Old 01-20-2012, 02:07 AM   #1
80807STI
Member#: 183266
2004 Impreza WRX STI
Default Cold weather starts and engine dying
Hey guys, heres a background on my car. 2004 STi Built engine stock bore, gt35, AEM standalone EM, and all the trimmings....
The problem: first starts in the morning or starts after sitting(cold) I get a wierd fluctuation in idle 1K-1.7K it will start normal then jump and hold for about 3-5 seconds at higer rpm then drop. When its warm after 10mins of driving it seam to even out although still not smooth. Recently its been dying out, coming to stops, idle dips below 1K and then sometime it dies.
Is this a tune issue? Fuel issue? Or could it be electrical? Any idead would be appreciated. Also if it was a fuel issue, would switching from E85 to pumpgas(current tune) be a factor? i.e injectors/fuelrail damage or clog? ITs been about 2 months since the retune.
80807STI is offline   Reply With Quote
Old 01-21-2012, 12:25 PM   #2
80807STI
Member#: 183266
Any ideas...well I found something in the tuners area about "cold weather tunes"...I forgot to mention that I live in Oregon and its 40 and below in the morning when it has its issues.
Old 01-21-2012, 08:07 PM   #3
flash02
Member#: 78916
It's your IAC (idle air control valve) those dam things are very finicky especially when controlled by other then stock ECU's. You can try and clean it, if you do get the gasket for it as the old one will not be usable.
flash02 is offline   Reply With Quote
Cold weather start up knock? yellowblaze Baja Forum 6 12-28-2004 12:51 PM
Cold weather starting car with hydra Matrix 1193 Other Engine Management 9 12-26-2004 09:29 PM
Cold weather starting car with hydra Matrix 1193 Normally Aspirated with bolt-on Forced Induction Powertrain 9 12-25-2004 11:28 AM
slow cold weather start sedona-rex Factory 2.5L Turbo Powertrain 14 12-21-2004 05:53 PM
I know this is normal but cold weather starts. SubaruImpreza_power Normally Aspirated Powertrain 1 12-28-2003 12:44 AM
Message Board Statistics All times are GMT -4. The time now is 01:05 AM.
