Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 01-15-2012, 12:56 AM   #1
docNUCCA
Member#: 242377
2006 Legacy GT Wagon
For Sale
Default Boost leak test needed
Suggestions for who can do a boost leak test for me?
Running a GM boost control solenoid and Turbo Smart manual boost controller in a "hybrid control" set-up on my LegacyGT.
Mpg is way down, car is running way lean (adding 20% fuel according to code that was read), Cylinder #2 misfire, coil pack was changed out, plug looked good and compression tested good. Car ran great for one afternoon and then sputters under boost, mpg way worse and CE light came back again, Cyl #2 misfire again
Who do you guys like for a boost leak test?
Thanks for the help.
docNUCCA is offline   Reply With Quote
Old 01-15-2012, 01:00 AM   #2
WRX N EFX
Member#: 157721
2003 WRX
Im having the same problem the car just has no juice under boost, it just starts misfiring when i get on it. I just got my boost leak done at solid auto.
P.S. keep me posted if you figure something out.
WRX N EFX is offline   Reply With Quote
Old 01-15-2012, 03:40 AM   #3
Eww Evo
Member#: 299687
TT2
06' Wrx Project
I built my own Boost leak tester and did the Job well.
Eww Evo is offline   Reply With Quote
Old 01-15-2012, 04:26 AM   #4
rkl303
Member#: 171314
2008 STI
http://www.iwsti.com/forums/how-inst...ak-tester.html
Here's the link to a DIY. You could probably get away with just the
(1) 1/4" air reel lead in line
(1) 2" to 1/2" pvc reducer (threaded)
(1) 1/2" to 1/4" threaded reducer
(1) thread seal tape
1/4" male air line fittings
If you stole someones air compressor, as I believe they already have regulators on them. Otherwise harbor frieght is probably going to be the cheaper option for a regulator.
rkl303 is offline   Reply With Quote
Old 01-15-2012, 09:59 AM   #5
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
It's really easy to do it yourself.
car_cursed is offline   Reply With Quote
Old 01-16-2012, 09:51 AM   #6
docNUCCA
Member#: 242377
For Sale
what about the tip of having to pinch off all the other assorted lines?
I thought it was simply pull the afta-maf, insert tester and add line pressure..... to hear the leaks?
Also, what about the worry of pushing out cam seals?
Old 01-16-2012, 10:05 AM   #7
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
There is 3-4 lines that come off the turbo inlet pipe that need to be pinched off. If you dont pinch them off you will fill the oil pan up with boost which in turn will make your dip stock pop out and spray oil all over it sucks.
You normally only pressurize the system to the amount of boost you are running in the car, so you shouldn't have an issue pushing out cam seals. Especially if you pinch or plug the lines off on the turbo inlet. Its nice to be able to test the system right after the turbo that way you don't have to plug all that stuff, but this really only works with fmic.
bhhamblin is offline   Reply With Quote
Old 01-16-2012, 11:02 AM   #8
Eww Evo
Member#: 299687
TT2
06' Wrx Project
With TMIC pinch the lines as well on the turbo inlet? Or what would you recommend with TMIC?
Old 01-18-2012, 07:09 PM   #9
subtech02
Member#: 215613
are you sure its a boost leak it sound like something else. like bad injector which these cars are famous for or the issue around the seals on plastic half of the intake or the blue tie by the intercooler that pops apart.
subtech02 is offline   Reply With Quote
Old 01-18-2012, 07:18 PM   #10
docNUCCA
Member#: 242377
For Sale
^^ Smart man!
Had an air leak at Throttle body to TMIC hose (TB side of things) that didn't fix anything.
Solid Autoworks confirmed that injector 2 appears to be stuck wide-open and waiting for injector warranty information at this point.
850 side feeds from Five O Motorsports purchased through metric motors.
Old 01-18-2012, 07:51 PM   #11
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Damn, this is the second set of side feeds from them i've seen do this. At least they idle well when they dont stick
907Bum is online now   Reply With Quote
Old 01-19-2012, 12:07 AM   #12
docNUCCA
Member#: 242377
For Sale
Five O will have another injector on its way tomorrow. Maybe now the flooded starts during warm weather will also be a thing of the past???
Old 01-19-2012, 01:50 AM   #13
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Should be good now
Old 01-20-2012, 01:41 AM   #14
docNUCCA
Member#: 242377
For Sale
update: Five O fed ex'd overnight a complete set of 4 so that I'd have a flow matched set by Friday AM.
Should be good now
need help with a boost leak test suBerSam Southern California Impreza Club Forum -- SCIC 6 09-11-2010 12:37 AM
need advice on boost leak test and tester??.... pnut2345 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 01-11-2010 12:50 PM
Need help with boost leak test Sausage Newbies & FAQs 7 12-05-2007 09:10 AM
Boost leak test....need help Tronner Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-15-2007 09:52 AM
I did a boost leak test..and found some intresting leaks. BoostedAWD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-13-2004 08:56 PM
