Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 08-03-2005, 07:07 PM   #1
Subaru of Plano
Member#: 52637
Default DIY - 15 Minute 02/03 ‘Bug Eye’ Impreza Headlight Blackout!
We know there are a lot of you out there who would like the look of blacked out headlights, but don't have the time/desire/will to take your headlights out of the car, put them in the oven, split them apart, paint, re-assemble, and re-install. So we have come up with another option - and here is the DIY with step by step photos. Enjoy.
Start by thoroughly cleaning both the headlight lens and your hands. Wet the headlight down with water (a plant mister works great).
Carefully remove eyelid from the backing paper using the built in handling tab and mist down with water. The tab portion goes on the outside of the vehicle. Line the top third of the piece up with the near horizontal chrome contour line and gently lay it on the lens.
Gently feel for the alignment of the edges. The top should be about 1/16” from the edge of the lens (chrome portion covered) and each side should be equidistant from the edge.
While the piece is sitting on the water you can gently reposition – the bottom (long horizontal section) of the piece will be flat to the lens while the top ‘sits up a bit’.
When it is aligned, re-wet the surface of the piece, start at the inside corner and gently squeegee. Then drag the squeegee across to the outside along the horizontal bottom edge.
Verify positioning and gently lift and reposition if necessary. When set, go over the squeegeed area once more using a bit more pressure. Now re-wet the piece again, both underneath and on top. Working in short overlapping strokes, squeegee up to the top – working from one side to the other taking small bites until the entire piece is down and smooth. This method distributes the material across the compound curve at the top of the lens.
Now line up the bottom outside portion of the piece with the outside of the headlight housing
Gently squeegee the outside edge.
Repeat with more pressure when you are sure it is line up correctly.
Finish off by squeegeeing into the center of the kit in short strokes – just like you did on the top portion.
Let the kit sit for 10-15 minutes and then carefully trim off the handling tabs with a sharp x-acto knife. It is important to just cut about halfway through or so – don’t jab it in and cut into the light housing…
Subaru of Plano is offline   Reply With Quote
Old 08-03-2005, 07:07 PM   #2
Subaru of Plano
Member#: 52637
Default continued...
Now you can sit back and enjoy your work!
Old 08-03-2005, 07:14 PM   #3
Handsdown
Member#: 29355
interesting.
can you/do you make a red one for the taillights?
Handsdown is offline   Reply With Quote
Old 08-03-2005, 07:23 PM   #4
ein86
Member#: 67817
FRS DeVinci Troy
Smith&Nephew Genesis II
only a year too late for me though ..... i totally would have done it this way
...but i still like mine the way they are
ein86 is offline   Reply With Quote
Old 08-03-2005, 07:48 PM   #5
Moods
Member#: 71961
2003 WRX Sedan
MBP
Agreed here... but only 6 months
Definitely a good alternative and a whole lot less time to do it
Moods is offline   Reply With Quote
Old 08-04-2005, 12:27 PM   #6
Subaru of Plano
Member#: 52637
Thanks, we launched these two weeks ago for the local people and they were a big hit! Sorry, we don't offer red film though.
www.hot-subaru.com
www.pcpcdallas.com
Old 08-04-2005, 01:22 PM   #7
subaru mike
Member#: 30749
2002 wrx
Nice
subaru mike is offline   Reply With Quote
Old 08-04-2005, 01:48 PM   #8
bitterWRX
Member#: 49624
04 AW WRX
13 SWP STi
Do you make them for the passenger side too?
bitterWRX is offline   Reply With Quote
Old 08-05-2005, 11:29 AM   #9
Subaru of Plano
Member#: 52637
LOL Yes you get both sides
Old 08-05-2005, 05:33 PM   #10
HiVoltg12
Member#: 16880
2003 WRX Wagon
Ordered mine yesterday and it shipped today.....pics up soon!
HiVoltg12 is offline   Reply With Quote
Old 08-06-2005, 12:39 AM   #11
turbosporttsi
Member#: 85848
1998 M3
im moving down to san angelo in about 2 months. ill have to stop by and pick a set up!
turbosporttsi is offline   Reply With Quote
Old 08-08-2005, 02:59 AM   #12
Subaru of Plano
Member#: 52637
Post some photos when you get them on, we love photos
Old 10-08-2012, 01:35 AM   #13
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
Has anyone tried this? Have any pics?
Daddy_Digital is offline   Reply With Quote
Old 10-08-2012, 12:15 PM   #14
ravenlunatic
Member#: 180601
2003 PSM WRX
(>")>==HADOKEN==<(o)
lol. check the date, this was 7 years ago...
ravenlunatic is offline   Reply With Quote
FS: Brand New 02-03 Bug Eye WRX Headlights w/Clear Corner kicemocha SCIC Private Classifieds 4 09-29-2008 02:19 PM
FS: Brand New 02-03 Bug Eye WRX Headlights w/Clear Corner kicemocha Exterior/Styling 8 09-29-2008 11:42 AM
DIY - 5 Minute 02/03 ‘Bug Eye’ Impreza Eyelid Film Installation Subaru of Plano Interior & Exterior Modification 11 03-15-2006 01:47 PM
02-03 bug eye WRX Headlights -MINT- ComTekAuto Private 'For Sale' Classifieds 9 02-16-2006 02:10 PM
Hot-Subaru.com – Eyelids and Headlight Blackout Film Kits – 02/03 Bug Eyes Subaru of Plano Exterior/Styling 0 08-03-2005 06:56 PM
