Old 01-15-2012, 04:39 AM   #1
RolySaul
Member#: 294005
Default Cat Converter knowledge: Need U guys to dumb something down a little for me lol
Greetings Nasioc, brand new member here, and I have a seemingly common (p0420) cel problem. I'm getting my first basic knowledge here, so please bear with me if I seem like a helpless baby.
I'll try to minimize the puke down your back and the crying, as for the constant drooling and occasionally soiling myself, 49 years later nothing seems to work so I can't promise anything..
The car: '07 i wagon, totally stock, impeccably maintained to this point, running perfect as far as I can see, smooth idle and low rev power, compression seems like a new motor, and it hauls serious torque all the way to 120k which is as fast as I've taken it. It started to throw p0420 at an outside temp of -15 celsius, about +5 farenheit. I drove it for two days at warmer temps with no codes, so I dunno if that's a clue. I haven't as yet noticed any smoke or smells indicating a rich mixture which I understand will damage the cat converter relatively quickly.
Basic n00b Cat Converter and P0420 questions.... part 1
I get what the cat converter physically does I think, thanks again to Nasioc, and all the info I've read so far generally narrows the culprits for p0420 to the cat or sensors bracketing the cat. I understand that there are less common causes from sensor wiring, fuel mixture problems, and more, but I'm starting with these because of my limited knowledge..
1. What exactly fries first if I just removed the cat converter from the equation, as in not there at all, just a pipe? Does any backpressure change ruin other components like valves upstream, or timing ,or muffler even? I don't intend to ever do this, but I wanna know what specific impact it's gonna have if I have a "blowout " of the guts in it. This code has me totally paranoid, the car is only three days old to me, and if the cat converter "blows" and friggin metal dust comes blowing out the tailpipe, do I drive it around like normal , or just drive to a garage, or pull over and tow it??
2. How will I know when it lets go or somehow reaches 0 efficiency? Would the car die? After all the searches I've done here, I find one camp that says "I run catless and have done so for 20 years", and another camp that says " if you mess with the cat or sensors at all, you're begging for fuel mixture problems which will eventually make your cat problems seem like a picnic", another camp that says "just put the ol antifouler kit on it and drive like normal", and the final camp that says "try the resistor thingy and spoof the sensor voltage". All the info seems to be conflicting to me, or is it that I am so thick that all 4 camps are talking about completely different areas yet it SOUNDS like the same exact issue to me?
3. Does the cat in a NA 2.5 stock motor just reduce emissions? Does it have any other reason for being? IF it isn't there does it mean my car would never pass emissions testing, even if the rest of the aggregate emission factors were excellent?
I have thousands of questions, but I guess I better shut this one down for now. Thanks for any general cat/emission reduction theory or specs anybody can point me too also, Ive searched a lot but my problem is now info overload, if someone could help me narrow it down it would be most welcome.
P.S. Just noticed the n00b forum, sorry if I'm supposed to post there first. I apologize to the Mods, I love this site and will try to play by the rules.
Last edited by RolySaul; 01-15-2012 at 10:48 AM. Reason: Maybe should be in the Newbie Forum, also some typos
RolySaul is offline   Reply With Quote
Old 01-15-2012, 01:50 PM   #2
bluesubie
Member#: 767
04 FXT
Over at subaruforester.org, a couple of folks have had some short term success removing the cat and giving it a citrus bath. I haven't followed up on the thread lately for updates though. After a year of constant resets with a scan tool, I gave up and replaced the cat in my 2000 RS.
There are various threads on the forester board, but this sticky should keep you occupied for a while.
http://www.subaruforester.org/vbulle...reshold-19374/
-Dennis
Old 01-15-2012, 05:40 PM   #3
rick-l
Member#: 33868
2003 wrx
srp
First piece of knowledge you need is that if there is less than 80,000 miles on the car it is under warrantee.
rick-l is offline   Reply With Quote
Old 01-15-2012, 07:54 PM   #4
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
That's pretty cold - perhaps your cat or your sensors are failing to reach proper operating temp, which might throw off the ability of the system to produce the results the ECM wants to see.
CosmoTheCat is offline   Reply With Quote
Old 01-15-2012, 09:48 PM   #5
RolySaul
Member#: 294005
Thanks Blue, that thread is full of new info. Like 80 something pages worth....
And no, the car has 143,437 klicks on it which I guess is a little over 80 k miles so no recall or freebies, but for a 5 year old car it looks and runs like new in all respects. I reset the code and have about 100 miles mostly highway on it since then, no code, but I understand that it may take weeks or months for the code to post again, which disturbs the hell out of me right into 2 MORE questions....
If I have a provable chronic enrichment problem , shouldn't it post a code after the car cycles every couple of times????
Does this really mean that the mixture problem only occurs every couple of weeks? What am I missing here?
Old 01-16-2012, 08:28 PM   #6
CosmoTheCat
Member#: 3409
98 My FMIC
Perhaps it's the temperature.
Old 01-18-2012, 10:44 AM   #7
leecea
Member#: 37359
2003 WRX
To try and answer some of your questions:
The cat is there to reduce emisisons and serves no other purpose. Running without a cat will not harm anything assuming you can trick the downstream sensor into thinking things are normal.
I've read a few things on this code because I have it on another car (Honda). I've never heard of the cat just completely falling apart and blowing out of the tailpipe. It may become cracked or detatched and rattle around but I doubt it will fail in the way you describe.
Not sure what emission inspection rules govern you - in my area they use the OBD port to check emissions on newish cars, so people can get away with stuff that wouldn't pass other types of check.
I have used the antifouler solution.
leecea is offline   Reply With Quote
Old 01-18-2012, 12:33 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I would ignore it...dont reset it...just monitor it....until it warms up a bit
if warmer temps eliminate the issue....then you are all good until next winter, most likely
you may want to run a bottle of fuel injector cleaner through it to see if that helps clean out the injectors..clogged injectors may be 'helping' your issue
you could also try several other things that may or may not do anything....but it may just be time for a new rear o2 sensor soon
Old 01-18-2012, 11:00 PM   #9
RolySaul
Member#: 294005
Thanks for all the help guys, thru my research I am finding out a few things...
P0420 is just about the most common code thrown regardless of make or model, and is known to be caused by many different problems. Because the car is running perfect to the senses, I am reluctant to start pulling parts because the code was thrown once, especially in cold cold weather.
Scotty, I did reset it before I read your post, and have about 150 miles on it since then, no code. What really gets me is that the system keeping track of the gas content in the exhaust may take weeks to throw a code for something that should be apparent every cycle IF it's a chronic problem.
Believe me I have read a lot of stuff about how unreliable 420 codes are, how many causes there are for it, and about how undependable the computers are in the first place.
I will take the car in to have the exhaust gases read, hopefully that will tell me if I have a mixture problem that may cause big problems down the line.
If anything noteworthy happens I may resurrect the thread in future if that's ok by the rules.
i need u guys to think for this one 06clonesti Southern California Impreza Club Forum -- SCIC 15 12-23-2009 07:49 PM
HELP!!! I need you guys to explain something to me... ENZO'SREX Newbies & FAQs 4 09-27-2006 08:41 PM
Someone buy this for me!! LOL Jk! ice_bomb Tire & Wheel 0 09-30-2005 02:15 AM
Ever have to dumb things down for the smart people? Sephro Off-Topic 25 06-21-2005 03:50 PM
We should all chip in and hire this guy to do something Eric SS Off-Topic 10 05-12-2004 07:58 PM
