Welcome to the North American Subaru Impreza Owners Club Thursday October 20, 2016
Old 01-20-2012, 10:22 AM   #1
Member#: 111917
2006 WRX Limited
Default Fuel nozzle clicks off repeatedly
When I try to fuel up my 2006 WRX, if the handle is squeezed to full rate or anything above a trickle, the pump clicks off. It ends up taking over 10 minutes to get somewhere close to a full tank. Usually I only get to half or 3/4 full. I had a CEL P1443, replaced the evap vent valve and it went away. Still have the fueling problem. While replacing the evap vent valve, I also blew compressed air through the lines...Any suggestions? Could it be the gas tank vent valve? I hope not.
kpow is offline   Reply With Quote
Old 01-21-2012, 10:08 PM   #2
Member#: 160425
2004 Impreza Outback
The gas tank vent valve is one of the first things I'd check ...
I've had a number of premature pump shut-offs recently, but none have been as horrific as when the vent valve didn't want to work anymore...
I'd have to "top off" about 120 times just to get half a tank... Then had the shop replace that valve ... it works fine now, but I think my failed charcoal canister messed things up with charcoal powder before I could get it replaced, so I probably have to clean that system yet again for fuel-ups to be completely effortless again. >.<
multimediaman is offline   Reply With Quote
Old 01-22-2012, 10:37 AM   #3
Member#: 40248
2003 WRX
Midnight Pearl (black)
You're putting it in too far. Slow down, there homeslice. Just put the tip in. No premature shut down.
billzebub is offline   Reply With Quote
Fuel injector/clicking question... awalk9905 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-24-2007 04:25 PM
Honda says odometers on 6M cars click off mileage at too-quick pace NYCshopper Non-Subaru News & Rumors 20 02-19-2007 01:22 PM
Fuel Pump cut off? Grease Monkey Car Audio, Video & Security 5 08-01-2006 10:39 AM
Fuel pump cut off switch as security safegaurd? AJ711 Car Audio, Video & Security 15 11-14-2004 12:18 PM
Fuel pump shut off switch? subenutt Car Audio, Video & Security 8 02-28-2001 11:06 PM
