Old 08-14-2002, 12:36 PM   #1
dcoty
Member#: 3149
01 V7 GC/R32 sky
Default My 2.5 build will be complete in 1 week!! Need expert opinions!
Ok, i have a lightly modded 01 2.5 rs My existing mods are:
strommung 2.25 cat back
random tec hi flow cat
newest gen borlas
cobb CAI
unorthodox UD pulley
Cobb mild cams.
KYB AGX w/ ground control springs (adj ride height)
whiteline adj swaybar (set on 20 mm)
cobb short shifter
WRX rotors and brackets (front)
I have been saving/ planning this for a long time and i am going up to lachute subaru to install a whole mess of goodies...here are my plans.
Port matched ported and polished cylinder heads
matched valves (5 angle valve job)
cobb springs and retainers
Cobb racer camshafts (newest most aggressive n/a grind cam)
exedy clutch (+30%)
16 pound machined stock flywheel
ZEX 55 shot nitrous kit
new fuel pump
colder range (7's) spark plugs
I have to arrange an appointment after i make my custom intake manifold with my brother for my car to go back to lachute for unichip tuning..im also raising my redline to 7,250 rpm to get the high end power Im going to be making with my set up. This is safe with my springs valves and retainers from cobb.
So, I just posted this to get some opinions, Im sorry if it looks like bragging, but Im honestly not. I am just looking for reccomendations and opinions on my n/a setup in an n/a forum. i appreciate any comments and opinions (both negative and positive) and also warnings and experience with anything that i am doing. Thanks everyone!
Dan
dcoty is offline   Reply With Quote
Old 08-14-2002, 01:12 PM   #2
tselway
Member#: 7490
2014 2.0i 5dr 5MT
Deep Sea Blue Pearl
good luck Hope your tranny holds up to all that power. Are you going to get a dyno done?
tselway is offline   Reply With Quote
Old 08-14-2002, 01:20 PM   #3
dcoty
Member#: 3149
01 V7 GC/R32 sky
Yes I am, when i go to get the unichip on my car, lachute subaru (they have a prodrive contract) will convert my car to rwd to tune it on the dyno, and later during the year they will have acess to a 4 wheel dyno, so they said I can eventually put my car on that too. When i get the rwd dyno numbers, 4 wheel dyno numbers and 14 mile numbers I will be sure to post them!
Dan
Old 08-14-2002, 02:13 PM   #4
GooseMan
Member#: 2462
2012 Audi A4 Avant
S-Line Titanium
you can use JUSt the UniChip to raise your redline? And keep the stock ECU?
where have I been? I spend too much time in friggin OT
GooseMan is offline   Reply With Quote
Old 08-14-2002, 02:58 PM   #5
dcoty
Member#: 3149
01 V7 GC/R32 sky
Im in OT waaaaay more than I am here Goose, its addictive!
Old 08-14-2002, 03:18 PM   #6
imprezey
Member#: 17178
2001 2.5RS Coupe
Silverthorn Metallic
that setup you got sounds really nice, and reliable. i was just wondering how much you are paying to have it rebuilt. also, do you know if you will pass emissions with that setup? what do you think youre 0-60 and 1/4 times would approximately be? really nice and good luck! you should look into gettin those chalek hardened gear sets for the tranny too.
imprezey is offline   Reply With Quote
Old 08-14-2002, 03:33 PM   #7
imprezey
Member#: 17178
2001 2.5RS Coupe
also, you should consider some STi engine and tranny mounts. your engine is prolly gonna wanna rip outta the engine bay.
Old 08-14-2002, 03:48 PM   #8
dcoty
Member#: 3149
01 V7 GC/R32 sky
I've heard that the STi tranny and engine mounts send a lot of vibration into the car, is this true?anyone with experience? Do you think they are really nesessary? Thanks for the thought!
Dan
Old 08-14-2002, 04:22 PM   #9
GooseMan
Member#: 2462
2012 Audi A4 Avant
S-Line Titanium
well, I have the STi tranny mount, and its a pretty good balance of solidity and vibration/noise. I notice a bit more noise and slightly more vibration, but the drivetrain doesnt knock around as much as before. With the engine mounts, it'll be ROCK solid tho, and transmit more noise and vibes.
Old 08-14-2002, 05:10 PM   #10
m750
Member#: 2278
8Sti | 07 allez
White | Comp
my .02?
don't go any further N/A.
spend a little more and go turbo. The cost per H/P n/a is just obscene... IMHO.
AO
m750 is offline   Reply With Quote
Old 08-14-2002, 07:03 PM   #11
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
I've heard nothing but bad things about lightening the stock flywheel. And not just from Subaru's.
Spend the money and get a good aftermarket lightweight flywheel.
Other than that, I'm jealous
tcs007 is offline   Reply With Quote
Old 08-14-2002, 07:05 PM   #12
dcoty
Member#: 3149
01 V7 GC/R32 sky
Turbo charged cars are great I've driven quite a few (my brothers), but the reason im going this route is because its different. I was torn between going turbo or doing a build, but the idea of a build is just simply more appealing to me and is what i really want to do to my car. It boils down to a simple preference i guess...good point though on cost/hp. Anyone else??
Dan
Old 08-14-2002, 07:13 PM   #13
ScoobArmada
Member#: 12974
2005 STi
Whiter than Faded BRP
Default dcoty
I think it sounds sweet, and completely understand the idea of not going turbo in order to do something different. I would LOVE to hear some results, hard numbers, butt dyno, grin factor, etc. A cost break down of the parts and labor would be really cool too, if you're bored and feel like typing...
ScoobArmada is offline   Reply With Quote
Old 08-14-2002, 07:49 PM   #14
STiTuner
Member#: 5778
09 135i
Jet Black
maybe a bit expensive but have you thought about oversized valves? maybe help a bit more air flow through there not that you'll need it with the cams though.
Brad
STiTuner is offline   Reply With Quote
Old 08-14-2002, 08:23 PM   #15
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Throw in a bigger throttle body? It can only help.
Keiho is offline   Reply With Quote
Old 08-14-2002, 09:58 PM   #16
dcoty
Member#: 3149
01 V7 GC/R32 sky
These are good points guys, thanks!
ill look into the lightend flywheel option, but the guy at lachute who has a supercharged 2.5 loves hi flywheel to death, so im a little stuck on this one, iwas originally looking at the fidanza fly, but the stock one seemed right for what i needed.
Oversized vavles arent nesessary, both cobb and lachute subaru were against oversized vavles for my car. The valves are machined to match the heads aswell, they arent stock.
I forgot to mention the new throttle body I'm putting in too, i wouldnt forget that!
Dan
Old 08-14-2002, 10:06 PM   #17
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
Higher compression pistons? And why not get a link + for a couple hundred more and having the tuning options? Sounds awesome though can't wait to see the dyno numbers and maybe a video if possibe preferably with audio in a tight enclosed space as to hear it echo of the walls nice and loud.
Poppa smurf is offline   Reply With Quote
Old 08-14-2002, 10:23 PM   #18
dcoty
Member#: 3149
01 V7 GC/R32 sky
Pistons will come poppa smurf ! Be patient . i decided not to do the pistons yet, but that will be the icing on the cake i admit. I will DEFINITLY post dyno #s, when I go to tune the unichip they will make my car rwd and plop it on the dyno, so ill have rwd numbers for you guys, eventually they will have acess to a awd dyno so Ill do that eventually.
I will do a full length, sound included video of my car when i am completely finished. I will also vidoe my 1/4 run too, I just need some time. Believe me, everyone will know how it goes!
It's becomming harder and harder to sleep!
Dan
Old 08-14-2002, 10:30 PM   #19
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
Oh I cant wait!! I have been debating the ludespeed stage 3 w/ link or doing a NA build up myself around X-mas. Do you have any idea on the CR yet?
My 2.5 build. Any thoughts? dc_adio28 Built Motor Discussion 2 11-05-2009 03:22 AM
Car will be stock in 2 weeks. VF34, EWG, UP, TMIC, More page02wrx Engine/Power/Exhaust 28 04-20-2007 03:03 PM
Someone from 'Desperado' will be completely nude in an upcoming movie! Machine Age Victim Off-Topic 13 03-23-2006 07:48 AM
New car will be here in a couple of weeks deadbolt South East Region Forum 31 05-13-2003 01:40 PM
Will a EJ20DETT Twin Turbo Jap. Prod. Bolt in my 2.5 RS redmeanie Normally Aspirated with bolt-on Forced Induction Powertrain 23 03-01-2002 07:35 PM
