Old 01-19-2012, 10:40 PM   #1
masky43
Member#: 80352
1999 Imreza2.2LCoupe
Black Diamond Pearl
Default 03 hybrid swap= no start.
Hi all. First off I'm Justin. So I have 99 2d L the engine is 2.2 turbo bottom end with 96 jdm turbo heads. I just finished swapping the harness, ecu, and all required sensors and what not. Now no start. It will pop every once in a while. It has great spark and I know the injectors are firing, but no go. Do any of you swap experts know anything I may have any advise where I should start looking for problems or something I may have missed.
Thanks Justin
masky43 is offline   Reply With Quote
Old 01-20-2012, 03:27 PM   #2
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
Try some starting fluid directly in the throttle body, sounds like bad fuel if it sputters but does not start. Let us know how that goes. If that is not it, I would think it may be a mechanical issue, ie timing, head gaskets etc..
Also what ECU are you running? The crank sensor pickup may be different than what that ECU is used to.
scoobydorift is offline   Reply With Quote
Old 01-20-2012, 09:22 PM   #3
masky43
Member#: 80352
Black Diamond Pearl
Tried starting fluid on the TB. The ecu is from an 03 wrx manual trans. The cam/crank gears are the 6/7 setup. Is that maybe the wrong setup?
Newly assembled hybrid with cranking and no start and no CEL, suggestions? 240sxguy Built Motor Discussion 7 08-20-2012 10:00 PM
Forester swap no start AsphaltsCry Subaru Conversions 7 11-19-2011 07:11 PM
No start on 2.5 hybrid swap pwr_wrx Built Motor Discussion 0 05-30-2009 02:02 PM
Jumped magic pins 11 and 12 on my 5spd swap, no start jamesfacts Subaru Conversions 5 11-02-2007 12:59 PM
05 Swap No Start kbahus Subaru Conversions 7 07-23-2007 07:53 PM
