Old 01-16-2012, 12:38 AM   #1
chancellor6869
Member#: 306289
1995 impreza-L AWD
red but will be white
Default trouble starting, help!
ok here is whats going on, when i go to start my car (1995 impreza) it will start sometimes and run good but when i stop, like go into the store and come out 15 to 30 minutes later it wont start, ill have to push start it, its cranks just fine just wont start, and sometimes if i leave it over night it will start without any questions.....any ideas on what the problem is and how to fix it?
chancellor6869 is offline   Reply With Quote
Old 01-16-2012, 02:33 AM   #2
pmugabi
Member#: 280926
Cam/crank sensor most likely. Check for stored codes to be sure which one it is.
pmugabi is offline   Reply With Quote
Old 01-16-2012, 12:03 PM   #3
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Hook up. Test connectors under dash and get the code number. Remember long flash is worth 10 and short flash worth 1. I believe the codes for cam and crank are 11 and 13. You could also pull the cam and crank sensors and clean them.
TommyAtomic is offline   Reply With Quote
Old 01-17-2012, 10:58 AM   #4
chancellor6869
Member#: 306289
1995 impreza-L AWD
check engine light isnt coming on.....should i still check it?
Old 01-17-2012, 11:06 AM   #5
chancellor6869
Member#: 306289
1995 impreza-L AWD
ive had someone tell me it could be the o ring on the distributor
Old 01-17-2012, 11:47 AM   #6
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
If your being serious - perhaps you should also check your blinker fluid.
Old 01-17-2012, 11:50 AM   #7
Aphex28
Member#: 11506
2000 Silver RS swap
thingy. USDM STI goodness
that person is applying carb solutions to a fuel injected car. and failing
Aphex28 is online now   Reply With Quote
Old 01-17-2012, 12:06 PM   #8
chancellor6869
Member#: 306289
1995 impreza-L AWD
so it couldnt be the o ring?
Old 01-17-2012, 12:08 PM   #9
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Follow the instructions to do an ECU reset. When you do an ECU reset it will do a diagnostic and give you any existing trouble codes via blinking CEL light. The format is pretty simple. Long blinks are worth 10 and short blinks are worth 1. For instance if it gave you two long blinks followed by two short blinks that would be code 22, three long blinks followed by two short blinks would be code 32.
You can either tell us what codes you pull or you can look them up yourself.
Old 01-17-2012, 01:57 PM   #10
Aphex28
Member#: 11506
2000 Silver RS swap
i really hope you're not serious. You don't have a carb.
Old 01-17-2012, 03:21 PM   #11
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
so it absolutely couldnt be the o ring?
There, I fixed it for you.
Old 01-18-2012, 03:08 PM   #12
chancellor6869
Member#: 306289
1995 impreza-L AWD
am i the only one with this problem? lol ima plug it in tomorrow and see if any codes come up......
Old 01-18-2012, 05:29 PM   #13
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I don't think you read his post closely
If he pushes the car and it starts fine its the age old problem all Subaru develop - bad contacts on the starter solenoid.
chancellor6869 : You can replace the contacts but its a pain in the butt. Just get a remanufactured starter. You are not the only person with this problem. Its more common than wheel bearing failures! It is funny someone told you to check the distributor. I hope he wasn't looking under the hood when he said that
trouble starting car yuletak Service & Maintenance 1 01-23-2006 04:34 PM
Trouble starting...coolant sensor, how can that help? Max Umbarger Service & Maintenance 9 10-03-2003 09:44 PM
little trouble starting steppin16 Normally Aspirated Powertrain 5 02-25-2002 01:57 AM
Help! Trouble starting... MagicMT General Forum Archive 6 03-20-2001 08:14 AM
Is anyone having trouble starting in the cold? M a t t General Forum Archive 37 12-11-2000 04:43 PM
Message Board Statistics All times are GMT -4. The time now is 04:52 PM.
