Old 01-20-2012, 11:04 PM   #1
stealth1281
Member#: 306298
2008 STi
Default Please help! stage 1 problem
I just got my ap yesterday, flashed the stage1+SF 93 octane map and logged it today in 3rd gear S#. During my run, the car hesitated around 4k rpm's and shortly after I hit redline, all these lights came on: check engine, traction control, cruise, and I could not get out of regular sport mode.
According to my ap, there was a solenoid a malfunction. I cleared the ecu with the ap to get rid of all these lights. Did I really screw something up? Could someone please look at my logs?
https://docs.google.com/spreadsheet/...HlIY1MxVHpQeWc
stealth1281 is offline   Reply With Quote
Old 01-21-2012, 12:14 AM   #2
Cobb Tuning
Member#: 4803
Sounds like you hit the overboost fuel cut (P0244 DTC). What year STi is this?
Bill
Old 01-21-2012, 10:51 PM   #3
stealth1281
Member#: 306298
2008 STi
Sorry, it's a 2008 STI
Old 01-21-2012, 10:55 PM   #4
stealth1281
Member#: 306298
2008 STi
Did I cause any damage to the engine or turbo hitting that high of boost? Also, how does the rest of the log look?
Old 01-22-2012, 12:21 PM   #5
Cobb Tuning
Member#: 4803
The log shows that you are overboosting and boost is wavering (high, low, high, low, etc.). Temporary overboost isn't going to damage the engine, but you don't want to be doing that long-term. The first thing to do would be to download and reflash the low wastegate (LWG) version of the map and go from there (do another log).
You can download the LWG version of your map from our map repo:
http://www.cobbtuning.com/info/?ID=3061
Use the AP Manager software to get the map from your computer to the AccessPORT. Then reflash that map to the car.
Bill
Old 01-23-2012, 05:14 PM   #6
stealth1281
Member#: 306298
2008 STi
Thank you for the reply. I reflashed with the LWG version but haven't had any time to log again. I really can't feel much power difference over stock which is slightly disappointing.
Old 01-23-2012, 05:40 PM   #7
Cobb Tuning
Member#: 4803
When you reflash a map or install the AP, it resets the engine control unit's (ECU's) learned parameters. This can make the tune feel a little soft until you get some driving in there. Give it a about a week and it should feel better. Get a new log when you get a chance and we can see how the LWG map is doing. Also get another log after about a week of driving and we can see if there are any fueling issues that may be making the car feel sluggish as a result.
Bill
Old 01-25-2012, 06:54 PM   #8
stealth1281
Member#: 306298
2008 STi
Old 01-25-2012, 07:38 PM   #9
STiAnnie
Member#: 307204
2015 STi
CWP
They look good. I had the same problem minus the lights coming on. It takes a good day or two of driving around for the ECU to learn the new maps. Im not a pro with reading the data but from what I see it looks good. If you have issues again maybe try running the Stage 1 91 octane map. That won't hurt if your running 93 octane. Im sure one of the guys from Cobb will chime in on this post and give you better details then me.
STiAnnie is offline   Reply With Quote
Old 01-25-2012, 10:48 PM   #10
Cobb Tuning
Member#: 4803
That looks much better - I would stick with the LWG map.
Bill
Old 01-25-2012, 10:56 PM   #11
stealth1281
Member#: 306298
2008 STi
Thank you guys for your prompt help. My piece of mind has been restored
please help! simple comp problem Kopid Off-Topic 3 04-22-2016 12:58 PM
Please Help stage 2 flash gone bad Simpstat AccessPort 3 01-05-2007 03:53 AM
Please help with brake problem sbrcr267 Brakes, Steering & Suspension 5 06-18-2004 03:02 PM
help help, stage 1 problems..? kuma15 Engine Management & Tuning 3 09-06-2003 08:13 PM
Please Help factory stereo problems macswrx Car Audio, Video & Security 7 11-01-2002 01:48 PM
