Old 06-09-2015, 09:53 PM   #1
Delicious Tuning
Member#: 1990
Default *** Delicious Tuning Flex Fuel for your Cobb AccessPort on 2008+ WRX/STI ***
General Overview
Tuner: Delicious Tuning
Vehicle: 2008 Subaru Impreza WRX STI
Ambient Temp: 78 degrees
Elevation: 700 ft
Humidity: 45%
Dyno Information
Dyno Info: Mustang AWD-150
Ethanol Content Reading on E85: 65%
Ethanol Content Reading on ACN 91: 9%
Peak HP at RPM: 284WHP @ 5400 on E85 (Flex Fuel)
Peak HP at RPM: 243WHP @ 6000 on ACN 91 (Flex Fuel)
Peak TQ at RPM: 339WTQ @ 3600 on E85 (Flex Fuel)
Peak TQ at RPM: 257WTQ @ 3600 on ACN 91 (Flex Fuel)
Target Boost: 18PSI on E85 (Flex Fuel)
Target Boost: 17PSI on ACN 91 (Flex Fuel)
Engine/Power Information
Delicious Tuning Cobb AccessPort Stage 2 Flex Fuel Tune
- 2008 Subaru STI
- Stage 2 ACN 91 with Flex Fuel
- Stock Intake and Turbo
- Turbo Back Exhaust
- ID 1000CC Injectors
- DW 300 Fuel Pump
Delicious Tuning is proud to unveil the first ever Cobb Stage 2 Flex Fuel for the 2008+ STI! This proves that we can now flex fuel 2008-2015 model year STI's.
Our Flex Fuel Bluetooth kit is designed to scale boost, fuel and timing based on ethanol percentage. So with that in mind all you need to do is pump and go, no need to pull out your Cobb AccessPort and switch between maps.
Cheers,
William Knose
Delicious Tuning
www.delicioustuning.com/flexfuel
http://www.delicioustuning.com/flexfuelcobb
Last edited by Delicious Tuning; 10-20-2015 at 08:33 PM. Reason: Adding Cobb FF link
Delicious Tuning is offline   Reply With Quote
Old 06-09-2015, 10:31 PM   #2
slide
Member#: 1130
2013 STI Hatch
Omg!!!! Awesome!!!
slide is offline   Reply With Quote
Old 06-10-2015, 02:25 PM   #3
iB00st
Member#: 407667
Will this work with an 07 sti? Or do you guys have a different kit for that?
iB00st is offline   Reply With Quote
Old 06-10-2015, 02:58 PM   #4
Delicious Tuning
Member#: 1990
Yes, we have flex fuel systems for 2004 thru 2015 STi using Cobb. There are some variances between kits due to model year differences, but it's basically the same thing.
Cheers
Old 06-10-2015, 09:55 PM   #5
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
That's very awesome, no more guessing the ethanol content.
Off topic: Is it true that you guys can tune the Lexus IS-F and RC-F?
Old 06-10-2015, 11:47 PM   #6
Delicious Tuning
Member#: 1990
How did you hear about that? I can neither confirm nor deny anything...yet.
Old 06-11-2015, 12:44 AM   #7
user1029
Member#: 57064
2008 STi IAG built
HTA86, Meth, 272s, Cos IM
Can you guys merge with IAG
user1029 is offline   Reply With Quote
Old 06-11-2015, 07:23 AM   #8
juanmedina
Member#: 133146
I heard from a little birdie.... I hope is true because my IS-F needs another 20-30hp..... or a twin turbo setup
Keep up the good work
Old 06-12-2015, 01:05 PM   #9
exchefphil
Member#: 324145
2011 Sti built motor
WR blue EFI tuned
what if your already protuned stage 2 with larger injectors, EWG on 93 oct ....how will this work for me? If i understand right if e85 isnt available i can just pump 91 oct and not do anything else? didnt buy a subbie for gas milage but does it improve it
exchefphil is offline   Reply With Quote
Old 06-12-2015, 07:44 PM   #10
Delicious Tuning
Member#: 1990
In your case, assuming you have 1000cc injectors and a larger fuel pump (what you need to run flex fuel). You would be a good canididate, because there is a COBB OTS map that could potentially suit your setup.
http://www.cobbtuning.com/maps/2011-...ti-stage-2-map
Yes, flex fuel, gives you the flexibilty to run your base fuel that you are tuned for (91 or 93 octane) and any percentage mix of ethanol, up to E85 (85% ethanol)
Actually, you get 30-35% less fuel economy runing ethanol, but you get good performance gains, lower price per gallon, cleaner burn/emissions and it's mostly a renewable fuel source.
Old 06-13-2015, 05:54 PM   #11
martin028
Member#: 401669
2004 WRX Wagon
JBP
What about a 2004 wrx?
martin028 is offline   Reply With Quote
Old 06-15-2015, 02:03 PM   #12
Delicious Tuning
Member#: 1990
We can do it:
http://forums.nasioc.com/forums/show....php?t=2727379
http://forums.nasioc.com/forums/show....php?t=2725510
Old 06-15-2015, 02:15 PM   #13
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'm curious, how do you best suggest setting up your data points to which you interpolate from? Do you run on a lab controlled E98 for instance and then run on a titrated pump gas, for baseline calibrations?
Also have you found that a linear interpolation of the maps works well or do you use a complex method? I ask because above fuel range may throw in more error if using a linear interpolation is used when a complex one should be used.
Old 06-15-2015, 03:32 PM   #14
Delicious Tuning
Member#: 1990
Hi Micah, it's been what, oh a decade or so?
I'm sure many people are curious what's in McDonald's special sauce, but I don't see them ever publically announcing the recipe.
Cheers,
Brian
Old 06-15-2015, 06:58 PM   #15
tsuch20
Member#: 297158
2011 STI Stage 4
Will the work for any stage performance mods. I have a built 11 STI and have wanted to be true "flex fuel" for awhile. Currently running e85.
tsuch20 is offline   Reply With Quote
Old 06-15-2015, 07:21 PM   #16
Delicious Tuning
Member#: 1990
This will work on any COBB OTS map. If you have modifications that exceed the requirements of the OTS maps, you will need custom dyno tuning by us, as we are not currently offering e-tuning for this setup.
Old 06-15-2015, 08:04 PM   #17
DavC825
Member#: 201736
12 IS-F..its white
07 Sti Blk
More on this! Last i heard was some company needing your ecu...
DavC825 is offline   Reply With Quote
Old 06-15-2015, 08:46 PM   #18
MassBugeye
Member#: 359347
Do these tunes require a flex fuel sensor as there is no easier way to determine the ethanol content of the "E-85" that is being pumped into the vehicle?
MassBugeye is offline   Reply With Quote
Old 06-15-2015, 08:51 PM   #19
Delicious Tuning
Member#: 1990
Yes, here is what comes in our kit:
Old 06-15-2015, 08:59 PM   #20
McGrizz
Member#: 405263
2011 STi
Obsidian Black Pearl
Is this only going to work with cars using basic off the shelf maps? What about those fully built and pushing in the 500+ hp range?
McGrizz is offline   Reply With Quote
Old 06-15-2015, 09:39 PM   #21
Delicious Tuning
Member#: 1990
No it will work on anything, but we would need to tune it.
Cheers,
William Knose
Delicious Tuning
Old 06-16-2015, 11:57 AM   #22
MPS-Dom
Member#: 204421
Hey bud,
looking at the kit and knowing what tables are available in standard GR based roms, I would guess that he is using the barometric sensor input (or something along those lines). Baro has compensation for fuel, ignition and boost. There is also the ability to scale the baro sensor.
The baro maps have on average about 8 points along the scale that you can adjust parameters, more than enough for flex fuel.
I'm totally digging the bluetooth display more than anything. I don't want another gauge in my car and the ability to just look it up with my phone when needed is cool. I'd like to see it display on an Android Auto head unit.
MPS-Dom is offline   Reply With Quote
Old 06-16-2015, 12:03 PM   #23
McGrizz
Member#: 405263
2011 STi
Cheers,
William Knose
Delicious Tuning
Is speed density ok too?
Old 06-16-2015, 12:40 PM   #24
Delicious Tuning
Member#: 1990
Originally Posted by MPS-Dom View Post
Hey bud,
Like this?
Old 06-16-2015, 12:41 PM   #25
Delicious Tuning
Member#: 1990
Yes, it works with speed density too.
