Old 01-18-2012, 06:17 PM   #1
vms150
Member#: 172917
2004 WRX
Default No Boost
So yesterday my 2004 WRX stopped making boost. The turbo will spool and the gauge will travel up through the vacuum section and then stop right at 0 psi. It is almost as if the waste gate is opening at 0 psi. The car just falls flat on it's face at that point. There is no CEL and no lines seem to me disconnected or broken. Also there is no disconnect on any of the change piping. Could the BCS be bad? I have no aftermarket boost controller and just an STI TMIC so it must be an issue with the stock parts. But what? It just happened out of the blue. Drove find on the way to the gym, left the gym and it wasn't working. Why would it do this? I am at a loss as my snapon scanner shows no codes. The car just will not make boost. I need some helpful insight. Thanks.
vms150 is offline   Reply With Quote
Old 02-15-2012, 12:30 PM   #2
Dulaney96
Member#: 268712
2002 Impreza WRX
World Rally Blue
If it were the ebcs then I would hope it would throw a code, and if it did it would be a waste gate solenoid, I suggest check the hoses on the wastegate and the ebcs also look into to doing a smoke/leak down test best way to figure out if u got a leak. Back to the beginning sorry I get off on tangents but it kinda sounds like the solenoid or the wastegate sorry I couldn't help that's my two cents.
Dulaney96 is offline   Reply With Quote
Old 02-15-2012, 12:31 PM   #3
Dulaney96
Member#: 268712
2002 Impreza WRX
World Rally Blue
Also another question has it ever been tuned
Old 02-17-2012, 06:31 PM   #4
dryvby
Member#: 49931
0305 wrx/Xt
black/black
Visually check the wastegate flapper arm and vacuum line. Open it thru its range of motion first by hand. With the car off and cool.
dryvby is offline   Reply With Quote
Old 02-17-2012, 08:16 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
I wonder if the bypass/blowoff valve is stuck open.
Old 02-17-2012, 09:47 PM   #6
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
clip fall off the wastegate arm?
woodys77 is offline   Reply With Quote
Old 02-18-2012, 05:25 PM   #7
AZP Installs
Member#: 40160
Smoke tests are a great way to really zone in on a finicky boost issue.
-mike
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
AIM: AZP Installs | E-mail: [email protected] | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 04-28-2012, 09:20 PM   #8
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
My car is doing the same thing. Did you find the problem?
King of Poop is offline   Reply With Quote
Old 04-28-2012, 10:03 PM   #9
J-horn92
Member#: 314815
2007 Wrx
It could be the vacuum line to your wastegate, did you check to see if your restrictor pill fell out?
J-horn92 is offline   Reply With Quote
boost... no boost... now boost again? WRX SEX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-27-2010 11:41 AM
STi with no cats, and NO BOOST CREEP V6TurboTA Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 61 08-23-2009 08:10 PM
boost, no boost, more boost...***!!1!11 03twrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-05-2004 03:16 AM
No boost creep-no boost spiking!!-excellent boost response. odin1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 01-04-2004 07:21 AM
No boost but no CEL?? ideas? OBDii scanner help? iceweazel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-21-2001 04:18 PM
