Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 01-16-2012, 11:10 PM   #1
bigdakota
Member#: 89471
Default 2011 WRX long road trip burned a lot of oil
Hey all,
Just moved from NJ to Dallas. I have 10k on the car and had an oil and tranny fluid change right before the trip with Amsoil synth. I arrived in Dallas and noticed a very noisy tranny. I checked the oil and was low on both tranny and motor. I averaged about 90 mph for 3 days at 8hrs a day. I'm not sure if being in boost at 3k rpm for the majority of the driving made it worse?
I added some tranny oil and it sounds a bit better. The motor oil is pretty dark.
Is this normal? Or could the be another underlying problem?
Thanks!
bigdakota is offline   Reply With Quote
Old 01-17-2012, 02:08 AM   #2
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Which weight and flavor Amsoil? I had a problem with the SSO 0w-30 when it first came out, high consumption on 3 different engines it was used in. But also running 90mph for 3 days can indeed show some consumption. As long as it's not 1qt in 1K miles, you're probably ok. Check level regularly.
The gearbox can be tough to get a good level indicator. When I had the gearbox oil changed on my '11 WRX, they filled it to spec, but it ended up being nearly 1/3qt low on the stick after 1K miles. No leaks, just not filled/checked correctly. YMMV.
JamesWilson2 is offline   Reply With Quote
Old 01-17-2012, 07:13 AM   #3
FCP Import
Member#: 305489
91 skyline GTR
champ white
Is this fairly typical in the new WRX's. Im planning a road trip with the fam to NC and wondering if Im going to need to keep an eye out for this.
FCP Import is offline   Reply With Quote
Old 01-17-2012, 07:57 AM   #4
bluesubie
Member#: 767
04 FXT
It's completely normal, especially if you ran Amsoil 0W-30 or 5W-30 and may continue.
-Dennis
Old 01-17-2012, 09:49 AM   #5
SHOfast
Member#: 99083
02 impreza
How low are you talking? Down more than a quart in 2160 miles?
SHOfast is offline   Reply With Quote
Old 01-17-2012, 11:34 AM   #6
bigdakota
Member#: 89471
Thanks guys, I use 5w30 Amsoil synth and 75-90 severe gear tranny oil. The level stated was on the low mark on the dip stick for both.
Thanks for the confirmation guys. I'm gonna do an oil change today. I'm going to try the Motul this time.
Old 01-17-2012, 01:40 PM   #7
SubLGT
Member#: 207528
2005 Legacy GT
I wanna know on what highways in the USA you can drive "about 90 mph for 3 days at 8hrs a day" and not get a speeding ticket.
SubLGT is offline   Reply With Quote
Old 01-17-2012, 02:14 PM   #8
flycaster
Member#: 60142
2011 WRX
Grey
SubLGT, I'm with you on that. Up here in the Pac NW, that just doesn't work, not with all the lazer units being used these days.
At 3K in flat and level cruise, you're probably close to zero boost. Regardless, it shouldn't burn a drop of either fluid at cruise - there's very little load on the motor, even at 90. We've taken 2 trips to SFO in the past month in my wife's WRX, roughly 2300 miles, almost all of it at a steady 70-80 in cruise, and the car burned nothing, nada, ziop.
flycaster is offline   Reply With Quote
Old 01-17-2012, 05:43 PM   #9
bluesubie
Member#: 767
04 FXT
I usually burn oil on trips and I'm at 3500 rpm's at 80 mph. When I drive to SC, that's the speed in the RIGHT lane on I95 through NC.
-Dennis
Old 01-17-2012, 08:11 PM   #10
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
ive driven a few 3-4 hour trips in my 08. never had to add oil in 40 k miles so far.
424wrx is offline   Reply With Quote
Old 01-17-2012, 11:01 PM   #11
bigdakota
Member#: 89471
Ha, I saw 3 state troopers the entire trip and they were in Virginia and Arkansas. I would say 85mph is the average for most of the drivers I've seen on the road so I'm lucky.
Anyways, I'm taking it to a local subaru performance shop in Fort Worth for an oil change and they'll send the oil to get analyzed and see whats up from there.
Old 01-17-2012, 11:35 PM   #12
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
In boost for that long, and you didnt check your oil along the way?
vision.dynamix is online now   Reply With Quote
Old 01-18-2012, 12:49 AM   #13
NcKidd
Member#: 133267
2004 psm WRX
I drove from Charlotte, NC to Portland, OR last summer. The answer to your question is any highway b/w about Nebraska & the Oregon border. I averaged 85-90 mph that whole stretch, but keep in mind the speed limit is 75 out that way, making 85-90mph fairly commonplace. At one point I did 90mph for 16 straight hours...in one long, long, long straight line :/
NcKidd is offline   Reply With Quote
Old 01-18-2012, 01:38 AM   #14
flycaster
Member#: 60142
2011 WRX
Grey
Originally Posted by bluesubie View Post
I usually burn oil on trips and I'm at 3500rpm's at 80 mph...
New motor, old motor?
Old 01-19-2012, 11:57 AM   #15
SubLGT
Member#: 207528
2005 Legacy GT
Originally Posted by NcKidd View Post
.........I averaged 85-90 mph that whole stretch, but keep in mind the speed limit is 75 out that way, making 85-90mph fairly commonplace. At one point I did 90mph for 16 straight hours...in one long, long, long straight line :/
I tried to average 85 mph on my last trip through the "middle of nowhere" in southeast Idaho, in winter. I would literally see another car only every 15 minutes. Came over a crest, and there was the Idaho State Police waiting for me.
Old 01-19-2012, 05:49 PM   #16
bluesubie
Member#: 767
04 FXT
Oil analysis is good but may not be helpful when trying to figure out consumption. I've been doing them since I had 7,500 miles on the odo, consumption started at 60k, and now I'm at 115k.
-Dennis
Old 01-19-2012, 08:59 PM   #17
flycaster
Member#: 60142
2011 WRX
Grey
Dennis, so it burned little/no oil until 60K? That's pretty good. I've had 4 of these cars now and 2 burned @ a qt every 3K from off the lot to over 80K miles; the other 2 never burned anything until they hit 90K, and then only when i pushed them hard, never at cruise. Regardless, it never bothered me either way; oil's relatively cheap.
Some are tighter than others, I guess. Same's been true of most of my other cars too.
Old 01-19-2012, 09:52 PM   #18
bluesubie
Member#: 767
04 FXT
Right, and I always ran GC for the first 60k.
-Dennis
Old 01-20-2012, 04:14 AM   #19
SFBayej205
Member#: 277219
2002 Honda S2000
Suzuka
I'm not sure if the manual says anything different for '11's as far as changing weights. Earlier years gives an acceptable range of weights/viscousities etc.
Anyways, to combat consumption many owners will jump up to 5w40. If your're sold on Amsoil they make 5w40 Euro formula that some guys run and love. Check with Amsoil to see if it meets specifications for an '11 engine.
I run either 5w40 Rotella or Motul 8100 5w40. My car doesn't consume a drop and it has over 100k.
SFBayej205 is offline   Reply With Quote
Old 01-20-2012, 07:41 AM   #20
Spigatelli
Member#: 306391
2005 Outback 2.5i
What shop in Ft Worth? I am in Ft Worth and I saw a few shops in Dallas, but someplace closer would be nice.
Spigatelli is offline   Reply With Quote
Long road trip + racing, best oil plan RaleighRider Service & Maintenance 22 08-12-2011 03:45 PM
Long road trips and oil changes Daggah Service & Maintenance 6 04-13-2008 05:55 PM
Going on a long road trip in my WRX this summer lionken07 General Community 28 03-16-2005 06:36 PM
Car's burning a lot of oil, Why?? PISTWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-16-2004 06:31 PM
