Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 05-16-2013, 03:17 AM   #1
mreed
Member#: 356267
Default 13 WRX Stage 1, Cant reach target boost
Car: 2013 WRX Bone Stock w/ AP Cobb Stage 1
So on my way to work i hit 16.3 psi and the target boost is 15 for the COBB Stage 1 OTS. So when i got home i loaded the LWG map onto my AP and tired to see what i got then, the max i got for that map was 14.1 right now. yes i am using the map for 91 california gas too.
I live in Bakersfield California and its usually about 100. it was probably 98 or so when i hit the 16.3 im not sure if that has anything to do with it, but just providing a little more information. Has anyone else had trouble trying to get target boost on stage 1 OTS map? ill try to get a map for you guys soon to check and see if everything else is good also.
mreed is offline   Reply With Quote
Old 05-16-2013, 01:33 PM   #2
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Drive through at least a tank of gas first, then see where your boosting. The ecu needs time to adjust to the new tune.
Cathexis is online now   Reply With Quote
Old 05-16-2013, 01:43 PM   #3
mreed
Member#: 356267
Ok thanks for the advise. Ill load the regular tune and give it some time and report back.
Old 06-05-2013, 09:49 PM   #4
a3ng25
Member#: 341599
2013 WRX Base
Not sure if you got this worked out but I dont think its the newness of the map. I got my AP today, flashed the stg1 93 stock airbox map in the parking lot and datalogged in third less than 5 miles later, log showed me hitting target boost and tapering off perfectly to redline with no knock issues.
That said, I don't know the fix to your problem, but Id say its likely not the map
a3ng25 is offline   Reply With Quote
Old 06-20-2013, 12:15 PM   #5
Apollo Creed
Member#: 352748
2012 wrx wagon
blue
I just flashed mine to stage 1 93oct sf tune but running the aem cai. target boost is 17.5 and i hit 17.7 and tapers down thru redline it was also a very cool night.
Apollo Creed is offline   Reply With Quote
Old 06-20-2013, 05:29 PM   #6
Thiago13Sti
Member#: 355304
2013 Sti Sedan
Cobb map note says target boost +/- 1 psi. So with the lwg map your hitting 14.1 which is within cobb target boost.
Thiago13Sti is offline   Reply With Quote
Old 06-21-2013, 11:53 PM   #7
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
Impreza WRX STi oops sorry
Ooops, sorry, didn't mean to reply,meant to start new thread
HAL1 is offline   Reply With Quote
Old 07-17-2013, 09:49 PM   #8
Chchappy
Member#: 355459
2013 Wrx premium
Wr blue
I live in Texas, have a 2013 with spt cat back. Flashed stage 1 91 oct and hit 16.5 lbs consistently. The following week, after a tank of gas, I installed cobb sf, no box, and flashed again to 91+sf. Now hitting consistently 17.6 lbs. normally 94-100 degrees here.
Chchappy is offline   Reply With Quote
