Old 01-19-2012, 10:33 AM   #1
STIDAWG
Member#: 298850
2007 STI
Default Clutch "clicking" in 2012 wrx
I have a 2012 wrx limited hatch with 1,800+ miles on it and just started to notice a slight "click" when I push the clutch peddle about an inch or two in. I don't Remeber the car doing it before a couple days ago. Does anyone know what it might be or is it normal?
STIDAWG is offline   Reply With Quote
Old 01-19-2012, 10:35 AM   #2
2011WRblueSTi
Member#: 275851
2013 BRZ Sport Tech
That happened on both my 2009 wrx and 2011 STi. It came and went. Took it to dealership and they said it sounded/looked like the spring on the pedal was making the noise. Never bothered to replace it cause as I drove the cars that noise was droned out by other rattles and creaks and then all was trumped by exhaust once I began the mod process.
2011WRblueSTi is offline   Reply With Quote
Old 01-19-2012, 10:44 AM   #3
STIDAWG
Member#: 298850
2007 STI
Ya I'm no stranger to the noises the car makes, I sold my 07 Sti to get this car. But never experienced the noise with that car. But it won't cause problems will it?
Old 01-21-2012, 11:16 AM   #4
2011WRblueSTi
Member#: 275851
2013 BRZ Sport Tech
No problems that ever happened to either of my cars. In fact I think it went away all together on my STi over time.
I never had this noise but many others in my 2004 STi and actually my 2007 STi (which I still have under 2k miles) had no odd noises. It's a factory freak.
Old 01-21-2012, 06:47 PM   #5
mmenet
Member#: 191736
2009 WRX Hatch
grey
if you look at the master cyllinder in the engine bay and it is now moving a great deal and you can hear the click in there, this could mean that a weld on your firewall has broken and you are hearing the weld seams rub against each other. I am about to drop my car off to get this fixed, it is a more frequent problem than SOA wants to admit to because it is very expensive to fix. Im not sure this is the issue, but keep it in mind, because the dealers will not find/admit to this being an issue.
mmenet is offline   Reply With Quote
Old 01-21-2012, 09:40 PM   #6
2011WRX
Member#: 251807
typical issue, same on my 11 wrx. Dealer lube it and it went away since
2011WRX is offline   Reply With Quote
Old 03-16-2013, 01:56 PM   #7
Capt_Hindsight
Member#: 350049
2012 WRX
I am having this issue now. Does anybody know where to lube the clutch in order to get rid of this noise?
Capt_Hindsight is offline   Reply With Quote
Old 03-16-2013, 11:22 PM   #8
MaddMax
Member#: 9264
2016 BMW M235i 6MT
I had this issue. It has nothing to do with the broken weld issue experienced in the 08-10 models.
In my car, the click could be felt more than heard. It was almost like a pop and I could feel it in the brake pedal when I depressed the clutch while my right foot was on the brake.
I traced the source to somewhere in the pivot assembly of the clutch pedal. The assembly has two pivots. One above the clutch and then a bar runs across the dash to just above the accelerator from which there's another pivot which when drives the slave cylinder rod. In my case, it was most definitely not the clutch spring. I pulled the pedal left and right and then gave it a yank upwards (towards the driver's seat). The sound never came back
MaddMax is offline   Reply With Quote
6spd sti clutch/flywheel in 5spd wrx tranny? Benjamin Tang Transmission (AT/MT) & Driveline 76 08-19-2016 11:03 AM
Weird clutch issue in 09 wrx..please help!! rspillman88 Transmission (AT/MT) & Driveline 3 06-23-2011 07:18 PM
06 clutch/flywheel in 02 wrx Boarder325 Transmission (AT/MT) & Driveline 2 11-04-2008 07:35 PM
sti 6 spd clutch &flywheel in 5spd wrx trans ECUtuneOne Transmission (AT/MT) & Driveline 9 09-06-2006 07:34 PM
clutch dragging in 5mt wrx Benjamin Tang Transmission (AT/MT) & Driveline 17 02-03-2005 09:44 AM
