Old 01-15-2012, 11:51 PM   #1
vince769
Member#: 277403
2005 STi
Default AccessPort and AEM Tru Boost
So I hope this makes sence....
Okay so I'm running a stage 2 pro-tune on my 05 STi and the boost is set at 18.5psi now I have just installed a AEM Tru Boost EBC and wanna know if it is going to create any problems seemings how the stock boost controller is no longer hooked up? I know the AccessPort tune WAS keeping the boost in check. So what I wanna know is if I should set my AEM EBC to 18.5psi? or if i will run in to problems since the car's computer no longer knows how much boost its running?
**hope I posted this in the area**
vince769 is offline   Reply With Quote
Old 01-16-2012, 09:37 AM   #2
Cobb Tuning
Member#: 4803
The car's computer (ECU) will still know how much boost you are running (as long as you are not messing with the factory MAP sensor) but it will have zero control over boost except for the overboost fuel cut. The factory ECU has a fairly sophisticated boost control system and can control boost based on throttle position, RPM, boost error (how close you are to target), altitude, intake temp, etc. It can also disable boost control when severe knock happens (when DAM drops to a low level). You give that all up when you are running an aftermarket boost controller. So, essentially, you are now tuning boost yourself. This can be dangerous if you don't know what you are doing. There's no reason to do this as the factory boost control system is perfectly adequate, especially at stage 1/2 levels.
Bill
Old 01-16-2012, 03:34 PM   #3
vince769
Member#: 277403
2005 STi
Okay so if I were to bring it in for a new tune would you use the AEM EBC or go back to the factory boost controller? Also this may be a Noob question but would it matter if I turned the AEM boost controller off and spliced in a T fitting to the factory BC? If that makes since at all lol
Old 01-17-2012, 09:51 AM   #4
Cobb Tuning
Member#: 4803
If you previously had a protune with the factory BCS functional and the ECU controlling boost, you are eliminating that part of the tune by installing the EBC (i.e. you are basically tuning boost yourself without consideration for how that will work with the rest of the tune). Certainly, you can get a re-tune (or tweaking) with the EBC installed. This will allow the tuner to verify the "complete" tune given the set-up.
Bill
FS : AEM Tru Boost gauge and solenoid 2man Interior/Dressup/Audio & Security 14 04-24-2012 03:39 PM
FS : AEM Tru Boost gauge and solenoid 2man TXIC Private Classifieds 2 09-10-2011 12:31 AM
For Sale (PA) Perrin VTA BOV, AEM Tru Boost and more!!! Blouchturbo Engine/Power/Exhaust 9 05-09-2009 06:42 PM
For Sale (PA) Perrin VTA BOV, AEM Tru Boost and more!!! Blouchturbo MAIC Private Classifieds 0 01-27-2009 10:00 AM
AEM Wideband and AEM Tru Boost EBC kylestt Engine/Power/Exhaust 20 12-25-2006 07:24 PM
