Old 01-15-2012, 01:41 PM   #1
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Default Plasma/Ni-sil sprayed cylinder liners
Has anyone heard of this?
The new 2013 650hp Ford Shelby GT500 is sporting an all aluminum block with plasma sprayed liners. They say it should be good for 150,000 miles of abuse.
They cycled the motor on an engine dyno for 250 hours between peak torque and peak horspower to make sure it was up to the task.
So whats the deal is it possible that this plasma or Ni-sil spray tech on our huge turboed 4's with the extreme cylinder temps may work well?
TDagen is offline   Reply With Quote
Old 01-15-2012, 01:52 PM   #2
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
That sounds REALLY expensive.
Psychoreo is offline   Reply With Quote
Old 01-15-2012, 01:57 PM   #3
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
^^^ This but in for any info lol
binjoau is offline   Reply With Quote
Old 01-15-2012, 02:00 PM   #4
Psychoreo
Member#: 79643
2015 WRX STI
I mean, how often do liners fail?
Isn't it usually a bearing that spins or a piston giving up on life?
Old 01-15-2012, 02:12 PM   #5
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
It is expensive, I think I seen it being done for about $210 per cylinder. But if your going for big power this may be an alternative to sleeving.
This isn't going to be needed for most setups out there, but could be insurance for setups running 600whp +
Old 01-15-2012, 11:36 PM   #6
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
They have been doing this in sportbike blocks for probably 10 years now. I don't think it would help hold any more power, just maybe last longer. In the bikes they did this instead of a steel liner. Just Nic-Sil in an aluminum bore.
Crazykev is offline   Reply With Quote
Old 01-16-2012, 12:21 AM   #7
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
It must be working if they are doing the plasma spraying on the new 650hp shelby and its and all aluminum block running 15psi. The previous shelby had steel or iron liners.
Old 01-16-2012, 08:07 AM   #8
CatfaceType-R
Member#: 81102
Interesting, I would think that adding any reliability would be something we should all be looking at.
CatfaceType-R is offline   Reply With Quote
Old 01-16-2012, 08:24 AM   #9
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Porsche has been doing this since the 70s.
ASF Machine is offline   Reply With Quote
Old 01-16-2012, 08:28 AM   #10
EmaciatedCow
Member#: 170373
98 Forester
15 wrx pshhh
^this
EmaciatedCow is offline   Reply With Quote
Old 01-16-2012, 10:11 AM   #11
AMS
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
The vr38 from the GTR is also plasma lined from the factory. The only downside is that it can't be bored if you have problems with the engine and need to go to a larger bore piston in the future. The liner would need to be resprayed.
-Ty
AMS is offline   Reply With Quote
Old 01-16-2012, 11:09 AM   #12
brutnus
Member#: 257195
2004 WRX
2.1L
so from what i gather from this thread is its been done for years by other people but ford is coming out like its ground breaking?
brutnus is offline   Reply With Quote
Old 01-16-2012, 11:20 AM   #13
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
I think its just new for the Ford crowd not that they are breaking new boundaries
Old 01-16-2012, 12:47 PM   #14
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
The big companies that do this are in Wisconsin, US Chrome is one of them. I asked them about doing this to subaru bores about 6 years ago. They told me it is not possible because of the composition of our liner material.
had well over 60 motorcycle engine cylinders done by them over the years
Team Scream is offline   Reply With Quote
Old 01-16-2012, 12:51 PM   #15
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Who said ford is acting like its ground breaking? Ford is acting like they have a 650hp boosted car coming out next year.
I just happened to look at the specs of the all aluminum block and it sparked my interest. Anyone making cylinder cracking power should be interested.
Old 01-16-2012, 12:55 PM   #16
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Ok cool thanks for the heads up!
Which one did they say isnt possible is it the plasma coating or the Ni-sil coating?
Old 01-16-2012, 02:50 PM   #17
MartinSTi05
Member#: 145145
2006 wrx STi
I don't think this process will do anything for you when it comes to cracking a cylinder. This process simply allows the liner to be sprayed on yielding better heat transfer and mitigating the issue of thermal expansion differences between the block/dissimilar liner. If you somehow cast an EJ block with no iron liner, and alum bores I have a feeling it would be weaker than a sleeved block.
I doubt ford did this due to mechanical strength. The superior heat transfer helps the integrity of the oil film and allows you to run a tighter PTW clearance because the block more effectively pulls heat from the pistons. This is attractive from an OEM perspective.
MartinSTi05 is offline   Reply With Quote
Old 01-16-2012, 04:32 PM   #18
k mier
Member#: 98000
05 sti [email protected]
Closer to 30 years ago in mx bike applications. Better heat transfer, wears many times longer than sleeves, weights less. Weight is a major concern in mx bikes.
k mier is offline   Reply With Quote
Old 01-16-2012, 05:08 PM   #19
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Cool, didn't know that. Huh, I am K Meyer.
Old 01-16-2012, 09:52 PM   #20
Team Scream
Member#: 121532
2006 FXT/STi 6MT
To add to this ^^ or perhaps add my experience with NiCom or NikaSil, it is not so much the heat transfer properties that add value or benefit, but rather the increased hardness it imparts to the original liner material (cylinder bore).
It makes the bores a lot more durable, and less likely to score and develop grooves, which then leads to poor ring seal, and blowby.
I would do this in a heartbeat if it could be done to our liners.
Old 02-07-2013, 04:52 PM   #21
Scargod
Member#: 260314
2008 STI hatch
I was told by two shops (that build Subie motors), that the cylinder wall of my late model 2.5L engine is hardened and one compared it to a Porsche engine cylinder.
I was told that if I honed it I would loose some of the hardened surface.
The other agreed it was hardened and suggested it was, or was like, Nickel-Silicon-Carbide (Nikasil/Nicosil/NiCaSil).
Now, isn't it common to bore cylinders .25mm over and more? Aren't these just ordinary ductile iron sleeves and nothing fancy?
Scargod is offline   Reply With Quote
Old 02-08-2013, 12:16 AM   #22
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
GTRs make in the excess of 1500whp with OEM Plasma coated liners
Junior2JZ is offline   Reply With Quote
Old 02-08-2013, 05:52 AM   #23
Scargod
Member#: 260314
2008 STI hatch
I thought we were talking Subarus... I had chrome lined cylinders on my Porsche, too. Doesn't get me any closer to a straight answer.
factory cylinder liner Vmiz Built Motor Discussion 5 06-21-2008 03:53 PM
For Sale: 05-07 Intercooler Spray Tank/Trunk Liner/Switch kennyvb SCIC Private Classifieds 25 02-13-2008 11:06 AM
SoCal: 05-07 Intercooler Spray Tank/Trunk Liner/Switch kennyvb Engine/Power/Exhaust 2 02-01-2008 03:45 AM
FS: 05 Sti Trunk Intercooler Spray Tank, Trunk Liner & Button jason.g Interior/Dressup/Audio & Security 6 07-09-2007 12:58 PM
Recommend a spray in bed liner company for me in PDX? I know it's a Subie forum But.. Safe Drives North West Impreza Club Forum -- NWIC 12 03-25-2007 03:06 PM
