Old 01-21-2012, 04:49 PM   #1
chapinb
Member#: 287505
2011 WRX hatch
Default Cold weather noises '11
On very cold mornings, 5F or colder, a get a screeching noise from the turbo area. It is not the 2nd air pump starting (although thats there too). It is MUCH louder than that. It sounds like a bad bearing type squeal.
The sound goes away after the motor warms up, or if I rev to about 3k.
Once the car gets warmed up, everything sounds normal.
2 things have recently changed. This is the first time the car has seen these types of temps. I also changed my oil to Rotella 5w40.
Ideas? It will be seeing the dealer in about a week, but they wont beable to replicate it.
chapinb is offline   Reply With Quote
Old 01-21-2012, 04:56 PM   #2
424wrx
Member#: 171948
08 wrx vf52 swap
best et,[email protected]
me too. a very faint high pitched whistle. only when its pretty cold. in for answers as well.
424wrx is offline   Reply With Quote
Old 01-21-2012, 05:19 PM   #3
chapinb
Member#: 287505
2011 WRX hatch
This is in NO WAY faint or subtle.
Old 01-21-2012, 06:44 PM   #4
XsoberX
Member#: 289656
2011 Impreza WRX
Does it maybe sound like a belt squeal? My car makes that sound around -20 celsius. Only when it's very cold, and only for about 1 or 2 minutes.
XsoberX is offline   Reply With Quote
Old 01-21-2012, 06:44 PM   #5
kowalsy
Member#: 307218
2011 WRX
Rally blue
Exact same thing on my 2011. It's been down to -30C this past week where I live in Canada and this car just screems with that high pitch noise. Glad to know it's somewhat common and my engine isn't about to self destruct...
kowalsy is offline   Reply With Quote
Old 01-21-2012, 07:20 PM   #6
chapinb
Member#: 287505
2011 WRX hatch
Its not a belt squeal, but it is about as loud. Much less rubbery, more metal/metal contact sounding. Its also coming from the back left of the engine bay, same corner as the turbo.
Once the engine is semi-warm it goes away while under power (not necessarily under boost) but will make its noise again when the gas is let off.
Makes me thing the rotella is too thick when cold and the oil pressure under 2k isnt enough. The turbo is being starved of oil. But its still only a 5w...
Old 01-21-2012, 08:24 PM   #7
Vincey70
Member#: 225785
2010 WRX Prem Hatch
Mine does it too. Very loud only squeals for like a second if that. It's done it since I had bought it. Only happens in extreme cold just like you. No idea what it is though.
Vincey70 is offline   Reply With Quote
Old 01-22-2012, 02:04 PM   #8
2011boostdwrx
Member#: 263470
Me too, but i am running anHTA68 in my 11 adn using the Rotella
2011boostdwrx is offline   Reply With Quote
Old 01-22-2012, 02:39 PM   #9
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
On my car its the air-pump, does it for about 3 seconds...
wrxdrvr is offline   Reply With Quote
Old 01-23-2012, 07:29 PM   #10
ScubyMath
Member#: 297664
2012 WRX
My 2012 does the same thing when very cold. Glad I'm not the only one.
ScubyMath is offline   Reply With Quote
Old 01-24-2012, 06:16 AM   #11
aberg12012
Member#: 127614
2008 WRX
Obsidian Black
My 08 does it too. And always has when its under about 5 degrees. It sounds to me like a very cold power steering pump. (Like an "eeeeerrrrrrrrrrrr" sort of cross between a band saw and vacuum cleaner.) Goes away within about 10 seconds of being started.
aberg12012 is offline   Reply With Quote
Old 01-01-2013, 03:40 PM   #12
klogcan1
Member#: 342232
2011 WRX Hatch
Is this the cold start noise everyone is referring to? This happens to my 2011 WRX after sitting overnight if it's below -20C. This occurs whether I use a block heater or not. The whining appears to last longer the colder it is. So is this something that I should bring to the attention of the dealer, or should I consider this as "normal" for Subarus and not worry about it?
klogcan1 is offline   Reply With Quote
Old 01-01-2013, 04:38 PM   #13
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Sounds like the power steering pump in those videos.
MaddMax is offline   Reply With Quote
Old 01-01-2013, 07:39 PM   #14
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
My power steering sounds exactly like that in the mornings if its below 40. It gets better after about 5 minutes of driving
Slimsti is offline   Reply With Quote
Old 01-02-2013, 05:03 PM   #15
CO11WRX
Member#: 304018
2011 WRX Sedan
TP Stage 1
I get the exact same noise (11WRX). It only seems to happen when the temp is below 32F (it has been in the single digits here in CO at night). I only hear the noise during the first few minutes of driving on a cold engine. I freaked out the first few times I heard it, but IMO it is normal. Honestly, it took me awhile to get used to all of the different noises this car makes lol.
CO11WRX is offline   Reply With Quote
Old 01-02-2013, 08:45 PM   #16
klogcan1
Member#: 342232
2011 WRX Hatch
5 minutes of driving . And I was worried about the couple of seconds of noise on my car, lol. I guess I have a more cold weather friendly WRX than most.
Old 01-02-2013, 10:06 PM   #17
coalslaw
Member#: 324808
2006 IWL Stg2
as for me, 06 wrx, 114k miles, timing belt+water pump only done at 110k miles. now winter is here. and the squeal like you all mention here sounds like normal. but i keep freaking out when i hear it. it goes away when warm..
coalslaw is offline   Reply With Quote
Old 01-02-2013, 10:32 PM   #18
Kevwa451
Member#: 314408
2011 WRX Stage 2
My cold weather noises differ from the warm weather noises I was accustomed too. Now I've come to expect it to sound like a ship in the middle of the Bering sea ice pack on cold mornings. Screeches, whines, you name it. Interior pieces rattling, body work and suspension pieces break free from ice and and make cracking noises. I'd like to think it gives the car character, it also causes my car problem hypochondriac side to go absolutely ape*****.
Kevwa451 is offline   Reply With Quote
car noise from starting in really cold weather? Soulstar New England Impreza Club Forum -- NESIC 9 02-27-2006 05:51 PM
Cold weather - odd noise - 2.5L in Forester Back Road Runner Normally Aspirated Powertrain 4 12-14-2004 11:51 AM
Anyone hear a weird noise coming from engine bay in the cold weather? WRXVII Service & Maintenance 1 12-29-2002 06:13 PM
Cold weather noise from the rear suspension of a WRX sedan. boxerT Brakes, Steering & Suspension 3 12-09-2002 04:43 PM
Cold weather noise imprezlynn Newbies & FAQs 1 03-02-2002 07:38 PM
