Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 01-20-2012, 09:56 AM   #1
obsaidian scooby
Member#: 276966
2005 wrx
Obsidian Black Pearl
Default stg 2
hey hope some one here can help me i installed my ap and turbo back exhaust along with a catless up pipe the other day an now the car throws misfire codes on cylinders one an two an a pfff code what would cause this?
obsaidian scooby is offline   Reply With Quote
Old 01-20-2012, 10:21 AM   #2
alieus
Member#: 155634
2006 WRX
SRR
It doesn't sound like the what you did caused it directly, unless you forgot to reconnect something.
First: Did your problem become apparent from the moment right after the install.
If this is true, then probably something you did during the installation caused this. Make sure everything is connected correctly(O2 sensors, disconnected the green connectors, etc.)
Second: Did your problems occur sometime after the install.
If this is true then you probably do have an misfire. Cylinder 1 and 2 are the two cylinders towards the front of the car.
Back of car
34
12
Front of car
Is your car is actually running rough? If it is all it takes for a engine to run is fuel and spark. There are three components to this, coil pack, injector, and spark plug. You can rule out injector and coil pack by just unplugging them while the engine is running. If the engine does not run any worse than it already is with the item you unplugged, then it is probably bad. If none of those are bad, change the plugs.
Given you have 2 misfire codes, Its probably something you missed during the install to be honest.
alieus is offline   Reply With Quote
Old 01-25-2012, 08:38 AM   #3
obsaidian scooby
Member#: 276966
2005 wrx
i thought i might of installed it wrong to but its deff not from that i went threw and made sure i did it right step by step
Old 01-25-2012, 10:21 AM   #4
Cobb Tuning
Member#: 4803
Can you give a complete list of all your mods? Any other check engine light codes besides the misfire codes?
Bill
Old 01-26-2012, 10:33 AM   #5
obsaidian scooby
Member#: 276966
2005 wrx
the car has a cobb sf intake and a invidia turbo back the car only throws misfire codes on one an two the only other code the car used to through was exhaust temp sensor malfuncton i fugured the sensor was bad an just replaced it with a catless up pipe
Old 01-26-2012, 11:16 AM   #6
Cobb Tuning
Member#: 4803
Do you have an aftermarket crank pulley or aftermarket flywheel?
Bill
Old 01-26-2012, 11:41 AM   #7
obsaidian scooby
Member#: 276966
2005 wrx
not that i know of i bought the car stock besides the cobb intake
Old 01-26-2012, 12:00 PM   #8
Cobb Tuning
Member#: 4803
Does the car run rough at any time?
Bill
Old 01-26-2012, 12:48 PM   #9
obsaidian scooby
Member#: 276966
2005 wrx
yeah the car wont go much over 3000rpms and has a rough idle now
Old 01-26-2012, 01:04 PM   #10
Cobb Tuning
Member#: 4803
How did the car run prior to installing the DP and AP? Did you buy it used? How long did you drive it before installing the DP and AP?
Bill
Old 01-26-2012, 01:49 PM   #11
obsaidian scooby
Member#: 276966
2005 wrx
the car ran decent befor i installed anything to it. i noticed today my pill restrictor is missing i also noticed the person befor me must of had a aftermarket boost solenoid and put the stock one back as i can see where he spliced it in the harness
Old 01-26-2012, 10:03 PM   #12
Cobb Tuning
Member#: 4803
If you have a local Subaru performance shop, I take it to them and have them do a once-over, especially since you already have evidence of prior mods. Misfires can occurs for any number of reasons relating to fuel, spark, lack of compression, etc. You can try uninstalling the AccessPORT - if the misfires go away, that means the prior owner likely has another tune on there which possibly disables the misfire codes and attempts to mask the mechanical problem.
Bill
Stg 2 2.0 VS stg 2 2.5 renosubby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 28 08-26-2010 01:30 AM
For the TD04 guys: 08 Stg 2 + meth vs 02 Stg 2 + meth PhatBotti Tuning TKR Proven Power Bragging 46 06-24-2010 10:08 PM
stoptech stg 1 or stg 2 break upgrade Lordhowe Private 'Wanted' Classifieds 2 06-30-2004 10:49 PM
COBB Stg 2 power package + Stg 2 heads + reflash = ??? Teh Legacy Normally Aspirated Powertrain 11 10-17-2003 03:09 PM
Vishnu Stg 2 TXS stg 4 comparo [email protected] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 60 11-19-2002 11:40 PM
