Welcome to the North American Subaru Impreza Owners Club Thursday July 31, 2014
Old 01-21-2012, 08:53 PM   #1
fateo66
Member#: 130997
Default I need a little help trouble shooting my ignition failure
Recently I was out at the track having some fun in my 97 Impreza which has a 94 SVX eg33 swap. Partly through a lap the ignition started cutting out. If you watch the tach you can see that it is referencing what the ignition is doing and not the actual RPM's of the car.
Thus far I have swapped out the ignitor, ECU, and cam position sensor from another SVX. I also checked for power at both the ignitor and the coilpacks and cleaned off both crank sensors.
At this point I decided to check out the wiring, thinking that the harness merge had something to do with it. So I checked for continuity from both crank sensors, the cam sensor, the ignitor and the coil packs to the ECU and they all ring out.
Obviously I am missing something here. What else could have failed that would be an input for the ecu telling it not to send out spark? Input would be greatly appreciated.
I've attached a video from the track along with a schematic of the EG33 ECU.
http://www.scribd.com/doc/78980268/SVX-ECU-p1
http://www.scribd.com/doc/78980271/SVX-ECU-p2
http://www.scribd.com/doc/78980273/SVX-ECU-p3
fateo66 is offline   Reply With Quote
I need a little help setting up my new system haberkorn Car Audio, Video & Security 1 11-20-2010 09:16 PM
OT Electricians, help trouble shoot my 4way...switch stlb5 Off-Topic 17 09-21-2010 01:22 PM
Please help trouble shoot my limited WOT boost gad Factory 2.5L Turbo Powertrain 11 01-18-2009 08:03 AM
Need a little help setting up my Tial 44 ewg. 1/500yellowwrx Factory 2.5L Turbo Powertrain 9 05-01-2008 12:13 PM
Please help trouble shoot my engine noise Liam D Car Audio, Video & Security 5 07-28-2005 09:11 PM
