Old 01-20-2012, 11:51 AM   #51
Mach V Dan
Member#: 12029
Originally Posted by wrxdrvr View Post
Only if you spray water onto the IC... Dry, the IC is usually only about 60% efficient, thus you would never really get as cold IAT as the IC core temperature...
Our empirical research would say it's more efficient than that. This is a 2.0 WRX with an STI turbo and STI top-mount intercooler.
With 70-ish ambient temp, we were seeing a temp drop across the core of as much as 75 degrees -- from 175 before the IC to 92 or so after. Sure, it's not all the way to ambient, but it's pretty close. 75 degrees actual drop / 95 degrees max possible drop = 79% efficient?
Sorry, I realize this is a bit off the topic.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 01-20-2012, 12:15 PM   #52
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Mach V Intercooler Temp Gauge - YouTube
--Dan
Mach V
FastWRX.com
What kind of driving was that? "Normal" Spirited or pedal to metal? If it was any other way but a pedal to metal run, you don't get a true IC efficiency number... The best I got my IC efficiency up to was 86% on a pedal to metal run (the only way you can get true IC efficiency number) from 0 to 130 MPH, with just spirited driving around I can easily get 99% and even 103% (great numbers but not really proper test numbers)...
The 60% stock TMIC set up number was a pedal to metal run too...
wrxdrvr is offline   Reply With Quote
Old 01-20-2012, 01:57 PM   #53
Mach V Dan
Member#: 12029
That's wide-open throttle.
--Dan
Mach V
FastWRX.com
Old 01-20-2012, 03:21 PM   #54
banny sti
Member#: 118815
Originally Posted by suby-newbie View Post
$230. Just saying...
If budget is tight....
http://www.ebay.co.uk/itm/PTP-Subaru...item45f4d785d5
banny sti is offline   Reply With Quote
Old 01-20-2012, 03:30 PM   #55
dScooby
Member#: 277465
2010 WRX
sl0w
Originally Posted by banny sti View Post
If budget is tight ~$40
http://forums.nasioc.com/forums/showthread.php?t=2298336
dScooby is offline   Reply With Quote
Old 01-20-2012, 03:40 PM   #56
RossLH
Member#: 147839
2003 WRX
SRP
Originally Posted by dScooby View Post
RossLH is offline   Reply With Quote
Old 01-20-2012, 06:06 PM   #57
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Originally Posted by v8subie View Post
Can I haz $20?
It's yours if you PM me your paypal addy. I'm a man of my word and have only once lost one of these jackass bets. Read those links and most of them were morons, but still flaming wrap is flaming wrap even if you use it to soak up WD40 prior to install.
Old 01-20-2012, 06:18 PM   #58
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
Like a banana
Nimbus09 is offline   Reply With Quote
Old 01-20-2012, 06:21 PM   #59
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
with respect to wrapping vs. non.... non is the way to go. feels better
ok, ok. seriously, wrapping should be better in principle. just make sure you wrap your downpipe too since it will run that much hotter with the turbo wrapped.
Old 01-20-2012, 06:27 PM   #60
hdempsey
Member#: 126374
2001 Impreza 2.5RS
Pure Aspen White
PM'd
Don't underestimate stupid people. You know this Ron. You've been in the Navy for quite some time and then some.
hdempsey is offline   Reply With Quote
Old 01-20-2012, 07:05 PM   #61
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
--Dan
Mach V
FastWRX.com
Good, 1 gear? Couple of gears? Or 1,2,3,4, WOT? The reason I am trying to be more specific is, usually when I go WOT the IAT into throttle usually goes down for the first gear then goes up a bit for the second gear then starts to climb noticeably as both the turbo out, and IC out goes up majorly by third gear, as everything gets hotter and by fourth gear as heat saturation of the IC starts that is where you start to get to know the true efficiency of the IC and that is why I can only get 86% efficiency out of my IC set up even when spraying iced water onto it, but when fooling around going WOT in a couple of gears only I can get 103% efficiency with iced water... And that's why the stock '02 WRX TMIC only comes in at 60% efficiency,properly tested, I'm sure normal driving riping WOT through a couple gears it's probably around 70% but that doesn't count.
Oh, and I have had every exhaust pipe that's under the hood header wrapped + an aluminium covered insulation on top so no oil or water can soak into the header wrap for 8+ years and nothing has happened, no rust holes, no cracks, no flames, just good stuff like, faster turbo spool ,faster IC cool-down, less IC heat soak, colder IAT, all adding up making for a faster car...
Old 02-28-2012, 05:06 PM   #62
GDB FAN
Member#: 105814
Originally Posted by GDB FAN View Post
Hopefully we'll see a writeup soon!
Hopefully sometime next month. I have to talk to some people in Lebanon, PA, Richmond, VA, and Gaithersburg, MD first.
Any word yet? It's been a month.
GDB FAN is offline   Reply With Quote
Old 03-17-2012, 04:21 AM   #63
stylin2.5rs
Member#: 45248
2005 WRX
Wanted to share with everyone that I had found Jegs charges a $10 handling fee...so if you're looking to get the Thermo Tec 15003 and save yourself some cash check out Autozone. Thermo Tec 15003 Turbo Insulating Cover
PS Great write-ups Unabomber, very informative.
Best of Luck
stylin2.5rs is offline   Reply With Quote
Old 05-11-2012, 12:46 AM   #64
FG2toGDF
Member#: 292537
2004 STi
Awesome writeup again, but got a question, and not necessarily for you UB, open question for anyone who has done this. I looked at the Thermo-Tec website, and the 15003 Kit says Turbo Cover Only, does this include everything I need for this? I just wanted to check before I make plans and then don't have everything I need for it.
FG2toGDF is offline   Reply With Quote
Old 05-22-2012, 12:09 AM   #65
paulpat
Member#: 237145
02 WRX
12 FXT
Is this the same material as in the DEI titanium wrap?
Like found here in the other unabomber how to:
http://forums.nasioc.com/forums/show...2303664&page=3
paulpat is offline   Reply With Quote
Old 05-22-2012, 12:15 AM   #66
RossLH
Member#: 147839
2003 WRX
SRP
No. It is an aluminized fiberglass blanket.
Old 05-23-2012, 10:21 PM   #67
mazdero
Member#: 286173
2003 BMW 330ci Turbo
There is a guy on ebay that has awesome turbo blankets. His ebay name is ollyrama. I bought a bunch of them from him and its high quality stuff. They range in price depending on size, anywhere from 50 for small to 80 for the huge turbine housings. You just lay it over the turbine housing and youre done, they work really well. If they can withstand rotary heat for years then its good stuff. Would save some time and hassle. He is the only one on ebay i would buy them from as a lot of those ebay blankets are garbage. My friends is300 caught fire cause of one of those crappy blankets. Actually im not even sure hes still on ebay but its worth a look. Hes in australia.
mazdero is offline   Reply With Quote
Old 05-23-2012, 11:29 PM   #68
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Please....gargle bees and wash them down with a big glass of bleach.
Old 05-24-2012, 12:54 AM   #69
FastAdams
Member#: 280714
1998 Look below.
98 rs 99 forester
Holy funny awesomeness. LOLOLOL
FastAdams is offline   Reply With Quote
Old 05-24-2012, 01:39 AM   #70
1stimeboost
Member#: 321155
2002 Impreza WRX
World Rally Blue
awesome write up
1stimeboost is offline   Reply With Quote
Old 05-24-2012, 01:39 AM   #71
mazdero
Member#: 286173
Really guy? Im trying to help people out and you hit me with this ignorance? Or maybe your slow car doesnt create enough heat to need a blanket? How about you grow up.
Old 05-24-2012, 01:41 AM   #72
1stimeboost
Member#: 321155
2002 Impreza WRX
World Rally Blue
I bet the poster ^^^ is the owner of the ebay store doing a little sales pitch haha
Old 05-24-2012, 01:46 AM   #73
mazdero
Member#: 286173
Wow you guys are something else. I am not in australia. I was just sharing a good experience i had with a heat blanket from that one seller. So i guess you guys like to stay in your closed little boxes and follow what everyone else does? Im getting attacked for no reason. Bunch of winners here i see.
Old 05-24-2012, 04:29 AM   #74
J_Baker
Member#: 309434
06/9 WRBSTI/SRR2.5i
shop slut/5sp beater
Hey. I happen to like my box.
J_Baker is offline   Reply With Quote
Old 05-24-2012, 04:56 AM   #75
Mr. Me
Member#: 193598
2002 Bugeye Wagon
Yes. We are winners here. Some of us, like you, are whiners though.
To each his own. And that was a fatty sales pitch by the way...
Mr. Me is offline   Reply With Quote
How to protect your turbo??? scoobiekid86 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 01-25-2009 07:26 PM
Why its a good idea to wrap your headers PolarisSnT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-30-2007 09:38 AM
How to wrap header? AWD>FWD Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 05-22-2007 02:06 PM
How hard is it to tune your turbo setup with UTEC? disque71 Newbies & FAQs 7 09-17-2004 12:19 PM
How to make your car handle to your liking Eric SS General Community 4 11-10-2001 06:34 PM
