Old 01-21-2012, 05:09 PM   #1
tdedmon
Member#: 236673
2011 Impreza OBS
Default cooling system upgrade...overkill?
Hey guys,
My '02 WRX wagon was overheating recently, and I am going to have to do some work on it and replace the thermostat. The car has 177k miles on it so I figure as long as i'm in there I might as well upgrade the cooling system with new silicone hoses, radiator, ancillary hoses etc.
My logic is that with that many miles, the stock hoses and such are not far away from dry rotting and rather than chase problems around for the next year or so I should just nip everything in the bud.
Is this overkill? Should I just leave well enough alone and save my money for real problems that are around the corner? Oh and here is the really stupid question: do I run the risk of making my cooling system too efficient for my stock motor? Thanks for your help guys.
I'm not really looking at modding the car too extensively, I just want to make it bulletproof so that it will last forever, and I figure preventative maintenance is the best way to do this.
tdedmon is offline   Reply With Quote
Old 01-21-2012, 08:00 PM   #2
flash02
Member#: 78916
177k, you should have done a timing belt change already, have you? Any Subaru mechanic worth a dam will change the water pump and thermostat along with the tensioner and idlers when changing the timing belt. One of the radiator tanks could be cracked, you may have air in the system, leaking hoses or you may have a head gasket issue. The stock radiator and thermostat, unless clogged or damaged works very well. Check everything before spending too much on a radiator and thermostat. Unless you live in a very cold climate and or go with a much lower thermostat don't worry about the radiator keeping the engine to cold.
flash02 is offline   Reply With Quote
Old 01-21-2012, 08:03 PM   #3
flash02
Member#: 78916
Oh and forced induction and bullet proof don't really go hand and hand....although my 02 WRX has over 160k on the clock and she is solid. Your idea of just taking care of the car and staying on top of the worn parts is a smart way to own a car.
Old 01-21-2012, 11:56 PM   #4
Pinned
Member#: 152707
It's not a bad idea to do that work, especially if you plan on keeping the car after the motor inevitably goes.
Pinned is offline   Reply With Quote
Old 01-22-2012, 10:35 AM   #5
billzebub
Member#: 40248
2003 WRX
Midnight Pearl (black)
If you haven't blown a stock radiator yet, I don't see any harm in replacing that bad boy. Its days are numbered.
billzebub is offline   Reply With Quote
Old 01-24-2012, 11:07 AM   #6
tdedmon
Member#: 236673
2011 Impreza OBS
Well the engine itself was rebuilt about 35k ago so I know the seals gaskets etc are fine. When i changed the oil there wasn't a milkshake of fluid in the engine. And it turns out it wasn't so much a coolant leak as the replacement coolant reservoir couldn't take the pressure of the system and it was blowing the coolant out. Now that I've figured out the problem I think I will save my money for a rainier day. But thanks for your input everyone.
Yeah I know bulletproof is a silly word to use, but I did learn from my last wrx that a little extra money/ work now will save mucho heartache later.
Old 01-24-2012, 11:13 AM   #7
bfedorov14
Member#: 208058
2005 WRB STi
EWG
When my radiator busted on my 05 STi, i decided to replace everything with the best parts so that i wouldnt worry about anything coolant related for another 30k.
bfedorov14 is offline   Reply With Quote
Old 01-27-2012, 01:16 PM   #8
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
30K? Original parts on entire cooling system (other than fluids) for 84K and 9 years - no issues. Just did timing belt, water pump thermo, idlers etc. Hoses looked fine. I will replace when I do stock radiator at 100K or so.
Ernest is offline   Reply With Quote
Old 01-29-2012, 03:34 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
my 06 wrx...bought NOV05... has almost 90k and all stock cooling system
but im not holding my breath on it, either
GMS 08+ Impreza Cooling system upgrade! A real Steal! GimmickMotorsports Vendor 'Group Buy' Classifieds 8 11-12-2009 10:09 PM
Aftermarket cooling system upgrade q's Nick W Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-26-2005 07:03 PM
Complete cooling system upgrade!! skubie209 Private 'For Sale' Classifieds 11 09-12-2005 02:37 PM
Cooling system upgrades?? Hondaslayer Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-10-2003 11:56 PM
Upgraded cooling system.. Running a bit warm.. AZScoobie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 12-28-2002 09:39 AM
