Old 01-21-2012, 08:33 PM   #1
Vinny G
Member#: 211173
2016 WRX Premium
Default 05 overheat
My 05 rs, lost control yesterday in the snow/ice, and popped a curb. My wheels are slightly out of alignment, but that's not the issue. The issue is that my car is overheating ever so slightly. Its happening at low speeds and when sitting still. Cruising doesn't seem to have a problem. Anyone have any ideas as to what's causing the overheat?
Vinny G is offline   Reply With Quote
Old 01-23-2012, 07:27 PM   #2
Spigatelli
Member#: 306391
2005 Outback 2.5i
I would think that it is a problem with the fans. Check to make sure they are both turning when it is hot, and check the connections down at the bottom on each side. You may have broken a wire or something.
Spigatelli is offline   Reply With Quote
Old 01-23-2012, 07:28 PM   #3
bfedorov14
Member#: 208058
2005 WRB STi
EWG
Do you have coolant in there?
bfedorov14 is offline   Reply With Quote
Old 01-23-2012, 09:30 PM   #4
Vinny G
Member#: 211173
2016 WRX Premium
Yep coolants full.
Old 01-27-2012, 02:28 AM   #5
subaru_sti_steve
Member#: 289798
94 Ranger Truck
world rusty blue
Check radiator for clog and do a pressure test.you could have air bubble
subaru_sti_steve is offline   Reply With Quote
Old 01-30-2012, 09:40 PM   #6
Vinny G
Member#: 211173
2016 WRX Premium
So after 2 weeks, I've had no problems, and its been cold so I've had heat/defrosters on all the time. but Tonight I got a little warm in my car so I turned the defroster/foot heat off and came to a red light. I was talking to my friend in the car next to me, and I looked to see my temp rising. I turned the heat and defrosters back on and it stopped climbing when it hit the 3/4 slash mark. Once I started to accelerate again the temp dropped back to normal so I drove with the defrosters on all night again and it didn't happen again.
Old 01-31-2012, 01:49 PM   #7
subaru_sti_steve
Member#: 289798
94 Ranger Truck
world rusty blue
Radiator could be clogged or air bubble in system
Old 01-31-2012, 06:04 PM   #8
Vinny G
Member#: 211173
2016 WRX Premium
Radiator cap isn't getting pressurized. Fans come on when it reaches temperature. Did a leak test, not leaking. My head gasket appears to be leaking oil.
Old 02-06-2012, 03:48 PM   #9
Vinny G
Member#: 211173
2016 WRX Premium
Any ideas
Old 02-06-2012, 07:42 PM   #10
REDrexsti
Member#: 283553
2004 wrx
jbp
This all started after you popped the curb? Did the curb have snow piled up on it that might have flattened the fins on the radiator or condenser?
REDrexsti is offline   Reply With Quote
Old 02-07-2012, 11:11 AM   #11
rkramer
Member#: 118209
2015 WRX Limitec
First, you have a head gasket leak which might be the result of overheating... (and in that case, possibly warps heads) In any case, your overheating is now a minor problem....
But on your coolant issue, define 'leak test'. Do you mean pressure test? If the system holds pressure, there is 100% no way that it can NOT build pressure at the radiator cap, assuming the cap itself isn't bad. When liquid heats up, it expands. If you have a sealed system that passed the test, it builds pressure. No way around physics...
Old 02-07-2012, 05:29 PM   #12
Vinny G
Member#: 211173
2016 WRX Premium
Correct and not that I can see. I noticed today that the car does it every once in awhile, not every time the heats off. I'm thinking it is air in the system since its not all the time, but idk how it got there
FS : 05 STI exhaust manifold crosspipe, ported and polished valleywrx Engine/Power/Exhaust 0 01-21-2012 12:40 AM
05 RS Overheat after an hour of 60 MPH, with CN wht052.5 Service & Maintenance 4 09-26-2005 04:47 AM
help overheat red of the sun Service & Maintenance 16 12-28-2002 11:25 AM
('93-'01) Engine Overheat, CE light problem Piusma Impreza Forum 11 06-04-2001 05:35 PM
Engine Overheat CRAZY KEN Normally Aspirated Powertrain 7 04-30-2001 07:04 AM
