Old 01-15-2012, 09:04 PM   #1
Browzer
Member#: 306433
2005 Subaru WRX
Default Smoke coming from engine.
I just bought my car and I took it for a drive today and after an hour arrived home and was letting it cool down because i was kinda pushing it a little hard just to see how it felt (awesome btw)
But as I was sitting in my car idling in my drive way I noticed somke coming from the engine.
The temperature guage didnt register and change but I shut the engine off and popped the hood. It smelt like coolant, but I could be wrong.
My car is all stock Just bought it, I called the dealer and left a message because they werent there.
I know that in my old car I installed a SRI which required the coolant hose to be redirected and due to my shoddy install, was causing a coolant leak in the engine bay and making the temp guage turn up.
But I never got and smoke from that.
If anyone has an idea as to what it could be that would be awesome. But ultimatley its the dealers problem, I mean I JUST bought it.
Browzer is offline   Reply With Quote
Old 01-16-2012, 08:32 PM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Did you get a warranty with that?
The temp gauge didn't register... at all?
Were your cooling fans coming on?
Sounds like you're going to need some new head gaskets, machining of heads... expect a couple grand.
I hope you got a warranty.
CosmoTheCat is offline   Reply With Quote
Old 01-16-2012, 08:46 PM   #3
Browzer
Member#: 306433
2005 Subaru WRX
yeah theres a warranty and the temp gauge stayed the same.
idk if the fans were on. it was extremely cold out.
i dont think its that serious because like i said, I did see coolant leaking.
Old 01-16-2012, 10:33 PM   #4
flycaster
Member#: 60142
2011 WRX
Grey
Coolant smells sweet, oil smells like bad BBQ. Have you checked all your fluid levels?
flycaster is offline   Reply With Quote
Old 01-16-2012, 10:44 PM   #5
Browzer
Member#: 306433
2005 Subaru WRX
yeah it smelt like coolant. Ive had coolant spill in my old car and i know the smell. but it could be something else i mean the engine smelled like alotta things lol.
the fluid levels seem alright. the reserve tank was halfway full.
Old 01-17-2012, 10:00 PM   #6
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
I'd check your head gaskets. Look for seapage of oil and/or coolant from the head. Is coolant spewing all over the engine? If it is, change your coolant cap out. If it continues, probably a bad head gasket, as the cooling system may be over pressurized...the worst news many subaru owners have faced head on is a bad head gasket
Blur125 is offline   Reply With Quote
Old 01-17-2012, 10:19 PM   #7
Browzer
Member#: 306433
2005 Subaru WRX
yea. bad news. took it to the mechanic today. theres like 6 things wrong with it. I forgot em. I have em written down...
the delears gonna take care of it tho.
still really bummed.
Old 01-17-2012, 10:31 PM   #8
Browzer
Member#: 306433
2005 Subaru WRX
Front Tires are bad.
Alignment is off.
Front axle boot is broken which is throwing grease on the exhaust...theres the smoke.
Both vavle cover gaskets leaking.
bolts and nuts missing from turbo.
oil coming out of timing cover? (i could be misreading that)
AND...Power steering pump is low. possible leak...
fml man.
Old 01-18-2012, 01:22 PM   #9
JohnM10
Member#: 244231
2006 Impreza 2.5i 5M
Crystal Grey Metallic
I thought you said you smelled coolant? Was there any coolant related problem as well?
JohnM10 is offline   Reply With Quote
Old 01-18-2012, 05:44 PM   #10
Browzer
Member#: 306433
2005 Subaru WRX
nah the coolant was fine.
Old 01-18-2012, 09:56 PM   #11
CosmoTheCat
Member#: 3409
98 My FMIC
Alignment is off.
fml man.
Oil coming out of timing cover? Front engine seals? 4 new tires?
Sounds like an expensive trip.
Squealing sound coming from engine bay blkbugeye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 01-28-2012 06:05 AM
Smoke coming from engine bay...what is it? minhha2006 Service & Maintenance 26 10-17-2008 04:24 AM
smoke coming from engine bay. oil residue in between hot and cold sides of turbo. ted dibiase Built Motor Discussion 4 05-22-2008 10:51 AM
smoke coming from engine bay Vampyr Newbies & FAQs 9 04-11-2006 11:51 AM
smoke coming from engine bay jcdeng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 02-06-2004 05:53 PM
