impreza Club Forum -- NWIC 15 07-27-2005 10:32 AM
I want to get a daily driver Kuonji Off-Topic 9 05-11-2004 11:11 PM
