Old 08-14-2002, 02:01 PM   #1
jr34596
Member#: 14529
Default overheating issue
jr34596 is offline   Reply With Quote
Old 08-14-2002, 02:12 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Id guess that:
Fan clutch crapped out
Car overheated slightly a few times
Head gasket had small leak
Leak pushes into coolant
Coolant boils out slightly
Car overheated again
Head gasket leaks more
Now whenever under load a sufficient amount of combustion gasses leak into the coolant that the rad cap cant keep up and it overheats.
GET A SNIFFER. They are fairly cheap and give you good confirmation.
Why did you post this in the Legacy forum? At least the Service forum would have been slightly on topic
Old 08-14-2002, 10:24 PM   #3
jr34596
Member#: 14529
ciper i actually posted this in this forum because i am aware of the problems the 2.5 have with head gasket, i was just curious if anyone had an assumption if it was the head gasket. Thanks for your reply.
Old 08-15-2002, 01:12 AM   #4
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Default Depending on the mileage
If over 60K it could be blocked cats that won't flow well. I've seen this on a couple of other 300ZXs (and other cars too). Usually ends in a blown head gasket, partly from the back pressure, but mainly because you basically run the car harder and harder to compensate for it steadily losing power over the power band. Just some food for thought... and I agree with Ciper... get a sniffer and check it out. Head gasket is more than likely going.
Br, Dale
Subietonic is offline   Reply With Quote
Old 08-15-2002, 04:59 PM   #5
Z1 Performance
Member#: 9327
A couple of things to look for:
1. Coolant in the oil, or vice versa.
2. Do a compression test (preferablly leakdown)
3. Headgaskets are a common thing on older Z's, so sounds perfectly logical. I would probably also pressure test the coolant system as well just to make sure everything is in perfect shape there too.
Adam
www.z1auto.com
Z1 Performance is offline   Reply With Quote
Old 08-15-2002, 06:06 PM   #6
jr34596
Member#: 14529
Old 08-15-2002, 06:33 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
One note, dontsuck antifreeze into the sniffer. I made this mistake the first time.
"you will be hurt if you follow my next direction"
This is total shade tree mechanic talk, so just be careful. Ive been chewed out many times for suggesting this:
Taste the antifreeze. Not drink, just taste.
If the gasses are leaking it will turn the coolant to acid. It will be very sour like battery acid. If left too long this will damage engine internals.
Old 08-15-2002, 08:18 PM   #8
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
[VOICE=HOMER]MMMMMMMMM......antifreeze[/HOMER]
HIHO is offline   Reply With Quote
Old 08-19-2002, 02:19 AM   #9
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Just make sure you rinse afterwards. It could leave a foul taste in your mouth for a long, long time otherwise.
Br, Dale
Thermostat / overheating issues Sort of odd issue psychoskip Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-15-2009 08:18 PM
overheating issue help please white2002rs Service & Maintenance 11 03-23-2007 07:04 PM
2002 wrx overheating issue rotaman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-19-2006 06:09 PM
'97 2.5 GT with overheating issues StarryNights Legacy Forum 10 04-01-2006 09:07 PM
Overheating issue... MekoNY Legacy Forum 5 10-04-2004 12:46 PM
