Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 01-18-2012, 02:45 PM   #1
SLegacy99
Member#: 117504
2015 WRX Limited
Lighting Red
Default Need Some Clutch Help
So the clutch on my '99 LGT is not being cooperative. I replaced it and drove it for two weeks before it became so unforgiving that I could no longer change gears.
Tried bleeding the system, this didn't work. Tried replacing slave cyldiner, this didn't work. Tried bleeding, again nothing. Tried replacing master cylinder and bleeding, still nothing. Finally, tried replacing clutch hose and of course, bleeding the system and I just can't get any pressure back. The trans. won't go into gear and the clutch pedal will not return to position.
Any thoughts would be appreciated.
SLegacy99 is offline   Reply With Quote
Old 12-17-2012, 02:35 AM   #2
IBDDRAGON
Member#: 340839
Default legacy clutch problems
What was the solution to your problem? My 1999 legacy gt did the same thing.
IBDDRAGON is offline   Reply With Quote
Old 12-17-2012, 07:02 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
In both cases, what clutch?
Did you do the whole clutch, including the TO bearing?
Did you clean & lube the input shaft?
An OEM style clutch should be easy.
An aftermarket, like the ACT Street CLutch, can be harder. I have used & installed a number of the ACT clutches and they have a very low pedal when the clutch engages. The last one I did in my 98 GT showed I needed a new master cylinder. Replaced it, bled the system and it's back to a normal low pedal.
May need some clutch change help ryanveld Rocky Mountains Impreza Club Forum -- RMIC 3 10-14-2010 07:13 AM
Need some diagnostic help - worn clutch? Meyers Bay Area Impreza Club Forum -- BAIC 0 06-10-2009 11:31 AM
I need help. I lost my job. Need some direction help. scaryfastskier Off-Topic 60 01-15-2008 06:46 AM
need some serious help with some wiring issues on a rex swap into an rs legacy2003 Subaru Conversions 14 07-20-2005 05:57 PM
I need some serious help. I redlined and dumped my clutch at 6krpms!! xicema17x Transmission (AT/MT) & Driveline 20 10-27-2004 10:08 PM
