Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 01-16-2012, 12:41 AM   #1
dvlsfan30
Member#: 307046
Default in cabin smell
I'm just curious to see if someone can help me. I can't tell if it is exhaust fumes or if it's just bad air from maybe the heater. maybe bad cabin filter but when I have the heat on it's kind of like a musty smell I'm just nervous to make sure I'm not inhaling exhaust fumes. I've had the car for over a year it's a 2002 Bug eye. The smell doesn't make me dizzy or nauseous or anything like that. Im not smart or handy wih cars just looking for help.i want to make sure im not killing myself with whatever it is.
dvlsfan30 is offline   Reply With Quote
Old 01-16-2012, 12:49 AM   #2
subaru606
Member#: 267298
2007 wrx
There is a thread about some fuel line recall for 02/03 search it and u shouls find it
subaru606 is offline   Reply With Quote
Old 01-16-2012, 12:56 AM   #3
dvlsfan30
Member#: 307046
My car had it replaced and its only when the heats on.
Old 01-16-2012, 01:17 AM   #4
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
here's a thread i started a while ago..
http://forums.nasioc.com/forums/show....php?t=2204853
And there's many more...
z is offline   Reply With Quote
Old 01-16-2012, 01:24 AM   #5
dvlsfan30
Member#: 307046
I will try the cabin filter then hopefully thats the problem. Thanks alot guys. Yea mines probably never been changed haha i need to check it
Old 01-16-2012, 01:39 AM   #6
z
Member#: 41762
04 STi
Definitely do it. There's some threads on 'how to'. A bunch of bolts around the glovebox.
You can either buy a subaru one, an aftermarket, or cut up a home depot/lowes filter for a home AC unit and make a bunch for cheap.
Old 01-16-2012, 02:27 AM   #7
dvlsfan30
Member#: 307046
Im hoping thats the problem and its not been bad fumes from the engine. My gf said it makes her car sick but im fine paranoid its exhaust now. I hope its just the filter. Car has 160k im sure the filter is bad either way.
Old 01-19-2012, 02:24 PM   #8
dvlsfan30
Member#: 307046
there was no cabin filter in the car popped one in though. could this have caused the problem? once im back home tonight im going to check if it smells. if it does then i guess it may be exhaust ive been breathing a while -_-
Old 01-19-2012, 03:31 PM   #9
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
Where are you located? Also, what model / year is your car. You should fill out your profile.
Anyway, what I was going to suggest is maybe you're got a lot of moisture in the carpets. I was looking for your location to make an assumption based on where you live. I live in a snowy climate. I was having a funky smell in my car for a while. When it was warm outside, even more so. It was due to having a lot of water under my drivers side floor mat, carpet and padding was saturated.
Check there, and see it's it's wet. You might have to pull it up to suck out the majority of the wetness with a wet/dry shop vac. Then aim a good fan at it, and dry it out.
The smell is gone, and now that I know what to check for, I hope to keep on top of it.
From what I gathered, it's wet from a combination of snow and ice melting, coming in on my shoes, and a missing firewall grommet/plug directly behind the pedals. I will have to look in my parts car, and rob that plug. As for the carpets...
I peeled up the drivers side and shop-vac'd out a lot of water from the insulation pad.
I propped up the carpet and put some towels under them, to catch the water as it ran out.
I added a box fan to the mix and air circulating made quick work of drying it out.
Dominator is online now   Reply With Quote
Old 01-20-2012, 12:32 AM   #10
dvlsfan30
Member#: 307046
Ny and the carpets are dry. I put the cabin filter in gonna check tommorow to see if it is a little bit of exhaust or somethin else since there was no filter in
Gas smell in cabin...not so much in engine bay? Jard Mid Atlantic Impreza Club -- MAIC 39 03-24-2006 12:51 PM
Turbo back and exhaust smell in cabin? ChrisF Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-08-2002 11:34 PM
Oil smell in cabin? PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-03-2002 11:39 PM
Exhaust smell in cabin gavin Legacy Forum 4 04-24-2002 12:25 AM
