Old 01-22-2012, 12:48 AM   #1
Pinned
Member#: 152707
Default Ignition replacement: 2 keys?
I just had my ignition replaced, and now I'm left with two keys. This was done while I was away, but I was pretty sure there is a way to continue using my one original key. Can the lock cylinder for the ignition be replaced? My mechanic says no, but I believe otherwise.
The only video or anything I can find is of an old legacy, this is for a 2001 RS though, so I'm not sure if the key cylinder can still be swapped into a new ignition. But it seems to me that it would be pretty backwards to be forced to use two separate keys if an ignition goes bad.
Pinned is offline   Reply With Quote
Old 01-22-2012, 11:17 AM   #2
Elbert Bass
Member#: 283429
Swapping the lock cylinder usually depends on what the original problem is. If the cylinder is too worn or binds in the old lock it is not a good idea to put it in the new lock. Being that old I would opt for the new cylinder and rekey.
SOA offers a matched lockset with all the locks/cylinders but apparently your mechanic didn't give you that option. I bet a locksmith is cheaper anyway. Call a locksmith and have him rekey either your ignition or your door locks (whichever is least expensive) to get you back to one key.
Elbert Bass is offline   Reply With Quote
NYC: 04 WRX ignition lock w/ key and illumination ring jamesfacts Interior/Dressup/Audio & Security 16 03-25-2010 06:18 PM
Pushbutton start style ignition, except with key JDMFLCL Newbies & FAQs 11 04-06-2009 07:05 PM
Ignition, Lockset w/ KEY!!! JRach NWIC Private Classifieds 4 08-13-2008 01:51 PM
wtb: door locks, trunk lock, and ignition slot with keys and remote system for 02 wrx M.R.blue Private 'Wanted' Classifieds 2 03-31-2007 12:41 AM
ignition wire from key cylinder ptirmal Electrical & Lighting 2 06-17-2006 11:10 PM
