Old 01-17-2012, 07:16 PM   #1
greasy_beast
Member#: 307213
Default Broken Starter Bolt
Hello folks,
I'm replacing a starter on a friend's 1997 Subaru Outback (engine code: EJ25DAWCYL, trans code: TY752VACCA). The reason the starter needed replacing is that it was attached only by the bottom stud and the housing cracked.
So, I pulled the starter out, and took a look in the top hole with a mirror. I saw a nice smooth hole with a rough (looked cast) backing. So I called the friendly neighborhood Subaru dealer, asked parts guy for the upper starter stud, and learned that it is indeed a BOLT in the top hole, not a stud.
So it appears that sometime in the past, a total jackass sheared off the upper starter bolt WAAAY deep in the bell. This presents a bit of a problem as I have no idea how the heck I am going to get an ez-out in there... let alone a drill...
Anyone ever encountered this one before?
greasy_beast is offline   Reply With Quote
Old 02-04-2012, 07:31 PM   #2
NVsubaru
Member#: 247111
2007 Impreza 2.5i
1971 VW Fastback
That's a bitch. You just might need to drop the tranny to really get it out. Otherwise, JB weld can do wonders...
NVsubaru is offline   Reply With Quote
WTB : turbo Banjo bolt a nd starter bolts Marlons101 AKIC Private Classifieds 15 01-14-2011 11:00 PM
Broken caliper bolt AND broken extractor filbert Brakes, Steering & Suspension 4 05-27-2010 06:14 PM
Removing starter bolt 02darkRS Service & Maintenance 1 03-28-2007 01:26 PM
ej20g only has 1 starter bolt hole???? kbahus Subaru Conversions 3 04-24-2006 11:37 AM
starter bolt, the longer of the two..... Pacobeagle Private 'Wanted' Classifieds 0 06-11-2005 11:26 AM
