Old 01-18-2012, 07:41 PM   #1
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
Default running the stage 1 91 octane map with 93 octane fuel?
Hi, I have a 2011 wrx with an accessport, I recently put 93 octane in the car as it was the only premium fuel the station had I flashed to the 93 octane tune and i didnt like it asmuch as the 91 octane one, since im at 6000 feet above sea level can i use the 91 octane tune with 93 octane gas safely?
also when I installed the accessport on my new 2011 wrx i forgot to save the stock map and im stuck with the stock tune from my 09, how can i get the 2011 tune? thanks
WRB19 is offline   Reply With Quote
Old 01-18-2012, 09:27 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
No problem running the 91 map on 93 gas... As for the stock map on the 2011 it should be saved on the AP for when you unmarry the AP then it will put it back on...
wrxdrvr is offline   Reply With Quote
Old 01-18-2012, 11:16 PM   #3
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
Well when I was going threw the maps and went to the stock map it said stock map for an 09
Old 01-19-2012, 12:13 AM   #4
Cobb Tuning
Member#: 4803
Hi there.
It is perfectly fine to run the 91 map on 93 octane gas. If anything, this will give you a little more knock resistance.
No tune from the prior installed vehicle will ever be used on the new vehicle that you are installing the AccessPORT to (and it would be impossible to use a 2009 map on a 2011 car to begin with). The v2 AccessPORT will automatically back-up your stock 2011 WRX tune when you installed it to your 2011 WRX. This backed-up image will be restored to the ECU if you were to uninstall the AccessPORT.
Bill
Old 03-11-2012, 09:18 PM   #5
vwbeaner
Member#: 257959
2008 STI
Sorry to bump an old thread here but what if I have a map for 93 and I run it on 91? how bad is that?
vwbeaner is offline   Reply With Quote
Old 03-11-2012, 09:27 PM   #6
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Could be OK, or it could be real bad, Personally I would never run a 93 map on 91 gas... JMO
Old 03-12-2012, 12:32 PM   #7
snoopy_sti
Member#: 164942
2015 Porsche Cayman
Exclamation
If you flash the 93 map on the car and put 91 in the tank , that will be bad because you are going to have more advanced timing and you are gonna see a ton of knock and possible detonation.
snoopy_sti is offline   Reply With Quote
Old 03-12-2012, 01:29 PM   #8
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Got the numbers backwards...
Old 03-12-2012, 02:35 PM   #9
Dartholomew
Member#: 208771
2009 WRX
He's answering vwbeaner's question and not OP's.
And while it is not guaranteed that you will see knock on a 93 map with 91 fuel (some very good maps are not split into 91/93 versions), you do increase the chances that it may happen. The only way to tell is to log and review.
Dartholomew is offline   Reply With Quote
Old 07-06-2012, 02:14 AM   #10
ajmillan
Member#: 298536
2013 STI
Satin white
If you were to run stage 1 91 oct map and fill up with 93 oct will the stage 1 91oct map be a bit more conservative gas consumption wise?
ajmillan is offline   Reply With Quote
Old 07-06-2012, 08:42 AM   #11
Cobb Tuning
Member#: 4803
No, it will not have any positive impact on your fuel consumption. Likely no effect whatsoever.
Bill
Old 09-13-2012, 12:26 AM   #12
Raceb0rn
Member#: 331568
2012 STI
I just installed my AP tonight on my 2012 STI using the stage 1 91 octane map running 93 octane in the tank. I thought this would be a very safe and conservative way to go. The car had exactly 3000 miles on it. I have been disappointed with the performance of the car up until today. Thank you cobb for fixing this problem
Raceb0rn is offline   Reply With Quote
Old 03-12-2013, 02:14 AM   #13
WRXSWP
Member#: 347936
2011 WRX
Originally Posted by Cobb Tuning View Post
Hi there.
Bill
So, I have wrx 2011 sedan running stage 2. Currently, my car run the 91 map. Is that still ok for my car running stage 2 on the map 91 with 93 octane? I guess it should be ok but just want to confirm for sure thanks
WRXSWP is offline   Reply With Quote
Old 03-12-2013, 08:26 AM   #14
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Originally Posted by WRXSWP View Post
... Is that still ok for my car running stage 2 on the map 91 with 93 octane? ...
Yes.
jebjkey is offline   Reply With Quote
Old 03-12-2013, 09:30 AM   #15
Cobb Tuning
Member#: 4803
Yes, you can most certainly run the 91 or 91ACN map with 93 octane fuel. The 91ACN and 91 octane maps are just more conservative maps so you will gain an extra margin of knock resistance as a result if using them with 93 octane gas. It certainly isn't required, but some of our customer like to be more on the conservative side of things.
Bill
Old 07-31-2014, 02:07 PM   #16
SubieStevie
Member#: 384509
2014 Subaru WRX
Revive to this thread lol i have a 91 ACN i usually dont see knock under WOT but when i look at my accessport after a drive i usually about 2.0 of fine knock
i usually run shell 91 Oct V power
my questions is should i run like 4 gallons of 100 OCT unleaded race gas and the other 11gallons 91 to fight the knock
2014 Stage1 WRX
12k miles DD
SubieStevie is offline   Reply With Quote
Old 07-31-2014, 04:02 PM   #17
JimmyBoyWRX
Member#: 371081
2013 WRX Limited
2006 WRX
2014 Stage1 WRX
12k miles DD
That's overkill and expensive. Log your drive and figure out were that knock is happening. It's likely during low load cruising if it's not happening during a pull.
Low load knock is normal and not really worried about too much.
JimmyBoyWRX is offline   Reply With Quote
Clark Turner Tuning Cobb Protune maps for your AccessPort, Gain more power! Clark Turner Engine/Power/Exhaust 7350 06-25-2016 03:38 PM
Top Scoob 027, Invasion of the Stancinistas, VOTE in Final Round !! Ferg Member's Car Gallery 463 02-06-2012 02:30 PM
Clutch started going soft in the heat? ChillinAussie Transmission (AT/MT) & Driveline 5 01-18-2012 03:09 PM
How does one go about running against an incumbant congressman of the same party? GodWhomIsMike Political Playground 5 01-18-2012 02:49 PM
Vibration in Fuel lines cdoliver Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 08-03-2011 02:13 PM
