Welcome to the North American Subaru Impreza Owners Club Thursday September 18, 2014
Old 01-20-2012, 10:06 PM   #1
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
Default UOA: 2008 STI Pennzoil Platinum 5w-30
2008 STI, ~4,000 mile interval, 42,500 total miles on car. Cobb AP Stage 1 OTS. PA Fall/Winter, all street driving. First UOA with the car - this was my 2nd fill of PP (previous fill went about 4k miles also).
Concerned with the copper - from what they wrote and what I've been able to search on the internet I'll probably need another UOA to determine if there's an issue. Could be bearing, turbo or oil cooler? Everything else looks normal except for sodium. Comments?
Mind is offline   Reply With Quote
Old 01-21-2012, 10:14 AM   #2
Slimey
Member#: 42487
2008 STI
Dark Gray Metallic
I've had elevated copper on a UOA before too (08 STI with RT6 @ 3750 miles OCI, some time ago when I had 20-25K miles).
I've read here or elsewhere that the consensus is the elevated copper read on Blackstone UOAs from GR STIs is related to the oil cooler and not a concern.
Slimey is offline   Reply With Quote
Old 01-21-2012, 05:13 PM   #3
Mind
Member#: 109216
08 STI DGM
Thanks for the input. Did your copper fall back to normal levels with other oil changes? I'm thinking since the car seems perfectly healthy otherwise (no burning oil, no odd noises, seems to run smoothly and pulls strong, very good mpg) that it is just the oil cooler.
Old 01-22-2012, 12:57 PM   #4
SubLGT
Member#: 207528
2005 Legacy GT
Not unusual to see a copper spike with turboed Subarus. I don't see any cause for concern. Oil has sheared down to a heavy 20 weight.
SubLGT is offline   Reply With Quote
Old 01-22-2012, 05:11 PM   #5
bluesubie
Member#: 767
04 FXT
The chemistry in some oils interact differently with the oil cooler and copper may be reduced by trying different oil. I agree, no reason for concern about the copper with this 20 weight IMO.
-Dennis
Old 01-22-2012, 05:48 PM   #6
Mind
Member#: 109216
08 STI DGM
-Dennis
Hmmm... okay I'll bite... what do you see that is of concern?
Old 01-22-2012, 10:43 PM   #7
bluesubie
Member#: 767
04 FXT
Just that the oil sheared to a 20 grade which is not unusual for any interval on a Resource Conserving oil.
-Dennis
Old 01-23-2012, 07:50 PM   #8
G_REX
Member#: 266384
2011 WRX Limited
Spark Silver Metalic
Here is a comparison between T6 and Pennzoil Platinum and Ultra.
The most recent one is the T6. Both oils did really good...
G_REX is offline   Reply With Quote
Old 01-23-2012, 09:46 PM   #9
bluesubie
Member#: 767
04 FXT
You have one 30 grade uoa that maintained its viscosity, and holy smokes, what the heck were you running at the 9,500 mile uoa? That oil is actually thinner than virgin Mobil1 5W-20.
http://www.mobil.com/USA-English/Lub...l_1_5W-20.aspx
It's funny that a lot of Forester owner's with the new FB engine refuse to run 0W-20, but in fact many people have been running oil with an operating viscosity of a 20 grade for years. If your fuel dilution continues, expect the Flashpoint and viscosity to take another hit on your current fill of PP. Be cautious about taking Blackstone's advice and running to 7,500 miles, IMO, although you would be covered under warranty.
-Dennis
Old 01-24-2012, 12:40 AM   #10
G_REX
Member#: 266384
2011 WRX Limited
Not my UOA ^^^ and I change the oil every 4k miles.
Where did you see 9,500 miles?
Old 01-24-2012, 10:23 AM   #11
Slimey
Member#: 42487
2008 STI
Dark Gray Metallic
Haven't checked it again.
Old 01-24-2012, 12:12 PM   #12
SubLGT
Member#: 207528
2005 Legacy GT
You have one 30 grade uoa that maintained its viscosity, and holy smokes, what the heck were you running at the 9,500 mile uoa? That oil is actually thinner than virgin Mobil1 5W-20........-Dennis
On two of my UOAs I have seen P-Platinum 5W30 shear down to a vis of 8.7, once after only 1480 miles and once after 2400 miles. Fuel in both cases was <0.5.
Old 01-24-2012, 06:26 PM   #13
bluesubie
Member#: 767
04 FXT
The uoa from January 2011.
-Dennis
Old 04-05-2012, 10:07 AM   #14
Mind
Member#: 109216
08 STI DGM
Another one on PP 5w30. Copper still high but dropping. Running RT6 currently.
Old 04-05-2012, 10:59 PM   #15
bluesubie
Member#: 767
04 FXT
It will be interesting to see if copper drops further with RT6. Different oils seem to produce different copper levels (possibly from the oil cooler). I wonder what this would have looked like pushed to 7,500 miles? Lead is zero though so that's a good sign for bearing wear. Unless the wear particles are just too large to be picked up by uoa. j/k.
-Dennis
Old 04-05-2012, 11:34 PM   #16
Mind
Member#: 109216
08 STI DGM
Yeah, I've been hunting out PP STI UOA's to see if there was any correlation with PP and copper, but didn't really find anything - actually found some PP STI UOA that had very low copper. I was running Synpower prior to the first run of PP (first UOA) and I think the elevated sodium could have been due to the Synpower as I've heard it is high in Sodium. Or at least I think I read that somewhere.
Looks like on the Oil Analyzers FAQ they have this:
Q: My sample has a high copper number. Where is it coming from?
A: If only the copper is high, but no other metals such as lead, tin, or aluminum are elevated, it is mostly an oxide of copper from the oil cooler. As the oil cooler is exposed to the heat from the engine oil, it can sometimes oxidize the copper, which will show up in the analysis report. This is considered a normal condition and no corrective action is required. This process usually will taper off or stop occurring over time.
So that made me feel a little better since other metals are low/within limits. But I do wonder about the silver too.
j/k.
Old 04-06-2012, 08:57 AM   #17
bluesubie
Member#: 767
04 FXT
Have you seen gathermewool's uoa's? Some silver noise as well. http://www.iwsti.com/forums/2-5-lite...o-0w-30-a.html
Stop running girly man oil! Oh, you've already switched.
-Dennis
Old 04-06-2012, 08:07 PM   #18
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
all of these 5w30 lemmings
Old 01-07-2013, 11:17 PM   #19
feet2017
Member#: 341256
2013 wrx sedan
swp
some of us don't want to risk voiding our warranty....
feet2017 is online now   Reply With Quote
Old 01-11-2013, 04:35 PM   #20
Hoon Goon
Member#: 335538
2008 WRX - Hatch
You would not risk your warranty by running a 5W-40 such as T6. Read that owners manual. It has a range of viscosities up in there.
Hoon Goon is offline   Reply With Quote
Old 01-11-2013, 04:47 PM   #21
Stretch18
Member#: 239822
2010 WRX
It burns when I PP
-Dennis
Just saw this old post; that is my UOA. The first one was run with PP 5w30, ran Pennzoil Ultra 5w30 after that. Starting with the 21,800 change, I filled up using T6 5w40 and haven't looked back since...
Stretch18 is offline   Reply With Quote
Old 01-19-2013, 04:44 PM   #22
fr0st
Member#: 41618
2008 WRX Hatch
wrb
from the TSB
SUBARU GENUINE ENGINE OIL SYSTEM FLUSH
TECHNICAL SERVICE BULLETIN
Reference Number(s): 02-110-10, Date of Issue: January 5, 2011
INTRODUCTION
The purpose of this bulletin is to announce a new product that is now available through the Subaru Genuine
Chemical Program, "Subaru Engine Oil System Flush".
The main cause of turbocharger failure is lack of lubrication due to insufficient maintenance. Currently,
2010MY and prior turbocharged engines require that the oil and filter be changed every 3,750 miles (6,000 km)
or 3 3/4 months. All 2011MY turbocharged engines require that the oil and filter be changed every 7,500 miles
(12,000 km) or 7.5 months.
Proper oil change maintenance is critical to the lubrication of engine components, especially in turbocharged
engines. When engine oil maintenance is not performed at required intervals, oil gelling (sludge) and deposits
caused by deterioration of the oil will clog oil passages, causing excessive wear from lack of lubrication. If the
mesh filter screen located inside the banjo bolt that secures the turbocharger oil supply pipe to the back of the
right cylinder head becomes clogged, the turbocharger will fail. In addition, this will also cause damage to the
Active Valve Control System (AVCS). As a reference, refer to Service Bulletin 02-106-08R,
TURBOCHARGER MESH FILTER SCREEN .
SYNTHETIC OIL
Subaru
fr0st is offline   Reply With Quote
Old 01-19-2013, 11:57 PM   #23
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
some of you dont wanna risk being stupid.....er....doing stupid things
UOA: Pennzoil Platinum 5w30 on 2010 WRX (cheap & easily obtained oil) DutchOven Service & Maintenance 39 08-10-2012 10:46 AM
UOA: 05 2.5RS, 5124 mi, 5W-30 Pennzoil Platinum ScottyB Service & Maintenance 4 12-21-2011 11:21 PM
Pennzoil Ultra 5w-30 UOA Grocery_Getta_265 Service & Maintenance 12 04-21-2011 09:26 AM
Pennzoil Ultra 5w-30 UOA Grocery_Getta_265 Factory 2.5L Turbo Powertrain 3 04-19-2011 08:49 AM
Used Oil Analysis - Pennzoil Platinum 5W-30 - 2005 Subaru WRX STi AndyH Service & Maintenance 16 03-10-2008 09:30 PM
