Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 01-14-2012, 11:22 PM   #1
b20vtec
Member#: 83452
2011 Impreza STI
Default Data Log Review 2011 STI Stage 1
Hello, Please review the attached data logs.
2011 STI
93 octane
Stage 1 93 boost select v301 in S#
Temp 27 degrees
4th gear pulls
Totally stock
The second map seems to have a small amount of feedback knock. According to this video
I am within the normal 1.5-2.0 range. Please provide feedback.
https://docs.google.com/spreadsheet/...hl=en_US#gid=0
b20vtec is offline   Reply With Quote
Old 01-15-2012, 09:25 AM   #2
Smokin' Joe
Member#: 219679
2011 Impreza WRX
V20-Vtec, the first log is really good. The second one is tapering off and, like you said, not in a harmful range. Nothing to worry about now, but something to keep an eye on. Since you have a rather new car, then you can expect it needs time to relearn a bit again.
Smokin' Joe is offline   Reply With Quote
Old 01-15-2012, 10:23 AM   #3
Cobb Tuning
Member#: 4803
2011 STI
93 octane
Temp 27 degrees
4th gear pulls
Totally stock
The second map seems to have a small amount of feedback knock. According to this video AskCOBB - Subaru Data Logging - YouTube I am within the normal 1.5-2.0 range. Please provide feedback.
Hi there. You are getting a boost spike in both logs which means the boost tune it is too aggressive for your particular car. We have low wastegate (LWG) versions of the map you can download from our map repo:
http://www.cobbtuning.com/info/?ID=3061
Simply use the AccessPORT Manager software to transfer the map to your AccessPORT and then reflash that map to the car. This should get boost back in line to where it needs to be (and reduce/eliminate the boost spike). Take another log after you reflash to make sure.
Bill
Old 01-15-2012, 11:11 AM   #4
b20vtec
Member#: 83452
2011 Impreza STI
Thank you for the reply. I will update the map and post the new results later on today.
Old 01-15-2012, 11:41 AM   #5
b20vtec
Member#: 83452
2011 Impreza STI
Bill
Hello Bill, can you point out where the spike Is so I know what to look for. I see it climb to 17 then taper off like I read it should. Thank you for your time.
Old 01-15-2012, 12:22 PM   #6
Cobb Tuning
Member#: 4803
Take a look at the TD Boost Error parameter. This is (target boost - actual boost). Target boost is what the ECU intends to target according to your map, altitude and potentially intake temp. You "spike" over 1 psi over the intended target and then it drops back. If it is doing this in 3rd/4th gear, you can bet that in higher gears (5th/6th for STi), it will be worse.
Bill
Old 01-15-2012, 04:09 PM   #7
b20vtec
Member#: 83452
2011 Impreza STI
Ok just about the same conditions as before but with the new Stage1 93 Octane Boost Select LWG as you requested. It definitely took boost out of the car. Is this on target for a 2011 sti in 4th gear?
2011 STI
93 octane
Temp 24 degrees
4th gear pulls
TD boost error has a -7.47 entry after I got off the gas. Is that ok? The rest of the log seems ok. Please review.
Old 01-16-2012, 09:08 AM   #8
Cobb Tuning
Member#: 4803
2011 STI
93 octane
Temp 24 degrees
4th gear pulls
The logs look better. You are still hitting your target (in fact, mostly a little above your target). I would stick with the LWG map.
Bill
Old 01-16-2012, 10:01 AM   #9
b20vtec
Member#: 83452
2011 Impreza STI
Thanks again for the feedback. I will stick with the LWG map.
2011 sti stage 1 on AP question 08WRBsti AccessPort 16 05-19-2013 12:53 PM
Data logs from 05 STi, Stage 2 OTS danny_d19 AccessPort 19 08-22-2012 11:31 AM
2010 Cobb Stage 2 Data Log Review WRXineohP Engine Management & Tuning 5 01-04-2012 08:36 AM
2011 STI Stage 1+AEM vs Stage1+Cobb SF glamcem Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 47 12-04-2011 12:41 AM
Help analyze log, 2011 STi Stage 1 OTS knock event RoninSTI AccessPort 7 08-07-2011 01:43 PM
