Old 01-15-2012, 06:49 AM   #1
eg33GC
Member#: 206851
56 Belair
Pro Street
Default 92-96 map sensor limitation (psi)
making a tune now for z32 maf, 850cc, and 20+psi
I have 24.9psi as the limit for the early style map sensor. anyone else confirm?
eg33GC is offline   Reply With Quote
Old 01-18-2012, 03:29 PM   #2
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
limit is 1.25bar relative which is ~18psi
rob is offline   Reply With Quote
Old 01-19-2012, 06:33 AM   #3
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Correct. The later 1997-1998 EJ20G/EJ20K MAP can read higher.
Marnix is offline   Reply With Quote
Old 01-19-2012, 07:03 AM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
marnix is that a direct replacement, barring wiring?
really need to work around this
Old 01-20-2012, 08:00 AM   #5
pmugabi
Member#: 280926
It is a direct replacement, bolts are the same placement and hose is the same size. Just drop it in and boost limit will be raised by about 0.4bar.
pmugabi is offline   Reply With Quote
Old 01-20-2012, 06:39 PM   #6
eg33GC
Member#: 206851
56 Belair
Pro Street
thanks, as usual paul.
Old 01-21-2012, 10:09 PM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
If the sensor calibration tables are not changed to match the new MAP sensor, then the ECU will miscalculate boost readings and atmospheric pressure corrections.
Old 01-22-2012, 05:41 PM   #8
eg33GC
Member#: 206851
56 Belair
Pro Street
Temp based idle fuel enrichment8060Mass Air Meter Translation8080RPM scale for fuel tables8100Load scale for fuel tables8110Primary Fuel8120RPM scale for ignition tables84d0Load scale for ignition tables84e0Primary Ignition timing8500Ignition revision table87c0Max pulse width88f0Max boost8918RPM scale for boost table8920TPS scale for boost table8928Boost table8940RPM scale for max wastegate solenoid duty8990TPS scale for max wastegate solenoid duty8998Max wastegate solenoid duty89a0TPS voltage scale for Mass Air failure table8cb0RPM scale for Mass Air failure table8cb8Mass Air failure fallback table8cc0
any of those worded differently than what I'd want?
I can only raise fuel cut to 1.73bar with romraider.
I understand if you don't want to help. I'll be releasing the finished version free and opensource.
Old 01-22-2012, 05:42 PM   #9
eg33GC
Member#: 206851
56 Belair
Pro Street
should add that the maf scaling for the z32 maf is DONE. so anyone that wants to add it to their rom can have it
Old 01-22-2012, 06:16 PM   #10
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Not sure exactly what you are asking? There are some in your list that I don't have or use. Did you figure them out from the disassembly or another listing?
The boost cut max value is limited by the 8bit value the ECU uses. There are other limiters you have to worry about in addition to boost cut.
Glad to hear you have a Z32 transfer table. How did you come up with it? I have mine done, but need a lot more testing before I am comfortable making it available. I am curious how our curves compare. Again, there are other considerations than just the MAF table.
-Rob
Old 01-22-2012, 07:45 PM   #11
eg33GC
Member#: 206851
56 Belair
Pro Street
what interface are you using to make the scaling palpable? I have the code if you want to exchange your definition files for RR or the like
Old 01-23-2012, 07:10 PM   #12
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
lots of excel mostly. One day I'll share my deep, dark ECU secrets
But again just FYI, there is more to MAF scaling than just the changing the fuel scalar and the MAF transfer table.
-Rob
Old 01-23-2012, 08:51 PM   #13
klys
Member#: 225974
2012 Impreza WRX
Plasma Blue Pearl
can a Z32 curve from nistune work (VQ table)?
for me it's easily avaible
klys is offline   Reply With Quote
Old 01-23-2012, 08:54 PM   #14
eg33GC
Member#: 206851
56 Belair
Pro Street
pm me
Old 01-23-2012, 09:41 PM   #15
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It is a good place to start.
Old 01-23-2012, 10:33 PM   #16
eg33GC
Member#: 206851
56 Belair
Pro Street
my major issue is i am NOT familiar with romraider, so I am trying to figure out how to add a maf scaling tab.
anybody have any insight? I'd use tunerpro but I am not redoing 10 tables in that just to get a maf scaling table.
my start so far:
injector scaling (850DW)
guess-n-go maf scaling by adding just raw code from 8080-80FF
added base timing a few degrees for closed loop operation to get the ball rolling (e85)
paul's pop and bang extravaganza
I need to figure out how the injector latency is setup in the code so I can add a half or full ms.
This is a lot more fun and difficult than the na 6 tuning was.
FS: Cobb MAP sensor adapter and Zeitronix 3.5 bar MAP sensor crashnscar Engine/Power/Exhaust 5 12-12-2010 06:54 PM
FS : AEM 3.5 Bar MAP Sensor and Cobb MAP Sensor Adapter [email protected] Engine/Power/Exhaust 2 08-18-2010 06:58 PM
WTB : ID2000cc injectors, AEM 3.5bar map sensor, Cobb Map Sensor Adapter Onyx10 Private 'Wanted' Classifieds 0 07-23-2010 02:01 AM
Someone please confirm... Stock MAP sensor limit? fc3swrx Engine Management & Tuning 0 06-13-2004 01:12 PM
RS-T Map sensor limit? (and detonation questions) Daveish Normally Aspirated with bolt-on Forced Induction Powertrain 3 12-01-2002 01:14 PM
